Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more!
Thread Tools
Old 19th May 2008, 11:03   #1 (permalink)
ramie2400's Avatar
Default Need Urgent "HELP" on Hard-Disk
Hello,Bhpians I am looking out for a Samsung SV0802N 80GB IDE hard-disk as my Hard-Disk PCB is damaged,i was trying to remove the power-plug it was so tight,i applied a little pressure and "tick" a sound came and my heart was stopped i immediately checked but no response the powersupply is history,i showed it to a technician he said we need to get the same PCB as per model number,all my 5yrs 3D work is in the drive and i want to recover it,Please help me find a Hard-Disk equivalent to the same model number mentioned above,if some-one still uses it,would like to do a barter with me i'll get him a new higher capacity HDD please help me on this.
Ramie
__________________
"Whenever I find the key to success,..... someone changes the lock.
ramie2400 is online now   Reply With Quote
Old 19th May 2008, 11:17   #2 (permalink)
vinayvtec's Avatar
Cool
Ramie
hey dude, did you try connecting the HDD to a another comp and check whether you are able to access the data... few times it will allow you if not then only you need the same kind of HDD for recovering the data.. I will check if I can locate a Samsung SV0802N 80GB IDE hard-disk .
__________________
I live my life a quarter mile at a time. For those ten seconds or least I'm free nothing else matter
vinayvtec is offline   Reply With Quote
Old 19th May 2008, 13:30   #3 (permalink)
Dear ramie,
Try any professional data recovery services. Don't have contact details of any myself, but any computer vendor should be able to give you the same.
Since your data itself is safe, I'm sure they would be able to easily recover your data and 5 years of work.
__________________
A fine is a tax for doing wrong. A tax is a fine for doing fine.
anuragn is offline   Reply With Quote
Old 19th May 2008, 13:46   #4 (permalink)
ramie2400's Avatar
Yess matey ive checked in about 7 pc's till now,yess the problem is the power connector,there is a small hairline crack developed in the PCB and difficult to repair it,If i get the similar HDD it can be done easily,the problem is finding it as i had bought it in 2004,and IDEs have been replaced by Sata's now,so finding a similar HDD is a difficult task I had called up Samsung service even they dont have that HDD in stock.
__________________
Old 19th May 2008, 14:31   #5 (permalink)
aaggoswami's Avatar
Ramie
If its confirmed that the PCB is damaged, then do one thing, call someone from computermagazines. My friend reads chip and pcworld ( digit and computeractive are the other two ) and they have manay articles on how to recover data. This is my third HDD, but I had data backups.
You can buy anyone of the magazines and try to contact them. they might help.
Mean while I will now start searching for the tools.
__________________
EVENTUALLY FATE DECIDES EVERYTHING.
aaggoswami is offline   Reply With Quote
Old 19th May 2008, 14:49   #6 (permalink)
ashthedivx's Avatar
You are talking about the crack on which chip, a no. must be mentioned over the PCB chips.
Whom do you spoke in Samsung ??
Old 19th May 2008, 14:56   #7 (permalink)
ramie2400's Avatar
I think its the samsung call center people,I will try to get the Part/chip number and post it here when i reach home,I am sure there is no other problem than the power connector,bcz i pulled it soo hard that it might have got damaged seriously.
__________________
Old 19th May 2008, 15:05   #8 (permalink)
ashthedivx's Avatar
Good, Also try to post the picture of the logic card.
JFI: Samsung call center isn't looking into HDD and OMS services, it is for home appliances, IT products(apart from HDD and OMS) and audio-video products.
Old 19th May 2008, 15:12   #9 (permalink)
greenhorn's Avatar
getting the SV0802 will be hard since its an older 5400 Rpm model. most people have the newer 7200 SP0802N ...
__________________
2007 Indica DLG
My next Truck will be a Safari!
greenhorn is online now   Reply With Quote
Old 19th May 2008, 15:38   #10 (permalink)
ramie2400's Avatar
Yess its difficlt,I am having 2 x 80GB Seagate Similar model and 160GB samsung(currently using),i had bought this Samsung second hand and was working just fine until this stupidity of mine
I'll post pic of the same and the PCB also
__________________
Old 19th May 2008, 23:10   #11 (permalink)
GTO - Touring's Avatar
Ramie,
Please leave the recovering job to experts. The most reputable chaps for data recovery are Stellar. Do NOT tamper with the disk yourself. As someone in my office recently discovered, Stellar will not touch the damaged hard disk if anyone has already attempted to recover data from it.
Also, do get yourself a second drive for backups alongwith SecondCopy backup software.
GTO - Touring is offline   Reply With Quote
Old 19th May 2008, 23:32   #12 (permalink)
motorheadinc's Avatar
Ramie
I hope this is not against the rules. But you can definitely try on TechEnclave.
I am sure they will be of help. I am not a member myself but have seen a few people hooked onto this as we are to T-Bhp.
All the best for recovery of your data.
PS: try professionals like mentioned in previous post. I hope they will be of some help
__________________
The Identity awishcar.co.in
If there's not a car to satiate me, I will make one.......
motorheadinc is offline   Reply With Quote
Old 19th May 2008, 23:37   #13 (permalink)
danlalan's Avatar
Told you not to drink and dri...errrr work.
All the best with your recovery. i have an 80 gig at work... how can i help..??
__________________
2008 DRIVERS CHAMPIONSHIP - LEWIS HAMILTON
2008 CONSTRUCTORS C'SHIP - McLAREN MERCEDES
danlalan is offline   Reply With Quote
Old 20th May 2008, 00:01   #14 (permalink)
ramie2400's Avatar
hehehehehe the only problem was i wasnt drunk thats why it happened,if i would have been drunk,i would have never touched it to remove it lolz.. just check out the model number of the 80GB you have i need this model only to get it to work "Samsung SV0802N" .thanks man
__________________
Old 20th May 2008, 09:52   #15 (permalink)
ashthedivx's Avatar
Originally Posted by GTO - Touring View Post
Ramie,
Ramie is about to change the logic card and the said act doesn't counts into any kind of tamperment. Also, the logic card trick works very fine as far as your hdd platters and headers aren't damages, but yes if anyhow the warranty seal is blown (on the side) very few chances are there of data recovery.
Thread Tools
Michelin "Energy XM1+" or Goodyear "Assurance" lohithrao Tyre & Alloy wheel Section 26 21st August 2008 22:10
Finally !! - Long awaited "BEFORE" & "AFTER" pics of my Avenger 200 !! VSG12777 Motorbikes 23 16th June 2008 19:26
Looking for info on good "Resorts" or "Home stays" in Madikeri lohithrao Route / Travel Queries 2 14th September 2007 11:28
Audi RS5 "M3 beater?" to be launched early next year "PICS" highwayblaze The International Automotive Scene 9 18th May 2007 01:59
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458
