Old 2nd January 2009, 15:21   #1
doomsday's Avatar
Post Seagate FreeAgent 1TB issues...
Hi guys,
I got myself a 1TB Freeagent to store all my Top Gear, Fifth gear, Best Motoring and other automotive videos and stuff since my two smaller 120GB drives and my laptop were full to the brim. The dealer said it was pre-formatted and that I could start using it right away.
The problem raised its ugly head the very first time I plugged it in. Windows XP didn't recognise the drive and I literally passed out thinking that I have damaged it somehow before using it even once. Then we tried restarting the PC twice or thrice and it suddenly detected the media as a single partition of 984GB or so of usable space. So the drive was indeed formatted and ready to use.
I started copying data from a friend's comp- totalling to around 250Gb, the transfer was successful. I got the harddrive back home and plugged it in to another PC- the same issue popped up again- Windows didn't recognise the drive. I went through computer management in control panel but the partition didn't show up there as well. I started panicking again, restarted the system twice or thrice and continued with my work where it was suddenly detected with the autorun popup.
I have been facing this issue since a long time now- recently I tried connecting it to my friend's Dell Inspirion 1501 and it refused to detect it. I powered down the laptop, changed USB ports to which it was attached and it was detected again suddenly. I copied some stuff and disconnected it- since then it has refused to detect the drive.
Can someone shed some light on what possibly could be wrong. I have changed the USB cable twice or thrice, I try all possible USB ports too on a machine. Is it possible that it can be a motherboard issue on older machines which can't detect portable devices with higher storage?
Thanks in advance.
doomsday is offline   Reply With Quote
Old 2nd January 2009, 15:33   #2
aaggoswami's Avatar
Thanked: 1,550 Times
Originally Posted by doomsday View Post
Hi guys,
If possible, format the drive again and then see if there is a difference. The motherboard issue can be there, but I feel that there is something wrong with hard drive itself.
If possible, give it for RMA.
aaggoswami is offline   Reply With Quote
Old 2nd January 2009, 21:44   #3
pranavt's Avatar
Thanked: 274 Times
Get it replaced. Don't stick to something which is giving problems just after purchase.
Old 3rd January 2009, 01:00   #4
Thanked: 661 Times
Its best you claim your warranty.
Old 3rd January 2009, 06:39   #5
claim warranty asap!
vishalpipraiya is offline   Reply With Quote
Old 3rd January 2009, 11:07   #6
cooldude1988765's Avatar
Thanked: 115 Times
I had a similar problem with my WD 1tb drive. It turned out I dint have enough ram (had only 256mb). When i upgraded the ram on the same comp (everything else was same) to 2gb there were no problems. I could connect upto 4.5tb without a hitch (I could probably connect more but thats all i had).
It seems wierd but i thought your hard drive reading capability depended on your motherboard bus speed but somehow upgrading the ram fixed things for me.
Hope this helps
cooldude1988765 is offline   Reply With Quote
Old 3rd January 2009, 12:08   #7
Take it to the dealer along with your laptop and he should be able to figure it out. There could be compatibility issues but this occasional detection / non detection speaks against that.
WanderNomad is offline   Reply With Quote
Old 3rd January 2009, 12:37   #8
doomsday's Avatar
Post
The thing about claiming warranty is the fact that I need place to transfer the ~500 GB of data to another drive and then wait for them to inspect and send it back. I'll try that but not sure that I'll find so much space somewhere except if I buy a new HDD.
@ cooldude- Interesting fix. Let me see if I can try that since I need to upgrade RAM anyways.
Thanks to all for your suggestions.
Old 3rd January 2009, 12:50   #9
ssjr0498's Avatar
Thanked: 122 Times
I also have a Seagate freeagent 1 TB hard drive and my system just has abt 512 MB of ram, however the transfer speeds seem to be really good.
As for the detection, did you install the software that came alongwith the hard drive, or did you just let windows do its work?
It really helps if you install the Freeagent software on your system.
Shrey
ssjr0498 is offline   Reply With Quote
Old 3rd January 2009, 13:05   #10
doomsday's Avatar
Post
Originally Posted by ssjr0498 View Post
Shrey
The software comes loaded on the HDD itself. So it needs to be detected first in order to install it. The issue is that I've been using the drive on many diff systems. So I haven't installed the freeagent software on all machines. I think I should stick to one machine and install the software once it gets detected.
Old 22nd January 2009, 12:37   #11
Post Seagate 1 TB Drives - High Failure Rate
Seagate has reported an issue with their 1 TB drives and there is a firmware update available. However, this firmware update is not universally know to fix the issues with the drive and usual opinion in forums is to avoid Seagate 1 TB drives altogether. Have a look at these articles.
Seagate isolates 'potential' Barracuda flaw ? The Register
Drives Fail at High Rates, Seagate Offers Solutions > Comments
Bottom line - Recover the data, return your harddrive and get a Seagate 1.5 TB (which is supposedly based on a design helping quieter operation and better speed than small ones) or switch to Hitachi/WD/Samsung/Maxtor whatever you fancy.
given2fly is offline   Reply With Quote
Issues with WagonR DCEite Technical Stuff 105 14th June 2018 12:58
Ideal number of partitions for a 1TB External HD. Shan2nu Gadgets, Computers & Software 24 9th February 2010 00:20
1TB USB drive for a song Samurai Gadgets, Computers & Software 109 31st January 2010 17:18
Updating harddisk firmware(seagate) ? deepclutch Gadgets, Computers & Software 1 28th January 2009 14:44
