Old 14th September 2009, 21:05   #16
Raccoon's Avatar
Thanked: 105 Times
^^^ Yes, but the Amaron we have is very low maintenance. Have top up less than even once a year. This could vary with usage though.
Old 15th September 2009, 01:21   #17
ghpk's Avatar
Thanked: 193 Times
Iam Happy with Okaya Red since last 2+ years now.
Old 20th September 2009, 21:54   #18
Gansan's Avatar
Thanked: 909 Times
I have installed Amaron Shield 160 AH battery. I got a discount of Rs 1200 for my failed Prestolite battery and I paid a balance of Rs 7000/-.
Old 2nd February 2010, 11:02   #19
gopikb's Avatar
Thanked: 132 Times
Hi Gansan, Are the Amaron Shield maintenance free batteries or is it the regular battery in which you have to top up the distilled water regularly? How is the performance of the battery since you started using it?
gopikb is offline   Reply With Quote
Old 2nd February 2010, 11:07   #20
Gansan's Avatar
Thanked: 909 Times
It is the regular type, black case battery. The electrolyte level can be inspected only by opening the caps, which I do once in two months. I have had to add just a little distilled water so far. I am satisfied with the performance.
Old 4th February 2010, 02:19   #21
navan49's Avatar
Thanked: 69 Times
Can some one suggest a good inverter for TV System Laser printer,Scanner and a fan and 2 tube lights. I have least idea about inverters in Chennai. The place where I lived for a long time did not have power problem at all but Chennai is different Please help.
navan49 is offline   Reply With Quote
Old 4th February 2010, 07:04   #22
Gansan's Avatar
Thanked: 909 Times
I am using Usha Zentra inverter for the past three years. Better go for a home UPS system rather than an inverter. Sukam is the brand that comes to mind immediately.
Old 5th February 2010, 23:05   #23
Ponmayilal's Avatar
Which inverter battery to buy for my APC 800 VA Home Inverter? Amaron Shield or Exide Inverter Plus ?
While I could find details about the Amaron Shield on the web (product catalog), I could not get even one bit of data on Exide Inverter Plus. The Exide web site is totally useless and what all I had read in the web was not in favour of Amaron Shield.
Fed up, I have finally decided to stop any further research and go for two Exide 100AH Inverter plus batteries blindly on faith and my fate .
Ponmayilal is offline   Reply With Quote
Old 6th February 2010, 07:07   #24
Gansan's Avatar
Thanked: 909 Times
I would suggest Amaron Shield. I am a satisfied customer!
Old 7th February 2010, 00:46   #25
khoj's Avatar
Thanked: 1,256 Times
Go for Xenon inverter with a Xenon battery. http://www.amararaja.co.in/batt.html
Both the inverter and the battery are manufactured by amaraja co. pvt. ltd. otherwise known for their Amaron batteries. The inverter is a true sine wave inverter that means no humming sounds and your hardware will not be subject to harmful square or quasi sine wave forms. Also if they say the inverer is a certain rating it actually is. As for the battery it is simply the Amaron shield but in a white case. Have been using this combo for the past two years, have not topped up the battery as yet. Your application minus the laser printer should be met by a 650VA inverter with a minimum 150AH rating single battery. This combo will be good for two hours on full load. If you are going to use the same inverter for your computer also I would recommend either a 180 AH battery or a 1400 VA inverter with two 160 AH batteries. Also invest in a trolley to safely keep the inverter and battery, looks neat too.
If the inverter system is going to be placed indoors do not buy a regular battery which needs topping up. The shield/xenon also requires top ups but release minimal lead fumes compared to a host of others. Remember Lead fumes are a silent killer and the effects will not show up in the short to medium term but long term damage can be devastating.
Regarding the laser printer. The smallest laser would need minimum 1KVA to operate and while there are inverters that can do this I do not think any one would want to spend that kind of money on an inverter. Print when regular supply is there or buy an inkjet if printer is desperately required even during power cuts.
Old 8th February 2010, 11:24   #26
panky12345's Avatar
Thanked: 147 Times
Am using EXide Sonic.. no issues so far!
Old 8th February 2010, 18:14   #27
anonymous's Avatar
Thanked: 15 Times
I bought Luminous inverter and Luminous battery in 2006. It worked like a charm until last month. I have now bought another Luminous tubular battery and its so far so good. I am happy customer and will any day Luminous over any other brand.
anonymous is offline   Reply With Quote
Old 8th February 2010, 18:29   #28
ElantraGT's Avatar
Guys, My APC UPS 800 VA battery went Kaput yesterday. I am in the market for a new battery now.
Gansan I saw your purchase of Amaron Shield 160 AH battery. I am more oriented towards Amaron as all my vehicles are running amaron for the past 5 years. What is the discharge rate C10/C20? Whats the no of backup hours this battery gives you?
ElantraGT is offline   Reply With Quote
Old 8th February 2010, 18:32   #29
Thanked: 196 Times
If want long battery life then invest in tubular battery , ordinary batteries will surely die in 2-3 yrs time.
We have a tubular battery unbranded one, its working perfectly well since last 4.5 years , daily the inverter works on an average 1-2 hrs.
I met a battery shop fellow he claims that locally made tubular battery can last up-to 7-10 years, the down side is that distilled water needs to be added to cells every quarter.
Amaron also makes pretty good batteries. From my experience, Amco battery is best avoided, Exide inverter batteries are also good, don't know about others
tj123 is offline   Reply With Quote
Old 8th February 2010, 18:52   #30
ElantraGT's Avatar
My Inverter is 2 years old and have Exide Inverter battery in them which went kaput. I am not confident on Exide inverter battery.
Inverter or generator? mrhap Gadgets, Computers & Software 740 25th April 2018 12:45
Car Battery to 220V AC convertor / inverter for charging laptop etc sreeku In-Car Entertainment 169 19th January 2018 15:42
Myth: UPS can't run on inverter? linuxtechie Gadgets, Computers & Software 17 24th October 2008 15:47
