Old 6th July 2008, 12:56   #31
Thanked: 245 Times
The CRUX of ripping and encoding.
With a DL DVD-DVD copy using DVD Decrypter should not be a problem.
But if you want to compress or divide the DVD into 2 DVD's (still cheaper than DL cost) use Ripit4me 1.7.1.0 (which inturn uses DVD Decrypter at the backend) to remove the ArccOS protection.
If you want to retain better quality than use DVD rebuilder with HCenc.
DVD Shrink is a transcoder whereas DVD rebuilder is a reencoder.
Finally use Imgburn (from the author of DVD decrypter) to burn you SL/DL DVD's.
Nothing can beat these combinations(all freeware).
Originally Posted by deepakvrao View Post
If I use shrink I can leave out the extras and I 'reauther' the DVDs to contain only the main title. That way if I put it on a single layer DVD I get less compression and better quality. However if sometimes I use DL blank DVDs then I dont shrink the DVDs.
With direct DVD to DVD, if you use single layer then the compression is from 8.5GB to 4.5GB
Old 6th July 2008, 14:50   #32
Thanks Dadu - all very valid points and I will download these ASAP. OTOH all this does not address the issue where it all works on one laptop but not on the other. Has to be a hardware issue then?
Thanks for the advise anyway.
Whats the difference between a transcoder and a reencoder?
deepakvrao is offline   Reply With Quote
Old 7th July 2008, 15:31   #33
Dell delivered new DVD drive this morning. All in all fantastice service. Complaint on Fri 4pm, acknowledgment on Sat 10am and new drive in my office on Mon 10am.
Seems to be fine on the first DVD that I tried.
Old 7th July 2008, 18:17   #34
vinayvtec's Avatar
Thanked: 9 Times
Cool
Don't forget to retrun the defected unit in the same box or a good box with in 8 business days.
vinayvtec is offline   Reply With Quote
Old 7th July 2008, 22:32   #35
I was told that they will send a guy to pick it up in a few days?
Old 8th July 2008, 01:11   #36
vinayvtec's Avatar
Thanked: 9 Times
Cool
Thats good, I think a person from DHL would be coming... lets wait and see..
Old 8th July 2008, 11:48   #37
Thanked: 245 Times
A video consists of I-frame(Intra Frame), P-frame(Predictive Inter Frame), B-frame(Bi-Predictive Inter Frame). Intra is the key frame.
A transcoder like DVD Shrink is a software/ device which just evaluates the video and takes away some frames from it in order to fit the defined size.i.e. the compression used is comprimising on the quality by removing the frames.
A reencoder is a software/ device in which the source is read and encoded again to the best quality possible to fit the defined size.
ofcourse if you compress you loose bits, but the way you loose matters for the quality.
Old 9th July 2008, 20:26   #38
Thanks Dadu - that was very informative. Any idea whether DVD Fab is a transcoder or reencoder?
External DVD writer - suggestions? benbsb29 Gadgets, Computers & Software 4 6th July 2009 10:37
External DVD-Writer bharanidharang Gadgets, Computers & Software 5 9th April 2007 14:21
Service centre required for LG CD-player/writer cum DVD player benbsb29 Gadgets, Computers & Software 0 18th January 2007 11:58
DVD Writer N Hard disc lancer_mania Gadgets, Computers & Software 47 6th February 2006 01:01
