Old 21st September 2010, 13:59   #1351
NetfreakBombay's Avatar
Thanked: 402 Times
Originally Posted by wanderernomad View Post
Why dont you guys buy the Chinese GPS units? They cost around 80$ for the 5" version and even less for 3.5", 4.3", 4.8" and so on. These devices have AV in to attach your rear view camera as well not to forget the BT. I think they are value for money.
I used such a unit for a year and later purchased Garmin. These units have lots of features, but they do not match Garmin in terms on robustness and accuracy of GPS Signal.
One advantage of Chinese units is Windows CE. Because of this you can use MMI/Satguide/Navteq or any other maps.
Old 21st September 2010, 14:09   #1352
MX6
MX6's Avatar
Thanked: 213 Times
@wanderernomad. One has to ensure the GPS chipset is of repute and locks to satellite signals quickly from cold start and also don't lose signals when there's a rain or cloud that easily.
My Garmin 265WT worked and navigated me perfectly in a 7 hour deluge that sunk Konkan couple of months back. Not once did I lose signal.
MX6 is offline   Reply With Quote
Old 21st September 2010, 14:43   #1353
Twiny's Avatar
Thanked: 47 Times
Anybody using Garmin-1490 be able to give a feedback.
Also will there be satellite signal reception issue with V-kool sunfilm on windshield. (Side and rear films are Garware)
Twiny is offline   Reply With Quote
Old 21st September 2010, 15:01   #1354
sgiitk's Avatar
Thanked: 3,884 Times
@Twiny: You should not have any problems with the 1490.
Sunfilm should not matter. Maybe the metallised (shiny) type can have a very marginal effect.
Old 21st September 2010, 15:08   #1355
Thanked: 402 Times
Since V-kool has metallic wires, it does affect GPS. However, there are solutions to this. You can attach an external antenna or you can cut few square inch of film just in front of GPS.
You can first use the GPS as it is and try workarounds if issue actually creates a problem with GPS fix.
Old 21st September 2010, 15:27   #1356
Twiny's Avatar
Thanked: 47 Times
Thanks sgiik, netfreak..
Is there provision for connecting ext antenna to Garmin
Old 21st September 2010, 15:37   #1357
Thanked: 402 Times
Yes, you need to buy an antenna similar to this :
https://buy.garmin.com/shop/shop.do?pID=33370
Old 22nd September 2010, 10:01   #1358
sgiitk's Avatar
@Twiny: I will suggest try it out before hunting for the antenna. You may find the signal level more than acceptable.
Old 22nd September 2010, 12:10   #1359
Thanked: 164 Times
Finally i upgraded to MMI maps Version 5. Now my GPS talks in Kannada
shamanth is offline   Reply With Quote
Old 22nd September 2010, 13:08   #1360
Thanked: 17 Times
Hey Shamnath, can you post a picture of your GPS device on the ANHC dashboard? I wanna know how it looks on the City dashboard. Is it a MMI device?
pamishra is offline   Reply With Quote
Old 22nd September 2010, 13:30   #1361
wanderernomad's Avatar
Thanked: 806 Times
I have atleast 5 friends who have been using these chinese units for more than a year now without any issues. Plus I agree that the GPS chipset should be of repute but these days when everything is made in China how can you be sure that its not the same chipset in yours too? But anyway it was a suggestion based on the practicalities and the VFM options. To each his own, but for newbies or first timers I am sure these Chinese units make much more sense and as pointed out above being windows CE they are very versatile and feature oriented.
@pamsihra : these things will run almost everything. My own brother is running both MMI and Satguide on his device. So am I though mine is not an outright chinese unit but a MIO.
wanderernomad is offline   Reply With Quote
Old 22nd September 2010, 17:39   #1362
Thanked: 164 Times
These are the pictures on my ANHC with MMI VX140. This angle and position is pretty good for ANHC. I am planning to put dashboard sticker, since i want to go for front windshield sun-film.
The GPS/Maps Discussion Thread (Dedicated Satnav, Smartphones, Tablets, etc)-10112009.jpg
The GPS/Maps Discussion Thread (Dedicated Satnav, Smartphones, Tablets, etc)-10112009_001.jpg
Old 23rd September 2010, 08:51   #1363
Thanked: 17 Times
Thats neat! Thanks Shamnath.
Also does the MMI box contain dashboard sticker as well? Or is it the friction mount you are talking about? Any link to show where this stickers are available?
Old 23rd September 2010, 09:50   #1364
Thanked: 164 Times
Not sure if its available in India. Got them in US
Amazon.com: ARKON AP013 Adapter Plate 80mm Circular Adhesive Dash / Console Disc with 3M Adhesive: GPS & Navigation
you may get it from 20north, but postage is almost Rs 500
ARKON AP013 Adapter Plate 80mm Circular Adhesive Dash / Console Disc with 3M Adhesive < Electronics : Electronics - Shop in the US from India @ 20North
Old 23rd September 2010, 10:18   #1365
Thanked: 17 Times
Thanks Shamanth..this is good info!!
Sygic Maps Vs MMI maps, what's the difference? rkbharat Gadgets, Computers & Software 38 1st July 2014 07:43
Thoughts on Dedicated Bus, Cycle, Autorickshaw lanes etc carjinx The Indian Car Scene 21 3rd July 2012 12:30
Satnav Launches GPS Navigation Software navdeep Modifications & Accessories 119 16th November 2010 15:48
MapMyIndia vs SatGuide - Best Dedicated GPS Solution lynx Route / Travel Queries 2 20th February 2009 18:29
