Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more
Thread Tools
Old 23rd February 2009, 18:25   #151 (permalink)
hydrashok's Avatar
@redrage, yep, it is worth a try. If you've backed up the important stuff, there is nothing to worry. The worst that can happen is that after you hard-reset the phone and reload the data and settings and apps it will behave the same as it does now.
Maybe you can hold off installing third-party apps that are non-essential for a few days after hard-resetting the phone. That way you can rule out any clash between the new FW and the 3rd-party app/s.
__________________
Alpine 9887 | TRU Tech STEEL S44 & S500 | Image Dynamics XS65 & CTX6 | Image Dynamics IDQ12 D2V2 | Connection Audison
Old 23rd February 2009, 21:55   #152 (permalink)
redrage's Avatar
Any particular code i need to type for the hard reset? or its just goto settings and reset it ? (Sorry for the dumb question but never have done a reset before)
__________________
2003 Hero Honda Karizma
2003 Suzuki Esteem Vxi
redrage is offline   Reply With Quote
Old 23rd February 2009, 22:14   #153 (permalink)
SirAlec's Avatar
normally nokia's default security code is 12345.
__________________
Still! Living Life a quarter mile at a time.....post being Dad.
Old 24th February 2009, 10:06   #154 (permalink)
hydrashok's Avatar
Originally Posted by redrage View Post
Any particular code i need to type for the hard reset? or its just goto settings and reset it ?...
Whoops, just saw this now. Guess the night was wasted huh?
You have to type in *#7370# (star hash seven three seven zero hash) while in the 'desktop' (standby screen) to hard reset the phone. The phone might ask you for the security code, before it does the hard reset. If it does, type 12345 (I'll assume you haven't changed the default security code).
The hard reset will wipe all data and leave the phone with just the default software (just as it was, immediately after you updated the FW).
EDIT: Very important -- before you do a hard reset, make sure the battery is 100% full.
__________________
Old 24th February 2009, 12:31   #155 (permalink)
redrage's Avatar
Thanks for the info Hydra, I can restore my messages, contacts, notes, bookmarks right after i do the reset?? Only thing i wont be restoring is the settings...
__________________
Old 24th February 2009, 13:21   #156 (permalink)
Default Alas ... me too in the same boat...
Originally Posted by viper View Post
Guys,
I had done the same to my phone and realized it was the biggest mistake I made. There are some very severe glitches in this upgrade. My phone started hanging, shutting down on its own and the worst of all was I could not restore backup to my phone even though it was taken via PC Suite.
The Nokia service centre confirmed there was a issue with the upgrade firmware.
Viper
Viper buddy,
wish you had posted this a day earlier and i would not be in the same boat as you
i downloaded the new firmwarre and now guess what...
the phone hangs when i start the Maps application and then it cannot be shut off except go back and remove the battery
tried it umpteen times.. doesnt help
Any fixes ???
the other features work well though....
Appreciate any help here...
Ram
__________________
Ram
Innova G4 @ 2008 - BF - 5050
Santro @ 2002 - MA -7777
pinnacle is offline   Reply With Quote
Old 24th February 2009, 14:12   #157 (permalink)
Originally Posted by pinnacle View Post
Viper buddy,
Any fixes ???
Ram
I read reviews on the net about similar problems happening with the firmware upgrade on E51 also. Can users confirm?
__________________
This is your life and it's ending one minute at a time.
nishantgandhi is online now   Reply With Quote
Old 24th February 2009, 20:46   #158 (permalink)
gendarmee's Avatar
The phone hangs when i start the Maps application and then it cannot be shut off except go back and remove the battery tried it umpteen times.
Similar thing happened with my phone after the upgrade. ( But, right after the upgrade i wasn't sure of whether the latest map would be loaded so i d/led and drag-drop installed the version of Nokia maps.)
The first time i opened maps, after that and okayed go online now(on start-up), the phone hung. I turned it off and on with the power button. (first crash)
Next time i opened maps i clicked no for go online now(on start-up), maps works fine.
3 days later i took a chance hit yes to go online now(on start-up), and to my surprise it didnt hang and worked w/o a hitch.
Other than that, only voice dialing causes a restart at times.
OT- how do u remove the battery? I find it tough to remove w/o using an object as a lever.
gendarmee is online now   Reply With Quote
Old 24th February 2009, 20:53   #159 (permalink)
Do you difficulty removin the back cover or the battery itself ?
The side locks to remove the cover is fairly simple..
As for the battery removal, the location above the SIM card has a slot where u simply insert a finger and lift the batt with your nail...
i tried using the options u suggested for the maps, but no use
it still hangs
is there no way i can go to the old firmware ?
Ram
__________________
Ram
Old 24th February 2009, 21:57   #160 (permalink)
gendarmee's Avatar
I didnt suggest anything, i just mentioned my experience.
For removing the battery, not the battery cover.
My phones battey is stuck with a vice like grip, need to use a metal object to remove it. using the nail is no good.
Do you have any 3rd party s/w on it?
Old 24th February 2009, 22:34   #161 (permalink)
redrage's Avatar
New firmware not working guys, i tried everythin include hard reset, removed all third party too, still when the phone restarts it shows installing something. Then says untrusted data on memory card.... My Mail Notifications also are just not showing up. I would like to comment that the Micro SD card provided by Nokia is utter crap... Just keeps flashing or getting reset now and then deleting all my messages. I am planning on putting a new card.
Cursing myself going for a symbian phone. My 6600 was like this followed by my N70 which was the crappiest of the lot. Now an E-Series. Guess i gotta look for an alternative.
__________________
Old 25th February 2009, 10:48   #162 (permalink)
IMP
How old is your sim card? That is the sim menu being installed on your phone, e.g. my phone has the Airtel Live! icon added, this icon is the sim menu. Try with another sim card, one which was bought recently. Many times its the sim that is faulty, it happened to me once.
IMP is offline   Reply With Quote
Old 25th February 2009, 12:13   #163 (permalink)
redrage's Avatar
Its not the sim card for sure , My Sim card is just about a couple of months old and i shuttle between Blore and Chennai and use 2 sims. Irrespective of the sim there is a problem, i guess it is some faulty data on my memory card. Need to format it and try.
__________________
Old 25th February 2009, 13:42   #164 (permalink)
hydrashok's Avatar
That's bad news. redrage. Looks like the FW upgrade is a big PITA. :(
The phone automatically starts installing stuff probably because of some 3rd party apps having been installed on the MicroSDHC card. Yep, formatting it and trying it again could be a good idea. Also, not keeping the MicroSDHC card in the card-slot while hard-resetting could be a good idea.
I'd heard Nokia Maps had given issues to quite a few phones (across a few models) with new FW updates. But that is only when the Maps program is started.
__________________
Old 16th March 2009, 12:40   #165 (permalink)
Default Some queries
Guys,
I am looking at Nokia E71, but have a few questions:
1. Is the speaker/call quality (i.e. the other person's voice) a major problem? I had an E61i before and faced very low speaker voice, maybe because of the form factor of the form. Is it so in E71's case as well?
What I want is a speaker that belts out voice loud enough to be heard clearly in crowded places/traffic.
2. How does the GPS thingy work? After the 3 months of free usage, what is the subscription charge? Are there any alternative/free/cheaper (but effective) GPS applications?
3. Do you need to have a special GPRS data plan for the GPS, or does a plain vanilla Vodafone Live (pay per use) plan work fine?
4. Is there a newer firmware than 200.21.118? I read a lot of 'major' glitches in this version at least! (Read Viper's review. He had to sell the phone! Now thats 'SERIOUS')
__________________
Thread Tools
Nokia N82 & N95 new software versions released (March/April 08) nishantgandhi Gadgets, Computers & Software 6 9th April 2008 17:54
NOKIA 9300 software Upgrade. zulfikar Gadgets, Computers & Software 3 13th February 2006 14:03
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
