Closed Thread
Old 17th June 2008, 14:24   #1
snaronikar's Avatar
Thanked: 23 Times
Question Transfer of Phone book from CDMA hand set to normal handset.
@ Mods: I was not able to get the response on the normal mobile phone thread. Hence I have created a new thread. Request you to keep this open till I receive the response.
Thanks.
I will be changing from CDMA to GSM in the coming month. My CDMA has the reliance connection. The handset is Nokia 6370.
The GSM handset is Nokia 6670 for which I will be starting to use from July-08. It does not have IR facility.
Now, I have over 300+ phone nos. Can I transfer all the phone nos from my existing CDMA handset to GSM handset. Pls advice..
snaronikar is offline
Old 17th June 2008, 15:08   #2
What is your CDMA handset? Does it have a cable that can sync it up with a PC? If yes, you can take a backup of your contacts in the laptop and then transfer these to the new phone. Does your new phone also come with a data cable?
In my case, to transfer contacts from a Motorola Razr V3c (CDMA) to a Motorola Q8 (GSM), I took a backup of the contacts into my laptop using the data cable (supplied with the Razr). One has the option of saving the contacts as Outlook contacts or Lotus Notes contacts. I chose Outlook contacts and then the Active Sync on the Q8 picked up the Outlook contacts automatically.
hrag is offline
Old 18th June 2008, 09:23   #3
Nokia 6370 doesn't have bluetooth but it does have data cable Pop-port. So you should be able to sync you contacts to PC-Suite / Outlook using correct drivers.
Post that it is pretty straight forward importing the contact from Outlook. Here is the link to download PC Suite & Content Copier for Nokia 6370.
https://www.nokiausa.com/A4410374
Originally Posted by snaronikar View Post
My CDMA handset is Nokia 6370.
given2fly is offline
Closed Thread
Need help with economics book and Baron's GMAT/GRE English book Nikhilb2008 Shifting gears 2 30th June 2008 11:05
Buying car without a blue book(RC Book). Safe? vrooooooom The Indian Car Scene 19 7th May 2008 17:25
Which Mobile Handset do You Use ? esteem_lover Gadgets, Computers & Software 11 28th March 2007 10:49
