Old 21st May 2010, 14:40   #961
sgiitk's Avatar
Thanked: 3,884 Times
My son used good old Google Maps on his htc Hero and was quite happy with the information on the one way system in Bengaluru.
Just got my SatNav u-SD card with adapter. About 131MB of info on the card.
Old 21st May 2010, 15:17   #962
PlaneMad's Avatar
Based on the site, just installed the maps in Mapsource. Looks pretty impressive. But not sure how comprehensive this is. But initial impressions look very good.
The routes may be updated, but POI would still lack.
Atleast it updates the NH207 correctly. Picture from Mapsource attached.
Mods, please merge the back-to-back posts. I could not merge them. I did not know how to upload pictures in a edit mode.
Attachment 350019
Looks pretty cool. Yup, POIs would lack, but its a collaborative project like wikipedia,, so as time goes on, it only gets better. Its quite impressive considering its totally free.
I also managed to get these maps onto my phone as a java application. the whole data is stored on the phone, so theres no need for gprs or gps. It's got some pretty kickass features like POI searching, routing with voice, map rotation. Its quite a useful thing to have on your phone just in case, should work in almost any java capable phone.
(click for details)
download link (transfer both the .jar and .jad files to your phone)
GpsMid - Free offline maps for various cities and countries
openstreetmap project site, where you can add map data:
http://www.osm.org
PlaneMad is offline   Reply With Quote
Old 21st May 2010, 18:15   #963
blackstallion76's Avatar
Thanked: 12 Times
Is there any GPS system which comes along with Music System build in as well?
Just trying to save some space inside swift.
OR
Should we buy them separate?
Please advice.
blackstallion76 is offline   Reply With Quote
Old 21st May 2010, 19:17   #964
Thanked: 1,345 Times
A quick query.
I got my SatNav Map on the microSD card with the SD card adapter. I put it in my Garmin Nuvi 260W and it does not show up in my map list. Do i need to do anything specific? Can i copy the map directly to the device, assuming that the device is not able to access the SD card? I do not need the US maps setup on the GPS devices currently.
sachinayak is online now   Reply With Quote
Old 21st May 2010, 20:23   #965
smsrini's Avatar
Thanked: 272 Times
OR
Please advice.
check Satnav site and Garmin site for devices that can do this.
Satnav has a all in one.
GArmin offers a GPS device that will use your double din receiver screen if it allows a external video feed.
You can also consider a 2 DIN Carputer from iRide that will do music, video, GPS, mobile internet, reverse cam etc.,
smsrini is offline   Reply With Quote
Old 22nd May 2010, 14:00   #966
nkapoor777's Avatar
Thanked: 91 Times
Originally Posted by sachinayak View Post
A quick query.
I had the same issue. I renamed the US mapset to something else and then inserted the SD card. It worked! I don't know how but I used this trial & error since I noticed that both the US mapset and Satguide maps had the file name as "gmapsupp.img". Try it and see if it works for you.
nkapoor777 is offline   Reply With Quote
Old 22nd May 2010, 14:03   #967
raamki's Avatar
Thanked: 42 Times
Arrow Travel Pilot Lucca 3.5
Picked up a Blaupunkt TP Lucca 3.5 from MMI yesterday, here's my story and a couple pictures of the setup:
A week ago, after reading quite a bit about MMI shipping the Lucca as an alternate to Roadpilot, i rang them out of curiosity to check if the Lucca was still available for 8k in spite of their website showing that the RP stocks were back. I got a reply in the negative and was told that the Lucca was now being sold @ its original MRP, which was 14k as the RP stocks were indeed back.
Hard luck i thought and requested for a RoadPilot demo anyway. I've never really used a GPS device earlier and because I have an ice cool shield on my car's front windshield apart from window films on all other windows, i wanted to make sure the device would receive a signal and stay connected at all times on the road (call me stupid, but i have read about window film's interfering with gps reception et all).
2 days and a couple of phone calls later, this chap from MMI comes down with a Vx130 for a demo. We sit in the car and are searching for a signal, i drive away from the building and in less than 2 minutes, the GPS signal is received, its connected to 5 satellites and the reception status showed up as 'Good', it eventually connected to 8 sats. We took a small drive around the Domlur area and i was super happy and excited about the accurate voice assisted turn direction indicator.
I was going to buy some time and ponder over the RoadPilot in my head for a few days when, to my surprise, this chap pulls out a TP Lucca box out of his bag. He tells me it was supposed to be sold to another customer in the morning but unfortunately, he couldn't get a hold of him! (Fortunate for me, i thought) He claims this was the last piece in stock in Bangalore across all distributors. I ask him for the price and he says, 8K!!
We head to his office and the deal is done!! Amidst all the excitement, I had not even bothered to open the box and find out if the unit was in one piece! turns out, it has a zillion scratches on the side panels, the LCD was intact and didn't have a scratch though! Turns on, works fine!!
Later realize from the 'recently navigated destinations' that it was used twice in Kerala! And yes, it was manufactured and imported way back in august of 2008!!
The navigation is precise & the touchscreen response is great, only 2 grouses though:
  • The voice-assist lady at the max volume sounds horrible, the clarity is better with the volume bar at about 70-80%.
  • Apparently, i took a wrong turn into a road that was closed thanks to the Metro work last evening. The navigator kept wanting me to go back the same way after i took a detour. Just wondering, does it not re-calculate and adjust itself to an alternate route based on the current position of the car and the destination position?
Attaching a couple pictures i took of the setup in my car. I must mention, the suction cup holder is awesome!! i vigorously shook it in its place after mounting it and it refused to budge!!
The GPS/Maps Discussion Thread (Dedicated Satnav, Smartphones, Tablets, etc)-dsc00101.jpg
The GPS/Maps Discussion Thread (Dedicated Satnav, Smartphones, Tablets, etc)-dsc00102.jpg
The GPS/Maps Discussion Thread (Dedicated Satnav, Smartphones, Tablets, etc)-dsc00103.jpg
The GPS/Maps Discussion Thread (Dedicated Satnav, Smartphones, Tablets, etc)-dsc00104.jpg
The GPS/Maps Discussion Thread (Dedicated Satnav, Smartphones, Tablets, etc)-dsc00105.jpg
The GPS/Maps Discussion Thread (Dedicated Satnav, Smartphones, Tablets, etc)-dsc00106.jpg
The GPS/Maps Discussion Thread (Dedicated Satnav, Smartphones, Tablets, etc)-dsc00107.jpg
The GPS/Maps Discussion Thread (Dedicated Satnav, Smartphones, Tablets, etc)-dsc00108.jpg
The GPS/Maps Discussion Thread (Dedicated Satnav, Smartphones, Tablets, etc)-dsc00109.jpg
The GPS/Maps Discussion Thread (Dedicated Satnav, Smartphones, Tablets, etc)-dsc00110.jpg
raamki is offline   Reply With Quote
Old 22nd May 2010, 14:25   #968
starter's Avatar
Thanked: 327 Times
Default Need help in deciding which GPS
Dear Friends,
I am planning to buy a GPS that can help me do my long distance trips without much detours.
So, i was looking at the following site GPS Devices in India,Garmin navigation in India,Marine navigation in India,Garmin Products in India,Rugged automotive GPS devices in India,GPS navigation for India Road,Authorised distributor for Garmin, Oetiker GPS products for India, Two way radio,
This is supposed to be the authorized Garmin dealer in Bangalore.
I see that there is a deal for Nuvi 215 for Rs.9500.
Is this worth the money am spending and will this be helpful, if say, am doing a trip from Bangalore to Leh?
Or, do you suggest another model viz. Nuvi 715?
Would there be any additional charges that one needs to pay, viz usage of GPS or to download maps or for some extended coverage (remote places)? Sorry, if these questions sound stupid.
Thanks a lot for this information.
Cheers,
Deepak
starter is offline   Reply With Quote
Old 22nd May 2010, 14:36   #969
Samurai's Avatar
Thanked: 15,776 Times
Deepak, buy it from 20North.com, you can get recent models for cheaper prices.
Old 22nd May 2010, 15:24   #970
Thad E Ginathom's Avatar
Thanked: 8,377 Times
raamki, thanks for your pics and description.
For safety, I recommend you not to mount this unit in the centre of your windscreen, but to move it to the bottom edge. which is, I think, the more usually chosen position.
Old 22nd May 2010, 19:20   #971
starter's Avatar
Thanked: 327 Times
Thanks a lot for your message Sharath!
I shall read up a little bit, will try to understand how this works.
Will collect my questions and maybe post here.
Could you suggest a model for me Sharath?
Thanks a lot!
Cheers,
Deepak
Old 24th May 2010, 11:41   #972
sorry, duplicate post, posted in http://www.team-bhp.com/forum/techni...ml#post1901543 (Using a GPS Receiver in the Car)
sidkun is offline   Reply With Quote
Old 24th May 2010, 13:58   #973
smsrini's Avatar
Thanked: 272 Times
Default SatGuide Maps on my Nuvii 265W
Got my Satguide maps and working with Nuvii.
First impressions are good. Routing working fine, and any changes from suggested route, the re-route is completed in less than 10 secs. Tried my office route from Hennur to Dairy Circle in Bangalore, and though it first suggested the ORR, once I crossed Hennur cross roads, it re-calculated the route and showed my daily route. It opted to route via Manipal Center and Trinity circle for some reason, which would have been a longer route, but again re-calculation was fast enough.
No city map details after Yellahanka in the north. was able to go upto Sarjapur and NH207 ( Indus intl school ) in the south.
Loading maps is a tad slow, and I want to check how I can copy the maps to the device rather than keep it on the SD Card.
For the money paid, its definitely VFM.
cheers!
Srini
Old 24th May 2010, 14:09   #974
MX6
MX6's Avatar
Thanked: 213 Times
Cheers,
Deepak
No additional charges for use of GPS. You need to buy maps from either satnav (currently at 990 bucks) or MMI (7000 bucks).
There's nothing like extended coverage. As and when MMI/ Satnav add more cities and POIs to their map, they release an upgrade (once a quarter) and you may feel free to upgrade to the same at a nominal price. I guess it would be a good idea to upgrade to the next version once a year or so.
MX6 is offline   Reply With Quote
Old 24th May 2010, 14:28   #975
amitoj's Avatar
Thanked: 1,705 Times
Ok, from my recent trip to Chikmaglur, i realised that MMI has pathetic coverage of state highways. Lesser said about roads smaller than SH, the better.
On the Bangalore - Magadi route, after some time it started showing that i was not driving on a road anymore. I am not talking about it showing me driving next to the road or like that. It showed that i was in the middle of nowhere
Same story on the interior roads of Chikmaglur too.
amitoj is offline   Reply With Quote
Sygic Maps Vs MMI maps, what's the difference? rkbharat Gadgets, Computers & Software 38 1st July 2014 07:43
Thoughts on Dedicated Bus, Cycle, Autorickshaw lanes etc carjinx The Indian Car Scene 21 3rd July 2012 12:30
Satnav Launches GPS Navigation Software navdeep Modifications & Accessories 119 16th November 2010 15:48
MapMyIndia vs SatGuide - Best Dedicated GPS Solution lynx Route / Travel Queries 2 20th February 2009 18:29
