Old 27th December 2008, 20:19   #31
If you buy a PCI WIFI card for your PC, you dont even need the WIFI modem. You can share files directly by setting up a wireless network.
rajhiremath is offline   Reply With Quote
Old 27th December 2008, 21:07   #32
hemanthisgreat's Avatar
UPDATE: I am able to wirelessly network the laptop and desktop without using the wifi card on the desktop. Here is the list of hardware I have.
1) A xp desktop, which does not have wireless capability and is connected to the huawei wa1003a wireless modem by a lan cable.
2) Huawei wa1003a modem. which has wireless capability.
3) A vista laptop with wireless capability and connected to the modem wirelessly.
Here is the answer I got on an other forum and its working albeit a few glitches.
1)First run your desktop xp.
2)Go to network setup wizard. Select "other" option. Then select "This computer connects directly/ through a hub (1st option)". Give computer description and name. Give workgroup name. Turn on file and printer sharing. Finish the setup. Reboot pc. Then manually select what folders/drives you want to be visible on your laptop.
3)Now Run Vista laptop. Go to network settings and turn on home networking and file and printer sharing.
4) Now go to my network places and your desktop should be visible there.
The problem I am facing now is, This problem existed even when I networked the laptop and desktop using a cross cable.
From the laptop, i am not able to open the desktop, it says access denied. The same error was encountered when i networked the desktop and laptop using a cross cable. I have shared the folders manually and also chosen the share files and printer option, but still not able to open the desktop. Whereas, i am able to access the vista laptop from the xp desktop. Please guide me in this regard.
hemanthisgreat is offline   Reply With Quote
Old 28th December 2008, 18:01   #33
Try this on your laptop. Go to Start->Run-> \\192.168.1.x(the ip address of the PC). This should work without running the network setup wizard to create a home network.
Also check whether the Windows firewall is enabled on your PC. If it is then you may have to disable it.
The DATA Card and USB Modem discussion thread (Reliance/Airtel/Tata) sk456 Gadgets, Computers & Software 720 11th December 2015 09:00
BSNL Automated Modem Firmware Uploader and Self Care Installer wildon Gadgets, Computers & Software 3 6th February 2010 21:54
Superbike Security Systems - Disc Lock / Chain Lock / Alarm Systems gsferrari Superbikes & Imports 3 3rd July 2009 01:45
Anyone tried connecting both USB and ethernet interface to Beetel 220 modem ? joecherian Gadgets, Computers & Software 6 14th August 2008 19:40
Found a Tata Indicom USB Modem. How do I use it? Dippy Gadgets, Computers & Software 21 7th December 2007 11:38
