Old 13th October 2014, 09:50   #3241
ampere's Avatar
Thanked: 8,760 Times
Default Re: The GPS/Maps Discussion Thread (Dedicated Satnav, Smartphones, Tablets, etc)
Originally Posted by NetfreakBombay View Post
+1, I think this sums up my experience with GPS too.
And thanks to you, I do that too! I still have the sequence that you suggested to me 5 years back for Garmin!
Only thing I now have added is ported the whole DB to a MAC. I still cant create the native MAC DB. I instal the map on Mapsource on a Windows PC and then export to a MAC DB (Garmin API) and then read it into a MAC
Old 13th October 2014, 13:45   #3242
Thad E Ginathom's Avatar
Thanked: 7,468 Times
To add to HVK, you can only use the GPS as a means to validate what you already know. In other words, use it to confirm the route that you plan to take. Its a good servant, but a very bad master. Leave it on its own for a minute and it would take to totally different journey!
I often use GPS not for reaching a general area, which, at least in my own city, I may know very well how to reach, but to navigate unknown streets once I get there.
Arguing with it, as I take my usual short cuts and traffic-avoidance routes, gives me something to do
Old 13th October 2014, 13:55   #3243
ampere's Avatar
I follow that approach in a city where I am new to. For example, if I have to drive down to Chennai from Bangalore, I plan the high level route on PC and then transfer this info to GPS. But then if I have to do short travels within Chennai, I just follow the GPS within the city. But however before starting my drive within Chennai, I do check Google too: Just to be on a safer footing. )
Old 13th October 2014, 20:19   #3244
How to Export KML Files?
I tried to find this information to no avail. I have been using MMI in my XUV for around10 months, now I find a need to export the saved routes to KML. I see the option in Logs to convert this to KML. I do not know how to export that file to my computer. Any body has done this here?
Thanks in advance.
vijaymishra is offline   Reply With Quote
Old 13th October 2014, 20:43   #3245
ampere's Avatar
Thanks in advance.
Why KML? If you can export to GPX, you can pretty much use it every where. If you really need to convert, one option is Google Earth and the other option is GPS Babel.
Old 13th October 2014, 21:47   #3246
TorqueyTechie's Avatar
Thanked: 1,061 Times
Hi, I am not sure if this would be the right thread to post this question.
I am looking for a sports watch to track my run. It should have GPS, ability to calculate speed of my run, time, calories and distance and provide me an easy way to collate the data.
I have shortlisted the below 2.
1. http://www.engadget.com/products/garmin/forerunner/410/
2. http://www.engadget.com/products/garmin/forerunner/220/
I have used RunKeeper app on my iPhone to track this and its a very good with a simple UI. Would be good if I could get something similar ( I know its not possible).
Please suggest me which one to go for. (Any other suggestion is also fine)
TorqueyTechie is online now   Reply With Quote
Old 14th October 2014, 10:33   #3247
Hello Ampere,
Thanks. My question is more towards fetching the file. The logs are in the Car inbuilt MMI GPS system, how do I export this to my computer.
Old 14th October 2014, 18:06   #3248
sgiitk's Avatar
Thanked: 3,795 Times
Infractions: 0/1 (5)
Any idea of the source of maps in the in-built AV units. Caska uses MMI, Mercs are Garmin, others ...
Old 14th October 2014, 18:16   #3249
Thanked: 6,864 Times
I have a TomTom Sport watch, see http://sports.tomtom.com/en_us/
It does all you want and some more. It monitors your heart rate without the need for these strap on your chest devices.
It has various different run modes. For instance you can set it on interval and determine time or distance to run, walk etc. one of the most useful function I find is the race function. This will allow you to keep track of your progress against a previous run. So it shows you continuously how much ahead or behind you are compared to the last time you ran the same distance.
It works very well and all the data gets uploaded to a website automatically as soon as hook it up to your PC. The one thing you need to check with these GPS watches is to find some user experience how quickly they lock onto the GPS satellites. This one has a special quick start. Means in practice that I get a GPS lock within 30-60 seconds of it switching on.
Jeroen
Jeroen is offline   Reply With Quote
Old 14th October 2014, 18:26   #3250
msdivy's Avatar
Thanked: 842 Times
In my experience, useful way of working with GPS is:
One more use of GPS - to find remaining distance to destination. No need to lookout for milestones .
msdivy is offline   Reply With Quote
Old 14th October 2014, 20:50   #3251
ampere's Avatar
May be / May not be! If there are way points in between and you need to fork out, then GPS typically announces/displays distance to the next waypoint.
Old 14th October 2014, 21:11   #3252
Try Get a GPS that does both. Even my tiny Garmin Etrex does distance and time to the next waypoint and or the destination.
Jeroen
Old 20th October 2014, 14:50   #3253
Thanked: 210 Times
Does anyone know of a good navigator program for an Intel based device? I have a Microsoft Surface Pro (with an Core i5 processor), which I would like to use for navigation and streaming music. Does the Google Maps on PC provide driving directions? Is it an overkill to have a PC as GPS?
If possible, please suggest me a good 5" phone, to be used exclusively for navigation purposes.
Thanks in advance!
bsdbsd is offline   Reply With Quote
Old 20th October 2014, 15:40   #3254
msdivy's Avatar
Thanked: 842 Times
Doesn't Surface come with bing maps? Microsoft provides offline maps too.
AFAIK, any smart phone will do.
Old 21st October 2014, 14:28   #3255
Thanked: 210 Times
Thanks. I tried Bing maps. At best, its unfriendly. I seriously don't understand why a company of Microsoft's caliber release such applications. I tried Here maps as well. Its another half-baked application. Guess I will stick to my Nexus 7 for foreseeable feature.
Sygic Maps Vs MMI maps, what's the difference? rkbharat Gadgets, Computers & Software 38 1st July 2014 07:43
Thoughts on Dedicated Bus, Cycle, Autorickshaw lanes etc carjinx The Indian Car Scene 21 3rd July 2012 12:30
Satnav Launches GPS Navigation Software navdeep Modifications & Accessories 119 16th November 2010 15:48
MapMyIndia vs SatGuide - Best Dedicated GPS Solution lynx Route / Travel Queries 2 20th February 2009 18:29
