Old 28th October 2010, 21:00   #1456
ampere's Avatar
Thanked: 9,080 Times
100 pages of discussion on the same topic:
http://www.team-bhp.com/forum/gadget...yindia-97.html
Use that thread. All your doubts will get cleared. We can actually close this thread.
Summary:
If possible buy a Garmin device from Amazon (You will get in 100$ range and then add Satguide or MMI maps).
Old 29th October 2010, 06:55   #1457
JMaruru's Avatar
Thanked: 107 Times
Question Garmin Nuvi 1100?
Originally Posted by neel385 View Post
I am using the Garmin 265 WT which I got from the US for Rs 7500. Satnav maps cost about Rs 1000.
Would this model work in India? Pl. advise.
Newegg.com - Recertified: GARMIN nüvi 1100 3.5" Slim GPS Navigator
JMaruru is online now   Reply With Quote
Old 29th October 2010, 07:32   #1458
kailashnj's Avatar
Thanked: 279 Times
Originally Posted by womanonwheels View Post
Hi All,
Has anyone bought a GPS unit recently? What are some of the things I need to keep in my mind? My budget is 10000. Can I buy a decent one in this cost in Mumbai?
Mapmyindia have the best maps that are currently available. You can buy a device with the latest maps for around 8000. I would suggest go for these.
Buy MapmyIndia Navigator : GPS Navigation in India | Portable Navigation Device (PND) with India's best maps
Also now a days you get lot of mobile phones with GPS capabilities, for example Samsung galaxy 3 which has GPS and is available for 11000 only. This has the best maps that are available from Google Maps and you can buy the MapMyIndia for another 2000. This way you do not have to carry 2 different devices.
Hope this helps.
Kailash
kailashnj is offline   Reply With Quote
Old 29th October 2010, 07:50   #1459
kousik's Avatar
Thanked: 36 Times
Perfectly. I am using it everyday with Satguide.in maps.
(as ampere noted before, let's merge this thread with existing one(s)).
kousik is offline   Reply With Quote
Old 29th October 2010, 10:33   #1460
kousik's Avatar
Thanked: 36 Times
Originally Posted by decode View Post
Hi Kousik,
I see that you have mounted the GPS device in your innova. Could you be able to load a day light photo (I wanted to know how you have mounted it under/near the AC vent)
There you go. I had one of this: eBay India: Car Universal Holder Cradle Mount for GPS CELL PHONE (item 280572604294 end time 07-Nov-2010 15:51:51 IST) at home. The width it can hold was just enough for a slim Nuvi (a W model wouldn't fit), and still then I had to open/reassemble it up to change some alignment because the USB charging point wasn't getting exposed properly. It is pretty good now, held securely (doesn't shake) by foam padded arms, low enough not to draw attraction from casual outsiders, and still signal is strong enough for accurate navigation.
Old 29th October 2010, 15:47   #1461
cool_dube's Avatar
Thanked: 397 Times
Do you get a clear view? From the picture it appears that the steering wheel would be blocking your view.
cool_dube is offline   Reply With Quote
Old 29th October 2010, 16:51   #1462
kousik's Avatar
Thanked: 36 Times
Yep, only the right bottom corner is not visible directly (have to lean a little), but that generally contains current speed and eco-drive score, so no real rush/curiosity to read those numbers. All necessary readings are in clear view.
Old 29th October 2010, 19:02   #1463
Thanked: 52 Times
Thank you Kousik. One question , where have you mounted the base of the holder? It seems like it is blocking the A/C vent too. Extensive exposure near to the A/C blower could be a risk..right?
decode is offline   Reply With Quote
Old 29th October 2010, 20:58   #1464
kousik's Avatar
Thanked: 36 Times
Yes it half blocks the vent, but I don't use much ac anyway, generally left in the milder setting. I'll figure out an alternative by summer.
Old 31st October 2010, 06:11   #1465
JMaruru's Avatar
Thanked: 107 Times
Question Satguide.in?
OK. So how much would be for this satguide.in maps? Where can we procure the same in Bangalore?
Old 31st October 2010, 08:39   #1466
NetfreakBombay's Avatar
Thanked: 396 Times
Maps cost 1000 and can be purchased online.
NetfreakBombay is online now   Reply With Quote
Old 2nd November 2010, 11:56   #1467
Originally Posted by mukeshgoel View Post
The coupon code is - glbgHJIty
Source: Satguide on facebook.
Does this above coupon code worked for someone at the Satguide website. I tried to purchase map for my Garmin 205 which I used in US. But there seems to be no discount further after adding the above coupon code. The price still shows 990/-. /
Someone, please confirm if these coupons work.
Also, I was thinking if I we could use copy these micro-sd card content to multiple cards and then use on other devices or if there is some lock which prevents it from being copied.
sameer551 is offline   Reply With Quote
Old 2nd November 2010, 12:15   #1468
sgiitk's Avatar
Thanked: 3,868 Times
@sameer551: The code is locked to the specific card.
Old 2nd November 2010, 12:46   #1469
Thanks sir. I will try to buy it from some store in Delhi. I don't use online payment gateways. I hope they do sell these sd cards on their tie up retail outlets.
Old 2nd November 2010, 14:08   #1470
sgiitk's Avatar
Yes. There is a post on another channel that they now sell only on MicroSD and do not give you the adapter. These should be about Rs.50, and easily available on the market. For all you know there may even be one sitting in some drawer. Also, there is some talk of picking up some code (a marketing gimmick) and getting a SatNav for Rs.475!
Sygic Maps Vs MMI maps, what's the difference? rkbharat Gadgets, Computers & Software 38 1st July 2014 07:43
Thoughts on Dedicated Bus, Cycle, Autorickshaw lanes etc carjinx The Indian Car Scene 21 3rd July 2012 12:30
Satnav Launches GPS Navigation Software navdeep Modifications & Accessories 119 16th November 2010 15:48
MapMyIndia vs SatGuide - Best Dedicated GPS Solution lynx Route / Travel Queries 2 20th February 2009 18:29
