Old 13th August 2008, 09:08   #1
joecherian's Avatar
Thanked: 78 Times
Default Anyone tried connecting both USB and ethernet interface to Beetel 220 modem ?
Hi Techians, Has anyone attempted to connect both the USB and ethernet interfaces on the Beetel 220 modem for accessing internet ? this way, you can connect 2 PCs without going for a router.
joecherian is offline   Reply With Quote
Old 13th August 2008, 18:20   #2
quicksilvr's Avatar
Yes, you can.
If I remember right, you just need to fiddle around with the DHCP to assign the IPs.
But I guess this is seriously OT though.
quicksilvr is offline   Reply With Quote
Old 13th August 2008, 22:40   #3
Thanked: 660 Times
dude post in shifting gears! Techincal stuff as in 'Auto stuff' and not your computer problems.
Old 13th August 2008, 22:45   #4
Thanked: 146 Times
I have a Beetel 220BXI modem. The ethernet cable is connected to the desktop and the USB is used to connect to my laptop. No change in anything. Just plugged and browsed. :-)
Now I have got a long term loaner on a wireless BSNL modem - need to figure how to set that guy up...
HappyWheels is offline   Reply With Quote
Old 14th August 2008, 00:41   #5
Path_Finder's Avatar
I had it before getting wireless - it works - just need to connect!
Path_Finder is offline   Reply With Quote
Old 14th August 2008, 10:05   #6
Zenster's Avatar
Thanked: 94 Times
Default @joecherian
@joecherian: I agree this is the wrong section but here is the answer.
Yes you can do what you are trying to. I also had the same issue a couple of days ago when me and my wife both needed to login to the office networks at the same time using our lappies.
All you need is the USB modem driver's disc and to make you access safer you can get a static IP assigned to your system from TCP properties and enter the prefered DNS Server as given by your service provider.
Once you have all this, enter the network setting like IP and DNS in the Network Properties->TCP Properties and then check the LAN connection. Then the USB conenction will need the driver to be installed. So connect the USB cable and then install the drivers using the disc and you are done. The same TCP settings will hold good for both USB and LAN.
Hope this helps cheers:.
Zenster is offline   Reply With Quote
Old 14th August 2008, 19:40   #7
Thanked: 660 Times
Now for the answer, Yes you can. Just configure it as PPPoE and not bridging.
That way ADSL will connect on its own and each PC will be assigned IP by DHCP running on ADSL modem.
The DATA Card and USB Modem discussion thread (Reliance/Airtel/Tata) sk456 Gadgets, Computers & Software 720 11th December 2015 09:00
Grande Punto : USB Interface / Auxiullary Interface / IPod Interface wind_rider In-Car Entertainment 1 4th March 2010 16:43
Choice Between E-220 or E-250 D both 1996 ! stone_monkey Luxury, Imports & Niche 16 15th February 2010 11:48
Connecting BSNL Modem to two systems! Is it possible? ramki067 Gadgets, Computers & Software 32 28th December 2008 18:01
Found a Tata Indicom USB Modem. How do I use it? Dippy Gadgets, Computers & Software 21 7th December 2007 11:38
