| Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Feb 2007 Location: chandigarh
| Hello Team-bhpians, I have a weird problem with my Dell Inspiron 1100. Whenever I start typing the dot key (............) goes on typing dots on its own. I am not able to control the Keypad. I have started using a USB keyboard, but still the problem persists. I have taken the laptop to a hardware guy. Their solution a new keyboard costing INR 2000 which i don't want to spend on a 4.5 years old laptop,as I have to buy a new one in the next two months.. Any suggestions... |
| | #2 (permalink) | |
| Senior - BHPian Join Date: May 2005 Location: TRV
| Quote:
If it occurs in both the inbuilt as well as the external USB keyboard then it is a software glitch and not hardware related. | |
| | #3 (permalink) |
| Team-BHP Support ![]() Join Date: Feb 2004 Location: Bombay
| Wolg, Try reinstalling the keyboard drivers. - Go to DEVICE MANAGER - Under KEYBOARDS delete/uninstall all the entries - Restart your computer and windows XP (?) should automatically detect and re-install the drivers. If that still doesnt work let us know. cya R
__________________ The memory of you will ride by our side forever. |
| | #5 (permalink) |
| Senior - BHPian Join Date: May 2007 Location: Vadodara
| Its pretty simple. Some times there is little damage to internals of Keyboard. Take it any well know professional. He will open and work on the " Circuit of keyboard ". Sometimes the connection does get lose or some sort of problem occurs. They can solve this. But if they are not able to solve this, get yourself a USB keyboard. This happened in my sister's laptop and despite all my efforts I was not able to repair the keyboard. So bought a new USB keyboard. NOTE : Dont take it to just any computer professional. Take it to some who has knowledge and has practically solved the problem/problems earlier. I dont know if its called a circuit or not, I just used this word as I dont know the proper word. But I have practically myself worked on this.
__________________ Never Dream because broken dreams hurt the most.There is no market for emotions. EVENTUALLY FATE DECIDES EVERYTHING. |
| | #6 (permalink) |
| Senior - BHPian Join Date: Feb 2007 Location: Delhi
| Seems your keyboard circuit is gone kaput. Consult a notebook professional. If he insists to get the internal keyboard changed, do not invest 2000 Rs. Tell him to disconnect the keyboard from mainboard, it ain't so much big thing. A clip need to be de-attached only. This way you'll be able to use the external keyboard without any problem. Cheers
__________________ Ashish K "Ninety percent of the politicians give the other ten percent a bad reputation." |
| | #7 (permalink) |
| BHPian Join Date: Jun 2008 Location: Madras
| If you dont mind experimenting (the other option being - taking it to a professional / listen to Dell!), try this: Carefully pry the . key off the Keypad - I have done this several times when I spill 'something' on my old Thinkpad / Toshiba. Now try using the . key, see it it works proper. If it works proper, the spring action is probably conked out - simple fix, DIY. If it still acts up, sorry buddy - experiment failed ![]() |
| | #9 (permalink) |
| BHPian Join Date: May 2007 Location: Bangalore
| @wolog, you would have the restore cd's from dell boot from them and go to dos check if you have the same problem in dos if yes then there is a keyboard problem if no then it is windows. "check if you can see the same in safe mode as well (F8 when it boots) this step is if you don't have dos disks" if its the same in dos then let me know i will try and get some pics for you about how to reset the keyboard ![]() |
| | #10 (permalink) |
| Hi Guys, Thanks for the advice.I was not able to log in yesterday as the whole day my "Keyboard" was in Dot Typing Spree. @ Rehaan- Already done that, does not work @ Sankar - The problem happens with both keyboards.Any idea about what software glitch it could be. I am a total tech iliterate inspite of being in IT. @ Thad E Ginathom & ph03n!x - Have banged on the keys, and in fit of love pried out the Dot Key, but still the "Dot Ghost" persists. @ aaggoswami and ashthedivx - I wil be taking it to a hardware guy and asking him to detach the original keyboard. I will let you know if that works. Cheers Wolg |
| | #11 (permalink) |
| Wolg, 3 more options: 1. - Pop off the "." key (pull it up from one edge and the key/cap will just click off) - Get a can of compressed air ("dust-off" etc) and spray it in there. - This might dislodge any particle that is either caught between the contacts or pressing the contacts together 2. - Plug in your USB keyboard - Go to device manager - See if a "disable" option exists for your existing keyboard (i feel like only uninstall will be present, in which case it probably wont work since it might try and reinstall the driver immediately? Give it a shot either way) 3. - Remove/unplug the laptop keyboard!! - Use USB keyboard instead - Its fairly simple, dont worry - Removing keyboard from Dell inspiron 1100? - Yahoo! Answers - Dell Inspiron 1100 1150 5100 5150 keyboard removal instructions cya R
| | #12 (permalink) |
| Senior - BHPian Join Date: Jun 2007 Location: Kochi
| Somewhere in control panel (if that is what they still call it), there would be an option to slow down the key "repeat rate". Looong time since I used Windose...
__________________ ɹǝʌıɹpʇɐǝsʞɔɐq |
| | #13 (permalink) |
| Senior - BHPian | why dont u try booting into dos and type there to see if its a software issue or a hardware issue.. windows may have gone kaput. try starting in safe mode if possible and then see. is ur computer emitting constant error beeps while starting up from the bios? that would mean the hardware key is spoilt and stuck.
__________________ Ford Fiesta S| Eclipse CD7200MKII| Alpine SPX17PRO| JBL W12GTi| DLS RA20| Clarion DPX11551| |
| | #14 (permalink) |
| BHPian | Hi Wolg, I too have similar problem with my 5 year old HP laptop. It starts typing in the comma characters continuously whenever it boots up (rarely when i'm doing something also). After lot of trials I have found that if I press the Esc key twice, it goes away. Then i cannot type the comma character after that (until i restart). I used to have a file in my desktop with the comma character typed in its name so that i can copy and paste it when im typing something. Since this worked for me, i never did any further research on this. I'm closely following this thread to see if I can also find a fix for this.
__________________ Cheers K a s h ---------------------- 2006 Hyundai Getz 1.3 2003 Yamaha Rx135 |
| | #15 (permalink) |
| Hi Guys, Thanks for your advise. @Rehaan - Thanks, tried all three options .Now the original keyboard has been disconnected and using the Usb keyboard. @backseatdriver (sorry for misspelling) - thanks, will try maybe in the future @ frankmehta - yes, the computer beeps while starting up. please can you specify any remedies @ K a s h - i was fed up so just disconnected the original keyboard and using the USB keyboard now. Cheers Wolg |
| Thread Tools | |
Similar Threads | ||||
| Weird temperature problem | teknophobia | Technical Stuff | 4 | 26th August 2008 23:52 |
| Help/Guidance for Solving the problem in My ICE!!! | rajeevrs | Ask the Gurus | 17 | 14th November 2007 17:18 |
| The Solutions Thread-Please post all you know about solving a car related problem. | gemithomas | Technical Stuff | 8 | 5th August 2007 01:48 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599
