Old 1st January 2009, 20:38   #1
DCEite's Avatar
Thanked: 607 Times
Default How to use remote desktop through wifi router
I have a DSL connection on my desktop with the router being WiFi enabled. What i want is to remotely login on my laptop from the desktop (remote desktop), using the WiFi connection. I can already access the internet on the Laptop through WiFi. Want to know if is possible to use remote desktop from Desktop->Laptop ?
DCEite is offline   Reply With Quote
Old 1st January 2009, 20:42   #2
greenhorn's Avatar
Thanked: 1,519 Times
yup, you can.The application layer and network layer are seperate !
PS: I've done this too
Old 1st January 2009, 20:48   #3
ImmortalZ's Avatar
Thanked: 312 Times
Yes, easily.
Just enable the Remote Desktop on the Laptop. On an XP Pro machine, go to the System Control panel, Remote tab and enable the Remote Desktop checkbox. Make sure you have a user account on the machine with a password set or you will not be able to connect.
If you have installed any third party firewalls or AV software with bundled firewall on that computer, you'll have to configure it to allow RDS connections through (TCP 3389).
Once this is done, fire up the Remote Desktop client on the other machine (Accessories) and type in the IP address of your computer. Hit Connect, enter credentials when asked for and you should be in.
Do remember you need to have basic network connectivity already established for this to work (same IP address ranges etc etc).
Old 1st January 2009, 23:22   #4
vivekiny2k's Avatar
Thanked: 184 Times
I have free zonelarm and I could not get it to work. I ended up using real VNC. all it needs is the IP of the computer running VNC server
later on bought a bluetooth keyboard and mouse for remote login (PC connected to the TV in living room, logging in from living room while wathing the TV).
vivekiny2k is offline   Reply With Quote
Old 2nd January 2009, 02:41   #5
phamilyman's Avatar
Thanked: 3,526 Times
easy peasy. You just rdesktop from one to another - you can see IP settings under Start->Run-> cmd and type ipconfig on both.
Old 2nd January 2009, 11:07   #6
aZa
aZa's Avatar
Thanked: 17 Times
i use the same config. TightVNC is what im using. Its smooth and efficient.
Old 5th June 2010, 17:06   #7
pradster's Avatar
Default Sweet!
I hooked up a BIG ( I mean BIG) stereo system to my home rig and was thinking if I could control the music without actually having to go into the room where I keep my desktop. ( the speakers are in my room)
I googled my query only for it to throw up team BHP and the correct answer.
Boy, are we guys good or what?
Now I control my desktop using my netbook ( HP mini 10) and can chill with my favorite music
Thanks a bunch fellas!
pradster is offline   Reply With Quote
Old 5th June 2010, 21:24   #8
Thanked: 660 Times
Use Teamviewer. It can't be easier and better than this.
PS: Its free for non-commercial use.
Old 5th June 2010, 21:29   #9
clevermax's Avatar
Thanked: 445 Times
Yes this is easy to do. But make sure that your windows firewall settings isn't blocking the access. Third party firewall apps also can be configured to make this work.
clevermax is offline   Reply With Quote
Old 5th June 2010, 23:59   #10
pradster's Avatar
I checked out teamviewer, seems pretty useful where the distances are greater. Right now I just need to get my laptops and desktop to talk to each other (both at home) and not use my broadband in the process. RDC seems like the perfect fit in this situation.
Old 6th June 2010, 16:00   #11
Thanked: 660 Times
But you can use team viewer on you LAN. Just do the following.
In the menu click on extras and then on options.
On the general tab activate 'incoming LAN connections' to accept exclusively.
Use IP address or Netbios name of PC to connect.
Old 7th June 2010, 13:01   #12
ashthedivx's Avatar
Thanked: 22 Times
+1 Teamviewer is the best and easiest to establishing remote connections.
Old 7th June 2010, 14:49   #13
pradster's Avatar
@Siralec
Thanks for the pointer, will surely try that out
Old 7th June 2010, 17:00   #14
chevelle's Avatar
Thanked: 526 Times
+1
I have been using Teamviewer 5 since its launch. One of the coolest and easiest software i have used. A must for remote sharing and controlling.
chevelle is offline   Reply With Quote
Old 7th June 2010, 18:38   #15
vivekiny2k's Avatar
Thanked: 184 Times
I still believe using bluetooth mouse is better than having to open another laptop and control, for music/movies control (which started the discussion this year).
not to mention VNC/teamviewer does take some CPU cycles that can be avoided while playing high def movies.
DIY: Adding a Remote level control/ Bass remote to your Amplifier HimuraKenshin In-Car Entertainment 8 11th April 2012 16:59
Using IPOD touch with ADSL WiFi router DCEite Gadgets, Computers & Software 5 24th September 2009 22:44
Remote desktop of laptop from PC using Bluetooth? DCEite Gadgets, Computers & Software 2 12th September 2008 10:58
Connecting Home PC with Remote Desktop anujmishra Gadgets, Computers & Software 13 7th August 2008 12:41
remote control on desktop vivekiny2k Gadgets, Computers & Software 11 18th March 2007 06:35
