Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more
Thread Tools
Old 24th October 2008, 14:22   #1 (permalink)
kb100's Avatar
Default Voltage Stabilisers
Friends
Most of us have/use electronic equipment at home that need protection. I am in the market for a good stabiliser for my HT setup. Can the knowledgeable please shed some light !!
Is this any good?
APC - Line-R - Product Information
__________________
A closed mouth gathers no Feet.
kb100 is offline   Reply With Quote
Old 24th October 2008, 23:48   #2 (permalink)
kb100's Avatar
Guys... I REALLY need a good voltage stabiliser - Current setup is hooked to a VGuard Stabiliser and I read here on the forum that its trash.
I am planning to invest in a new plasma + HT setup.
Please advice!
__________________
Old 25th October 2008, 00:05   #3 (permalink)
And, pray, what is wrong with vguard? I would trust a home grown stabiliser to any non-Indian brand, simply because Indian brands are experienced in dealing with voltages like 110V, 48Hz!!!
__________________
ɹǝʌıɹpʇɐǝsʞɔɐq
Old 25th October 2008, 00:05   #4 (permalink)
Shakensoul's Avatar
APC will be good but expensive.
You can also try Logicstat if its available in your city.
Logicstat on the Web: Leading Manufacturer of Voltage Stabilizers in India
Shakensoul is offline   Reply With Quote
Old 25th October 2008, 00:15   #5 (permalink)
kb100's Avatar
That is what I thought too - I fact all my stabilisers are vGuard.
Apparently someone who hooked it up to a scope found the raw power cleaner! (in the LCD thread)
Under the circumstances I just wanted to ensure I get the maximum 'Sane' level of protection for the equipment I am proposing to buy in ten days!
__________________
Old 25th October 2008, 00:22   #6 (permalink)
mura's Avatar
If you are getting a Plasma + a serious HT setup with AVR and Powered Subwoofer get a 3 or 5 KVA Servo Stabiliser. Do NOT get electronic/CVT type stabilisers and do NOT Connect them to your home inverter.
mura is offline   Reply With Quote
Old 25th October 2008, 10:55   #7 (permalink)
sixthsense's Avatar
Is there any harm if i run my HT on inverter ? the area i live in has frequent disruptions in electric power supply. Now the sole purpose of purchasing an 800VA inverter was to watch uninterrupted television.
__________________
Weekend's Don't Count Unless You Spend Them Doing Something Completely Pointless.
sixthsense is offline   Reply With Quote
Old 25th October 2008, 12:05   #8 (permalink)
MuzzledMoose's Avatar
Modern Devices does not need a voltage stabiliser. Just a surge protector is enough. Most modern equipments have switch mode power supply which can take universal input. SO just get a surge protector device and have peace of mind.
__________________
Do OR Die and NeVeR saY DiE
MuzzledMoose is offline   Reply With Quote
Old 25th October 2008, 12:32   #9 (permalink)
headers's Avatar
depends on what you want to use that stabliser. Ensure that the stabiliser gives a full sine wave. There are a lot of cheap devices that give a quasi sine wave that spoils your purpose.
__________________
Only a V8 will do! Only a V8
Old 25th October 2008, 15:14   #10 (permalink)
dash's Avatar
I have bought a plasma tv and looking to buy a 500VA V-Gaurd stabilizer. Can any one suggest if this would be sufficient or should I be looking for any other rating stabilizer? Pls. advise
dash is offline   Reply With Quote
Old 25th October 2008, 18:49   #11 (permalink)
headers's Avatar
check the power rating of the plasma tv and decide on the stabiliser accordingly.
__________________
Old 29th October 2008, 03:27   #12 (permalink)
Can you not get a large voltage stabiliser through which your mains supply first enters before going via various circuits to the rest of the house ?
I know countless people in Punjab and Haryana who have these large stabilisers serving this purpose.
bigman is offline   Reply With Quote
Old 29th October 2008, 09:19   #13 (permalink)
jkdas's Avatar
Would suggest the same.
And if your house has an invertor see that it too gives a sine out.Most dont and APC one's start about 20k.
I thought VGuard was good.And they have the digital versions too right?
I dont think this is a viable idea as it will involve lot of rewiring (supposing one has a 3 phase line).
EB wont allow you to have a big servo stabilizer too.
__________________
Audio, video, disco
Tat tvam asi
Old 29th October 2008, 10:09   #14 (permalink)
Couple of decades back, yours truly had the brains to ask an electrical engineer the question "why not have a big stabiliser for the whole house, rather than have several small ones for each appliance". The answer is interesting.
When you put a huge stabiliser for a huge circuit, the power consumption would be same (volts X amps). So if you step up the consumption Volts, the consumption and therefore, supply amps will go up. When supply amps go up, power at supply end has to remain constant; so higher supply amps is compensated by lower supply volts. Resulting in still higher drawing of power. Resulting is still lower supply volts. Ultimately leading to a power failure.
__________________
ɹǝʌıɹpʇɐǝsʞɔɐq
Old 29th October 2008, 10:31   #15 (permalink)
headers's Avatar
Well, I have a BIG servo stabiliser at Home! And EB does not care much about it!
@Backseatdriver: Well..your power bills go up by around 15-20% but i dont have individual stabiliser for my home appliances. and i have a different POV than the answer you got from that electrical engineer!
The benefit of having one big servo is that it controls the entire supply of the house and one has a better life of all electrical appliances. There are no surges or dropouts and all lighting / fans / ac / kitchen appliances run smoothly!
__________________
Thread Tools
PS3 from US - do i need a voltage transformer?? jassi Gadgets, Computers & Software 36 22nd November 2009 23:15
Incorrect voltage to sensors - ECU Lamp vdiatech Technical Stuff 5 2nd May 2009 02:05
Battery/Alternator /Voltage regulator problem? babe_on_wheels Technical Stuff 21 27th March 2009 18:49
Capacitor? - Need to stabilize voltage when radiator fan turns on... Ford Rocam Technical Stuff 33 10th February 2008 19:35
Tata Indica alternator voltage query tsk1979 Technical Stuff 5 9th December 2006 12:45
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
