Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more!
Thread Tools
Old 29th March 2005, 12:02   #1 (permalink)
Team-BHP Moderator
Rtech's Avatar
Default SD card error! Help!
Just took out my camera to take a couple of pictures and it said "memory card error". Can't access the card to take or view any of my stored photo's or even format the card.
Is there anything I can do to repair this problem? Or is it gone for good?
Card Details:128MB Lexar SD card
__________________
He who makes the loudest noise usually has the least to say. Unfortunately they don't realise that and keep at it!
____
Old 29th March 2005, 12:12   #2 (permalink)
Team-BHP Moderator
Dippy's Avatar
The card may have shifted because of movement. Try taking it out and putting it back in again tightly
Dippy
__________________
My name is Adrian Sutil. You can call me ADDY - Force India
dippy@team-bhp.com
Dippy is offline   Reply With Quote
Old 29th March 2005, 12:15   #3 (permalink)
Team-BHP Moderator
Jaggu's Avatar
yup first thing switch off cam, remove card, reload card n switch on.. if this doesnt work slot the card in a comp with sd card slot n see..
__________________
The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin
Old 29th March 2005, 12:18   #4 (permalink)
Gordon's Avatar
Remove the card and re-insert it. Check whether the card is not read-only.
If you have any more problems, I think you should have a manual which can troubleshoot it.
__________________
Team-BHP.com > Motorbikes > Yamaha Cafe Racer
Gordon is offline   Reply With Quote
Old 29th March 2005, 12:25   #5 (permalink)
Team-BHP Moderator
Rtech's Avatar
Done the above already. Rebooted, taken out, cleaned, inserted back in. No luck. Tried another card and it works fine. Does this mean the card is wrecked?
Damn cheap taiwan crap!
__________________
____
Old 29th March 2005, 12:36   #6 (permalink)
Gordon's Avatar
is the card original or fake??!
original as in Branded company?
__________________
Old 29th March 2005, 12:56   #7 (permalink)
jesal's Avatar
Infractions: 0/2 (8)
lexar is a very good company in SD cards. i have a 256mb in mine as well. what you can do is if u have a card reader load it up in there and format from the pc itself then insert in the camera. if it works then format it first and start using it again. this should help most of the times. if it does not work and if u have paid for warranty u will get it replaced since they all come with 5 years. if u have a grey market one play around for a while. might just work. though if u have been dropping it often it tends to get messed too.
__________________
Јєşåł Åŕỳā
Modifying Gone Mental
jesal is offline   Reply With Quote
Old 29th March 2005, 12:57   #8 (permalink)
Team-BHP Moderator
Rehaan's Avatar
Hey Rtech,
Clean the contacts on the card.
Move the "read only" switch back and forth.
Then try it again.
If its still not working, try using the card in a computer SD drive or the likes.
If you cant even format it there...then youve got problems.
Lexar has a good warranty system and makes good quality stuff. If you just contact support staff and then mail the card to them they should send you a replacement. (thats the way it works in the states...have done it myself due to incompatibility of some SD cars with pocketpcs)
cya
R
Old 29th March 2005, 14:53   #9 (permalink)
mohit's Avatar
Try putting your card in a reader and run a program like NDD on it to check for bad sectors. If there are any, the card is gone. I just ended up with a small piece of plastic that was once a 512MB CF card........ Tried repartitioning it in windows and linux but the damn thing just refuses to work!
mohit is offline   Reply With Quote
Old 29th March 2005, 15:06   #10 (permalink)
Team-BHP Moderator
Rtech's Avatar
Grrr...cleaned the contact but still no luck.
Rehaan, card was bought in the grey market, so no warranty. Unless I post you the card and you send it to Lexar US asking for a replacement (sneeky sneeky)
Will try putting it in a reader as a last resort. Otherwise seems like its gonna be another useless plastic piece like mohit's!
It's times like these you miss the traditional film camera!
__________________
____
Old 29th March 2005, 15:15   #11 (permalink)
Gordon's Avatar
Rtech, always go in for warranty pieces and from proper dealers.
I've seen 512 MB Sony Memory Sticks being sold for 3000 at Irla. Fact is a 512 MB memory stick at the Sony Dealership costs around Rs 16000. If you compared the two cards, they are 99% identical, but they give away due to slight variations in the fonts of some letters.
__________________
Old 29th March 2005, 15:23   #12 (permalink)
iceman91's Avatar
and most importantly..the quality of a genuine product!!!
__________________
...91 is back !!!!
iceman91 is offline   Reply With Quote
Old 29th March 2005, 15:28   #13 (permalink)
Team-BHP Moderator
Rtech's Avatar
The card I'm using is genuine. However, like anything electrical, it can malfunction at any time.
__________________
____
Old 29th March 2005, 22:46   #14 (permalink)
jesal's Avatar
true in electronics anything can go wrong any time cant blame. no way in hell i will spend 16k on 512 chip btw. just too high. though 3k seems cheap for 512. gordon u talking about camera chips or phone ones ? ? ?
__________________
Јєşåł Åŕỳā
Old 29th March 2005, 22:56   #15 (permalink)
Gordon's Avatar
I'm talking about Sony Memory Sticks for cameras.
__________________
Thread Tools
Error 11 and error 17 in pioneer MP3 rajivanoj Ask the Gurus 20 30th January 2008 14:47
LAN card to LAN card sharing abhibh Gadgets, Computers & Software 13 10th June 2007 07:57
Ialmrnt5 Error! Gordon Gadgets, Computers & Software 10 12th December 2006 17:40
Error in Gmail !? DCEite Shifting gears 6 14th November 2005 12:03
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
