| Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more! |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Mar 2006 Location: Bangalore
| Hi I am facing a problem in connecting my laptop to internet. But before I proceed, please be informed that I am a complete alien to the way computers work. So please be simple and detailed in your response. I have a BSLN broadband connection and it was working fine till last week. Now, whenever I switch on the modem (Type1 – LAN cable to the laptop), the local area connection status shows the message – “Connected” but with “Limited access/connection”. With this I am unable to access internet. Ps: I did perform a status check of the modem driver or something – Broadcom xxxxxxxxxxxxxxx . The connection speed which recently started showing connected at 10 Mbps went back to connected at 100Mbps. If the check the status: - All the 4 led’s on the modem glow - The message shows connected at 100MBPS but I am not able to access internet - There is no IP assigned to the machine - Not able to ping 192.168.1.1 I have even assigned IP manually to the machine with all the details – Subnet mask, Gateway, DNS server, etc. With this, the connections status shows connected and the error message “Limited access/connection” does not appear anymore. However I am still not able to access internet. Then I tried this. I connected the modem to a wireless router and used the wireless connection to access internet and it worked. It is able to assign IP automatically. Can anyone help me here? I have been trying various things but am not able to solve it. I am one step short of calling a hardware engineer for this issue. (Before you ask why don’t I continue using the wireless setup – I just need to figure out what has gone wrong and rectify the problem) |
| | #2 (permalink) |
| Senior - BHPian | Try resetting the modem. Ask your isp for DNS Server and it solves the problem most of the times.
__________________ VTEC NHC AND RED SKODA OCTAVIA vRs (LAAL PARI) WHY IS EVERYTHING ELSE SO SLOW !!! --------------------------- -=]|Do The Dew|[=- |
| | #3 (permalink) |
| BHPian Join Date: Jan 2007 Location: Shillong
| Assign the IP address 192.168.1.2 to your computer. Subnet 255.255.255.0. Gateway 192.168.1.1. For DNS use 208.67.222.222 & 208.67.220.220. Try if internet works. If it does not, assign the ip 192.168.0.2. Subnet 255.255.255.0 & Gateway 192.168.0.1, Same DNS as before. Try and see if it works. Else you need to go the engineer way. |
| | #4 (permalink) | ||
| Quote:
The connection check status is as below. Does it make sense. Is it a problem with the modem? Is it a problem with the port on the computer where the network cable is connected? Connection test passed Test details This connection is configured to use a static IP address. Ping Gateway 192.168.0.1 : Failed Ping DNS 208.67.222.222 : Failed Ping DNS 208.67.220.220 : Failed No WINS server is available for this connection Hardware Test EEPROM Test : Passed FIFO Test : Passed Register Test : Passed Interrupt Test : Passed Loopback Test(s) : Failed Last edited by RAC : 13th August 2008 at 22:59. | ||
| | #7 (permalink) |
| BHPian Join Date: Apr 2007 Location: Hyderabad
| How did you use to connect earlier? with router or without the router? what is the make and model of the Modem? how do you connect normally ? you start the laptop and you are connected to the internet or do you click on any icon and click connect then use the internet? Try the below steps:
1)Start --> Run-> type CMD and press enter 2)In the dos Prompt type ipconfig /flushdns enter 3)type ipconfig /registerdns enter 4)type netsh int ip reset resetlog.txt enter 5)type netsh int ip reset resetlog.txt enter again 6)type netsh int ip reset resetlog.txt enter again Restart the computer it , hope for the best ![]()
__________________ Romyeo-->The URBAN NOMAD |
| | #8 (permalink) |
| BHPian Join Date: Jun 2008 Location: Madras
| You have said that when the modem is connected to a router, Internet works - did you configure anything in this router (or was it configured earlier for this modem)? You need to know your BSNL username and password and VCI / VPI settings (can be obtained from BSNL) before you reset the modem - but if the same modem works with a router with no changes being made on the modem, then the problem is not with the modem. I would suggest you first try Romyeo's steps given above and tell us what happens. |
| | #9 (permalink) |
| BHPian Join Date: Mar 2007 Location: Bangalore
| I think you need to assign laptop ip address as 192.168.1.100 or above. I think there is a setup in modem where you define your computer IP addresses and the BSNL folks set it up as 192.168.1.100 to 192.168.1.155. try this and if this doesn't work then call the engineer.
__________________ If you have not failed you have not tried enough. Swift Diesel VDI - Feb '07 onwards Santro LS- Mar '01-Feb '07(59000 KM) Sold. |
| | #10 (permalink) |
| Whether he configured the router or not will only be of concern if he is able to ping the router. In this case, the router/modem is not pingable. What is the model and make of your router? Have you tried resetting the router? If you have not, try resetting the router and then try with the ips I provided above. If you can ping, we can proceed further. |
| | #11 (permalink) |
| Senior - BHPian | Fella's here's the situation : PC running a hathway cable connection does not load specific sites - Gmail, hotmail, Yahoo mail. The primary page loads etc and once login details are provided it just stalls. Same thing happens with Google search. Portal loads but after feeding in the query it starts searching and stalls. Initially thought it was the ISP (hathway cable sucks, its as good as not having a connection.) But when we plugged in a laptop we found the sites loading. Other diagnosis : The system also recently began using NOD32 as the AV. Not sure if the problem started after that but I uninstalled that but still no luck. What could be the issue? Could there be some worm/trojan perhaps trying to hijack ? I would have loved to pin this on hathway because honestly their service is just not worth it. Its lack of other broadband ISP's in the area which has resulted in them being the chosen one. ![]()
__________________ "Its not the size, its the heart, so dont hate... Accelerate !!!" |
| | #12 (permalink) |
| Senior - BHPian Join Date: May 2007 Location: Vadodara
| @RAC. I had BSNL connection for a short period of time. I had type 4 router. From your case ( thread starter ), mostly its the Router that is the problem. Also there is confusion wheather you are using Router or Modem or both. I will consider that you are using type 1 router bought from BSNL or you have router on rent from BSNL. In your laptop's lancard, assing IP as 192.168.0.5. Subnet mask, we all know. in Default Gateway 192.168.1.1 and in Preferred DNS Server enter 192.168.1.1. Leave the Alternate DNS server untouched. This should start the internet. If it doesnt, then most probably there is some problem in your router. I would like to suggest something more about putting the username and password in router itself. Read the documentation supplied from BSNL ( if at all they have supplied ) or else get the manual of your router from net ( may be ask you friend who has net connection ). Generally you will get a pdf format manual from internet. Read it and enter you BSNL username and password in the router itself. This will make sure that the OS or the connection making procedure of OS is not making any problem. Whenever you want to do net, just switch on your router. @s0uljah: If the sites are loading on laptop and not on desktop, then there is something wrong in desktop and not internet connection. Some times the present day antivirus and internet security block a few sites. Here, you just need to make changes in the way antivirus/internet security works. Generally by unchecking or checking a few boxes in the settings/options tab will do the job. If still this continues, then its viruses that are giving trouble.
__________________ EVENTUALLY FATE DECIDES EVERYTHING. |
| Thread Tools | |
Similar Threads | ||||
| Sharing an Internet Connection in a network | Sahil | Shifting gears | 20 | 31st January 2008 16:36 |
| Internet connection help in pune | fb1 | Shifting gears | 7 | 8th January 2008 10:29 |
| Which internet connection u got??? | barbar | Gadgets, Computers & Software | 64 | 21st July 2006 00:50 |
| new internet connection | dadudeonfire | Shifting gears | 21 | 16th October 2005 01:52 |
| How fast is your internet connection? | dan400 | Shifting gears | 1 | 12th August 2004 18:16 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481
