Old 1st December 2008, 12:30   #1
Thanked: 3,650 Times
Default How To Use A Qstarz BT-Q1000P GPS Receiver with Ubuntu?
I have got a Qstarz BTQ1000p GPS receiver with me, manufacturer doesn't provide any Linux support for this device. I have to make this device work with Ubuntu 8.04. Any ideas on how to make this work? A webiste ( Qstarz BT-Q1300 on Ubuntu 8.04 (Hardy Heron) | GPS Data Logger Software - BT747 ) suggested kernel recompilation but that is out of my league.
Here's the dmesg output when i connect the device via USB:
[ 6490.648143] usb 1-1: reset full speed USB device using uhci_hcd and address 4
[ 6490.802265] usb 1-1: cp2101 converter now attached to ttyUSB0
[ 6685.712010] usb 1-1: USB disconnect, address 4
[ 6685.712398] cp2101 ttyUSB0: cp2101 converter now disconnected from ttyUSB0
[ 6685.712420] cp2101 1-1:1.0: device disconnected
[ 6910.359888] usb 1-1: new full speed USB device using uhci_hcd and address 5
[ 6910.587844] usb 1-1: configuration #1 chosen from 1 choice
[ 6910.593625] cp2101 1-1:1.0: cp2101 converter detected
[ 6910.707560] usb 1-1: reset full speed USB device using uhci_hcd and address 5
[ 6910.853698] usb 1-1: cp2101 converter now attached to ttyUSB0
When i connect the device to Ubuntu via Bluetooth dongle it says, Connected to iBT-GPS, but nothing happens after that. I tried GPSDrive but the application says No GPS.
How can i make this work; any hints, suggestions, ideas?
Old 1st December 2008, 13:04   #2
Ok i got it working, i can now access the GPS device using gpsd and view the data using xgps. Now i have to figure out how i can access and use the Logging functionof the GPS device.
Old 1st December 2008, 13:22   #3
tsk1979's Avatar
Thanked: 15,684 Times
I think you can let the software handle the logging. For example gosmore or something will log stuff as long as GPS is connected and machine is on.
Old 1st December 2008, 20:05   #4
I don't tknow which software to use for logging the data. I tried GPSDrive and it isn't detecting the GPS receiver eventhough it's connected to the computer. I can access the GPS receiver through gpsd and invoking xgps. But xgps doesn't do logging it is a basic graphical front end for the receiver. Os is ubuntu.
The Ubuntu Linux Thread deepclutch Gadgets, Computers & Software 121 25th July 2013 14:55
Using a GPS Receiver in the Car sharathjeppu Technical Stuff 1478 15th November 2012 14:51
In Dash GPS/Audio Receiver mav2000 In-Car Entertainment 16 1st April 2010 20:25
How to configure MireoPC edition with USB GPS receiver contactme27 Gadgets, Computers & Software 1 4th November 2009 21:56
Linux Ubuntu Beryl gopz Gadgets, Computers & Software 31 4th March 2008 08:41
