Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more!
Thread Tools
Old 8th September 2008, 17:11   #1 (permalink)
Default LG Home Theater System: DVD does not run beyond a certain point
Guru's,
I have LG home theatre system and I have found in couple of DVD's, they do not run beyond a certain point. These points are variable for different DVD's. e.g. A Bridge too far won't run beyond 1:32:40 or Aamir won't run beyond 1:20:23 or Valu won't run beyond 1:40:52. However, all these DVD's run without any problem on player (Pioneer) at DVD Library (shop from where I rent the DVD). Why does this happen? The home theatre system is new ( just over a year old) and we would have seen not more tha 40 movies till date (i.e. not very heavy usage).
I have cleaned the head with help of Philips DVD cleaner. I cleaned the DVD's with the solution available in the market, but they won't run beyond a certain point. If I touch the DVD player at this point, I can feel the DVD running inside, but the picture is like "Computer hanged".
Please note that I do not have problems for most of the other DVD's or VCD's. Only to few that I mentioned above.
What is the issue and the solution for it?
looking forward to your help
__________________
Rajesh Kavthekar
Indica DLS, 94.5K, 17+kmpl, Pune.
i-10 Era
rkavthekar is offline   Reply With Quote
Old 8th September 2008, 18:08   #2 (permalink)
Did you check playability in another LG DVD player, if it does, some problem with your player like a weak laser etc.
If not, its a dvd compatibility issue with LG players.
__________________
Remember, its a machine
Old 8th September 2008, 18:52   #3 (permalink)
Thanks. But I feel compatibility is not an issue for DVD does run for some time and we are able to see the picture. I am not sure how we can measure the strength of the laser, but that may be the issue.
regards
__________________
Rajesh Kavthekar
i-10 Era
Old 8th September 2008, 19:47   #4 (permalink)
esteem_lover's Avatar
Please play the same DVDs on a different player. The discs could be damaged.
__________________
Goodbye Dada, you made us proud.
Old 22nd September 2008, 01:51   #5 (permalink)
It doesnt seem like an issue with the DVD pick up lens. DVD's if scratched/marked can affect playing. Though strange, i feel you can try resetting the player...if you have an option.
Once you load the DVD, go to menu and select from the last chapters of the movie and check if it plays. If so, the disc is scratched. Else you might need a visit to the service center.
xotiq is offline   Reply With Quote
Old 22nd September 2008, 04:08   #6 (permalink)
Shan2nu's Avatar
Diff players have diff tolerance levels wrt scartches, disc quality, burn quality etc.
Sometimes, these rentals give pirated discs or original discs with a lot of scratches which certain players find, diff to handle. Which is why it plays to a certain point and gets stuck.
Make sure your dvds are of good quality and dont pick up discs that have been sctrahed even if its an original copy.
Shan2nu
__________________
VTEC flyby - youtube.com/watch?v=1AhWJlVRPqE
Old 22nd September 2008, 14:11   #7 (permalink)
pranavt's Avatar
Probably a circular scratch running parallel (?) to the data track. Unlike perpendicular scratches, these circular scratches give error correction mechanisms a real run for their money. Try another DVD of the same movie from elsewhere.
Old 22nd September 2008, 17:39   #8 (permalink)
Thats why I am a huge Pioneer advocate.
If you have a dvd burner why don't you rip the problem dvd's and burn to fresh discs.
Sound like a media problem rather than a hardware problem.
bigman is offline   Reply With Quote
Old 23rd September 2008, 13:33   #9 (permalink)
Not sure whether its because of the scratched DVDs but my Philips player had this problem too. I ignored it assuming its scratched DVDs. Later on I upgraded my DVD collections to originals only and some of them were bought from the US.
One fine day the DVD started giving the same problem but more severely. At times after cleaning with a lens cleaner - it works for 10 minutes before it hangs and goes kaput. The MP3 CDs still play properly. I was told by the technician that the lens had to be replaced. The cost of the lens ranges from 500 to 1000 bucks. If i go through Philips authorized service centre the lens cost is 1100 + 350 for servicing. The regular repair guys can do it for less than 800. I am still contemplating what to do.
kalpeshc is offline   Reply With Quote
Old 23rd September 2008, 15:08   #10 (permalink)
Always buy genuine spares, but nowadays new DVD players are available quite cheap, that too branded ones like philips.
So check the difference before you go for repairs.
__________________
Old 23rd September 2008, 16:38   #11 (permalink)
Just go for a decent brand in the first place. Philips dvd players are not reknown for durability.
Old 24th September 2008, 10:47   #12 (permalink)
The issue is that even though 1500 for repairs seem costly - I actually have a low end Philips home theatre system with 5.1 speakers. These speakers are working just fine and i would need an amplified dvd player and will have to modify the speaker's connectors (philips has propritory connectors), if i plan to go in for a new one.
To save myself that hassle, repairs is the easy way out.
Thread Tools
Which Home theater system? muni Gadgets, Computers & Software 678 7th January 2009 16:23
USB Hard Disk to Home Theater autoenthusiast Gadgets, Computers & Software 0 20th August 2008 22:36
Help me build a Simple Home Theater PC sandeepmdas Gadgets, Computers & Software 26 6th March 2008 11:53
Home theater under $220 cooldude1988765 Gadgets, Computers & Software 4 9th November 2006 14:31
For SALE- Home Theater components nitinbhag Shifting gears 1 2nd August 2006 19:24
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489
