Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more
Thread Tools
Old 29th June 2008, 11:07   #16 (permalink)
akshay1234's Avatar
Infractions: 0/1 (4)
Originally Posted by barcode View Post
I have an Airtel 512kbps... Get download speads of 100kbps easily!
how? that means you have an 800kbps connection?
akshay1234 is online now   Reply With Quote
Old 29th June 2008, 20:12   #17 (permalink)
something very wrong here.
If he has a 512kbps connection , why is it not possible that he should get at least 100kbps ?
Sandeep_K_Ram is offline   Reply With Quote
Old 30th June 2008, 10:13   #18 (permalink)
Rehaan's Avatar
Two reasons:
1. There is a difference between kbps (kilobits/sec) and kBps (kiloBytes/sec)
2. The "512" is the minimum guaranteed speed between your computer and the ISP - the ceiling is 1Mbps or 2Mbps etc depending on the connection.
cya
R
ps - also akshay1234, in the internet world 1 byte ends up equating to 10bits, not 8 (due to 2bits for error checking)
__________________
The memory of you will ride by our side forever.
Old 30th June 2008, 11:00   #19 (permalink)
tsk1979's Avatar
Nope 512 is the maximum
The plans say (Speeds upto 512Kbps).
We get 100KBps etc., because sometimes Airtel for no apparent reason starts to give 2x speed at night.
Many times even in day you can get double speed for no apparent reason
__________________
Reclaimed, wrung dry and recycled....!
Old 30th June 2008, 22:11   #20 (permalink)
chetan's Avatar
tsk you are absolutely right , i have a 256kbps unlimited plan sometimes i dont know what goes into it the speed that i get during night times are unbelievable ... so i think 512 kbps users must be getting 100kbps DL speed
btw this rail wire is too good to be true !!
__________________
AS LONG AS YOU DONT SEE THE CORNER THROUGH YOUR REAR WINDOW YOU ARE IN CONTROL!!!!
chetan is offline   Reply With Quote
Old 30th June 2008, 22:45   #21 (permalink)
What I get in Airtel is:
256kbps which translate to 20~25kBps
now:
512kbps which translate to 40~50kBps
HappyWheels is offline   Reply With Quote
Old 1st July 2008, 13:43   #22 (permalink)
navin's Avatar
Railtel reminds me of the Southern Pacific Railroad Integrated Network story (young guns call it Sprint).
__________________
Scixelsyd Etinu
Old 1st July 2008, 16:26   #23 (permalink)
Two reasons:
cya
R
I am aware of the difference between kbps and kBps. Almost all ISPs quote in kbps which is kilo bits per sec.
So if the guy who post that he has got a 512kbps plan says he gets 100kbps speed ... there is absolutely nothing wrong or surprising about it ! IS there ? As per his plan the max speed he can get is 512kbps and he is getting 100kbps which is actually pretty low.
512kbps = 64kBps
100kbps =12.5kBps
Whichever unit you are using , the speed he is getting is quite low compared to the speed he is "supposed" to get as per his plan.
well 512kbps users are supposed to get at least 300-400kbps !! 100kbps is very low ...
If you are using a Home 500 dataone plan , you are supposed to get upto 2Mbps and if you see the speed using something like a NetMeter you can see it that it will be between 1.3-1.8Mbps most of the time.
Nobody will give you more speed than they advertise though its common that you always get lesser speed than they say.
now:
That is spot on . I think there is some confusion here between kbps and kBps among a few users.
1Byte = 8bits i.e 1B=8b.
So if you get 32 kilo bits per sec its actually only 4 kilo Bytes per sec.
So the max speed you can get on
1. 512kbps is 64kBps
2. 256kbps is 32kBps and so on ...
to get speed in kBps you only divide the kbps by 8.
I know about the error control coding somebody was mentioning - the start and stop bits used in a frame of bits but that is only control info. The speed mentioned is the overall data transfer bitspeed so when they say 1byte it still is 8 bits - the control info is meant for the protocols in place ...so its not that you have to divide the speed by 10 instead of 8.
Old 1st July 2008, 17:43   #24 (permalink)
tsk1979's Avatar
ISP data transfer measures the entire packet, not just data.
My RAW Data transfer is usually 75KBps, or 600kbps.
If I just count the "data" bits I get around 65-68KBps all the time.
This transfer includes upstream and downstream both.
If I setup a tunnel, and try to measure data throughput, I get around 480-500kbps(Data transfer rate).
From normal sites during download, I get an Mb down every 2.5 seconds or so.
So a 3MB-4MB file comes down in a minute.
Right now there is no Bittorrent throttling on Airtel
This railtel thing sounds great if they do not implement any "traffic shaping".
__________________
Old 1st July 2008, 17:56   #25 (permalink)
DerAlte's Avatar
Let me add to the confusion: All ISPs (wired, wireless, cable, et al) quote connection rates, not something suitable for calculating effective Byte throughput rates. So if you really want to compute bps to Bps, the denominator has to be 11 (not 8) x (1:n factor) x (buffering to get the consumer to the rate plan throughput). And this on top of (traffic conditions at the intermediate points) and line noise, where only God can help you.
On my BSNL ADSL connection at home, I get a 512/2048 Up/Down connection, but the effective throughput is the equivalent of 256Kbps promised in the rate plan. God bless BSNL, at least they are trying to be honest. I pity the cable consumers, they get the least price-performance unless they are the only house in a new colony.
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
Old 4th July 2008, 06:05   #26 (permalink)
ph03n!x's Avatar
Here is what I got from them:
Warm Greetings from RailWire!
This is with regards to your recent online enquiry with RailWire (appended below).
We are glad to receive your enquiry.
Chennai will come under our pan-India rollout plans. From the customer support team we, at present don’t have good visibility into the exact dates/timelines. However, you could expect us to reach chennai by end of this year or early next year.
With warm regards,
Team - RailWire Operations
eMail: connect@railwire.in | Tel: 91 80 4060 88 99 | URL: Railwire - Home
SMS: RAILWIRE(space)<Your Location> to 5 67 67 75
RailWire is an initiative of RailTel Corporation of India Ltd., Ministry of Railways, Govt. of India
So end of this year, huh??! And I am pleasantly surprised to even receive a response, that too within 6 hours of me posting in their website!!
ph03n!x is online now   Reply With Quote
Old 21st July 2009, 17:54   #27 (permalink)
SkyWalker's Avatar
This thread seems to have run a natural death. Anyone using railwire or have any feedback? Now its available @ our apartment, and frankly 1220/- for 2 Mbps unlimited is too good a deal. I want to check out how the user experience is.
__________________
“The Force is strong with you. A powerful Sith you will become."
SkyWalker is offline   Reply With Quote
Old 21st July 2009, 21:49   #28 (permalink)
menonrajesh's Avatar
Just saw this thread and realised that its almost 1 yr old one!
While the offer sounds amazing, still wondering why there are no user responses so far? I can see that railwire website is up and running, but never heard of it in the media so far. Any user reviews here??
menonrajesh is offline   Reply With Quote
Old 22nd July 2009, 12:48   #29 (permalink)
gd1418's Avatar
After reading about Railways internet scheme, I posted my query on their website yesterday at 16:55. Surprise, surprise, at 17:54, I got a response from them; that too a total Government, Babu infested organisation.. I'm in a state of shock..
Dear Mr. Gurudutt,
This is w.r.t.your recent online enquiry with RailWire (appended below).
Gurgaon will come under our pan-India rollout plans. From the customer care desk, we don’t have good visibility into the exact dates/timelines. However, you could expect us to reach gurgaon towards the latter half of year 09.
With warm regards,
eMail: connect@railwire.in | Tel: +91 80 67 89 88 99 | URL: Railwire - Home
SMS: RAILWIRE(space) to 5 67 67 75
----- Original Message -----
To: connect@railwire.in
Sent: Tuesday, July 21, 2009 4:55:11 PM GMT +05:30 Chennai, Kolkata, Mumbai, New Delhi
Subject: Railwire: Apply Online
Apply Online
Name:: B C Gurudutt
Phone:
Email:
Address 1:
Address 2:
City/Town/Village: Gurgaon
Pin Code: 122002
State: Haryana
Speed **: 1 Mbps
__________________
Royal Enfield Bullet 1962
All Black 1998 Safari 4x4
All Black 2004 Scorpio GLx
Old 22nd July 2009, 12:59   #30 (permalink)
anujmishra's Avatar
One of my neighbor was using Railwire connection in his earlier residence. I stay in Whitefield but for my road they still not laid down cable.
His feedback was good but not excellent because he sometimes experience longer hours down time. It seems their customer support executives also that ramp up like Airtel.
Till now I am on Airtel and waiting for them to lay down cable in my locality of Whitefield. We all owners planning to Shift to Railwire once they are available.
__________________
Seat belts are not as confining as wheelchairs...
anujmishra is offline   Reply With Quote
Thread Tools
Toyota future plans for India. avishar The Indian Car Scene 2 12th June 2009 23:18
India Broadband Review aseem Shifting gears 12 27th June 2006 15:52
Toyota's plans for India amit The Indian Car Scene 4 18th March 2006 18:12
Any plans for Swift 1.5L in India? mxx The Indian Car Scene 8 14th March 2006 11:39
Nissan plans for india hell_rider The Indian Car Scene 34 15th July 2005 11:24
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
