Old 25th November 2013, 15:30   #3076
NetfreakBombay's Avatar
Thanked: 352 Times
Default Re: The GPS/Maps Discussion Thread (Dedicated Satnav, Smartphones, Tablets, etc)
What if you are on a 25 day cross country trip with no laptop. Will it save 25 days of tracks?
Its more like a year or two. I still have tracks from 2012 on device.
Old 26th November 2013, 11:01   #3077
DerAlte's Avatar
Thanked: 2,877 Times
Garmin periodically renames the current GPX file and creates a new GPX file. If storage is dangerously low, it deletes the oldest file.
Old 26th November 2013, 13:14   #3078
Thanked: 6,864 Times
See if the software is non transparently deleting tracks, then its not a trackker. What if you are on a 25 day cross country trip with no laptop. Will it save 25 days of tracks?
I only have experience with the Garmin Etrex. Tracks are essentially a bread crump trail of coordinates and full is full. What happens then is that the first bread crump is deleted, and then the next. So when the track memory is full, the Etrex will still add the ongoing track, but it will take of the equal amount at the beginning of the track or the oldest track.
The amount of track you can store is more or less distance based. Although, I believe that a track with many curves will take up more storage then one with long straigths in it.
So in practical terms you need to save each track. Either on the Garmin or on your PC. Not sure what the limitations are on the Garmin.
So you need to distinguish what happens to the active track, even if it is spread over multiple days, and the tracks that you save.
Jeroen
Jeroen is offline   Reply With Quote
Old 26th November 2013, 14:09   #3079
ampere's Avatar
Thanked: 8,760 Times
+1. Even entry level Nuvi devices have an archive folder where it moves to the sampled points to a GPX file if the active size increased.. In many case, now folks are asking for improvements where the user has the capability to mention where the archive folder is. (Basically point to to an SD card mounted on the device). Though I dont know if that is available today.
Old 27th November 2013, 09:22   #3080
sgiitk's Avatar
Thanked: 3,795 Times
Infractions: 0/1 (5)
How does one access the data in the gpx file? Sorry for being naive.
Old 27th November 2013, 10:15   #3081
ampere's Avatar
Open the GPX on Google earth or Garmin's own S/W (Mapsource/Basecamp).
But for Mapsource/Basecamp you should have the map installed on the PC/MAC.
Google Earth; its much easier. Open the GPX and it shows trail/track overlaid on Google maps.
Old 27th November 2013, 11:16   #3082
I've been looking into this, but I couldn't get it to work; how do I get my track (ie GPX) file overlaid on google earth, or just google maps?
I'm using Mapsource for most of my planning, but I'd like to see it on google earth, make screenshots so I can upload these to my website etc.
any pointers on how to do it would be appreciated.
Jeroen
Old 27th November 2013, 11:32   #3083
ampere's Avatar
Its quite straight forward:
- If you have tracks on your Garmin device, connect to Mapsource and download on your PC/Mac
- Once in there export these tracks as GPS files on your PC
- Open Google Eaarth
- File-Open- GPX file through the Menu (Yes its as simple as that! )
Don't know where you are going wrong. But yes that is the set of steps.
Old 27th November 2013, 11:33   #3084
sgiitk's Avatar
I tried one under the guidance of ampere but somehow could not get mapsource / basecamp to work. Any fresh suggestions?
Old 27th November 2013, 11:43   #3085
Thanks, ill try again later this week. Just noticed, im not using mapsource, but basecamp. Ill check, if anything moving a file from the Etrex on the PC should be a problem and I guess can be done with any editor as well, without disturbing the content.
Jeroen
Old 27th November 2013, 12:28   #3086
ampere's Avatar
@SG, what you tried is how to install MMI/Satguide maps on PC.
Here its just downloading files your device on Mapsource (whether any maps are installed or not).
And saving them GPX on your computer and finally importing them on to Google earth.
Old 27th November 2013, 13:00   #3087
Twiny's Avatar
Thanked: 47 Times
Did not see Garmin 50LM / 52LM in the supported Garmin devices for MapMyIndia maps.
Does anybody sure of compatibility of MMI maps on LM 50 / LM 52
Twiny is offline   Reply With Quote
Old 28th November 2013, 13:56   #3088
ampere's Avatar
MMI launches MMI-Connect.
http://www.telecomtiger.com/Technolo...2&section=S210
Still wondering how useful the feature can be...
Old 5th December 2013, 12:12   #3089
Thanked: 210 Times
Try using MotionX GPS for iOS. Not available for Android. You can import and export tracks.
bsdbsd is offline   Reply With Quote
Old 5th December 2013, 12:39   #3090
vu2pmc's Avatar
Thanked: 32 Times
Not sure, what you meant by data in a GPX file?
You can download gpx file from a Garmin device to a PC using Mapsource.
Such downloaded GPS file can be converted to various file formats like CSV, KML, KMZ, GDB etc using various conversion software tools. I will suggest GPSBabel, which is more like a Swiss army knife.
Besides, Google earth can import gpx from GPS directly.
If you connect GPS as a mass storage option, you can access the GPX files saved on your Sd card using any file explorer. Certain Garmin models give you an option to save the track log to be saved on SD card with out wrapping instead of its internal memory
vu2pmc is offline   Reply With Quote
Sygic Maps Vs MMI maps, what's the difference? rkbharat Gadgets, Computers & Software 38 1st July 2014 07:43
Thoughts on Dedicated Bus, Cycle, Autorickshaw lanes etc carjinx The Indian Car Scene 21 3rd July 2012 12:30
Satnav Launches GPS Navigation Software navdeep Modifications & Accessories 119 16th November 2010 15:48
MapMyIndia vs SatGuide - Best Dedicated GPS Solution lynx Route / Travel Queries 2 20th February 2009 18:29
