Old 16th June 2008, 18:58   #1
tsk1979's Avatar
Thanked: 16,422 Times
Default A 2 second UPS?
Our apartment building has generator backup.
So when power goes, the PC modems shuts down, and then after a couple of minutes generator starts, and the modem switches on and connects.
So far so good.
The problem is when power comes back.
they do a changeover during which the voltage drops for half a second before coming back. This hangs the modem.
Now if power went and came back, it wouldn't matter, but modem hanging means I have to turn it off and on,
Is there a cheap DIY way of making myself a UPS which gives around 2 second backup.
Easily availability of parts for this DIY is important.
If I put a cheap 10 mF capacitor in series, will it do? I am gravitating towards the capacitor solution. I will connect the DC output of the adaptor to capacitor, so it will charge. Then when power dips it will cushion against the inverted spike.
Old 16th June 2008, 19:03   #2
merve_extreme's Avatar
Thanked: 12 Times
I assume you are talking about the Dlink Modem,It uses an AC-AC adapter and resets even on UPS switchover.
merve_extreme is offline   Reply With Quote
Old 16th June 2008, 19:16   #3
tsk1979's Avatar
Nope, its not dlink and it has AC-DC adaptor. Its a Beetel ADSL modem
Old 16th June 2008, 19:24   #4
condor's Avatar
Thanked: 4,907 Times
Suggest pick up a small capacity UPS - will be a clean install & use.
Old 16th June 2008, 19:32   #5
tsk1979's Avatar
Can I get a 200W UPS somewhere?
I would like to power my laptop and modem with that.
Old 16th June 2008, 19:33   #6
Thanked: 294 Times
A cap will be a cheap and good try. But put a bigger value. It will restore some energy when there is a dip. Atlest 1000-2000 mF.
Old 16th June 2008, 19:34   #7
Thanked: 253 Times
Wouldn't 10 mF be too little? What's the DC supply for the modem? What's the mA rating on the adapter?
Old 16th June 2008, 20:08   #8
greenhorn's Avatar
Thanked: 1,519 Times
isnt the cap supposed to be in parallel?
Old 16th June 2008, 20:16   #9
Thanked: 253 Times
Of course you're right!
Everybody seems to have missed the fact that tsk has written 'series'!
Old 16th June 2008, 21:09   #10
Thanked: 294 Times
I think he is using as a filter but DC will not pass.
Old 16th June 2008, 21:12   #11
Thanked: 253 Times
As a filter for what?
He's clearly said he wants to 'augment' the DC storage!
Old 17th June 2008, 00:03   #12
Thanked: 294 Times
To clean the spikes in the DC out put of the ac-dc converter
Old 17th June 2008, 00:07   #13
phamilyman's Avatar
Thanked: 3,526 Times
boss,
dekho before you try a cap soln, please visit nehru place. you will get junta selling old UPSes for 250-400 bucks (seen it meself).
These ones are typically with a gone case battery that only last a few seconds.
but from what you say - few >> 2.
QED
Old 17th June 2008, 00:18   #14
Vid6639's Avatar
Thanked: 21,086 Times
L_B_M paaji, 1000mf? or uF? 1000mF = 1F which is a huge cap value.
If you can spend like 1000 odd bucks you should get a wipro or a proview one.
Old 17th June 2008, 00:53   #15
DerAlte's Avatar
Thanked: 2,879 Times
I had the same problem years back with a Sony cordless phone! I had used a 10000uF capacitor, but even that was not a fool-proof solution.
It is better that you use a small UPS, especially like what @phamilyman described. The electronics part of the UPS doesn't cost much, the battery is the killer - you can get a new UPS for the retail cost of a battery.
I have a 1992 vintage 0.5KVA UPS that powers my modem & LAN switch at home - had replaced the batteries a while back. Must check the backup time with the current load some time.
APC UPS: Good Service EDIT: Now a bad service experience added as well bblost Gadgets, Computers & Software 52 14th March 2014 17:31
What is wrong with my UPS? kkdelhi Gadgets, Computers & Software 6 28th February 2008 16:12
Maruti Suzuki ups car prices windsurfer The Indian Car Scene 2 4th February 2008 18:16
pics: so more follow ups gemballa Super-Cars & Imports in India 1 4th October 2005 20:56
Formula 1 line ups for 2006 ?? Badcheetah Int'l Motorsport 32 3rd October 2005 18:04
