Old 4th January 2009, 21:20   #1
Thanked: 295 Times
Default What is this on my laptop
It was on the Laptop motherboard. I think it is a choke, is in the power supply section of the Laptop.
Old 4th January 2009, 21:36   #2
ImmortalZ's Avatar
Thanked: 312 Times
That's a 2.2uH inductor.
Old 4th January 2009, 21:39   #3
Thanked: 295 Times
If I connect directly will it effect something ??
I think it is used for filtering power
Old 4th January 2009, 21:43   #4
ImmortalZ's Avatar
Thanked: 312 Times
Connect directly as in? I don't understand your question, sorry.
Old 4th January 2009, 22:26   #5
Thanked: 295 Times
It means that I do not use it and short the path instead of the inductor.
Old 4th January 2009, 22:29   #6
adityamunshi's Avatar
LBM ji, messing around with Laptop power supplies these days kya ?? How many subs are you putting in ?
adityamunshi is offline   Reply With Quote
Old 4th January 2009, 22:49   #7
greenhorn's Avatar
Thanked: 1,540 Times
if its still running, guess there must be a lot more ripple in the voltage now that its gone
Old 4th January 2009, 22:55   #8
Thanked: 295 Times
Have not till now but will it affect anything or do I have to put it there.
Old 4th January 2009, 22:59   #9
greenhorn's Avatar
because its running even after you removed it , i guess its not critical. they're used to supress the HF ripple from the SMPS ouput (kinda like a DC LPF )
Old 4th January 2009, 23:18   #10
Thanked: 295 Times
Have not switched on the laptop till now. Will try soldering it back
Old 5th January 2009, 00:43   #11
abhinav.gupta88's Avatar
Thanked: 310 Times
Is it from the same laptop you beat down to hell?
Old 5th January 2009, 07:56   #12
Thanked: 36 Times
I think it is there to spy your transactions and report it to the authorities concerned, it must have already triggered an alarm somewhere when you disconnected it. They must be coming ...
zaks is offline   Reply With Quote
Old 5th January 2009, 18:11   #13
ImmortalZ's Avatar
Thanked: 312 Times
Short anything in a power supply circuit at your own peril. Hey, a laptop on fire could be a very purty sight!
Old 5th January 2009, 20:01   #14
Thanked: 295 Times
Yes it is the same one....
Old 5th January 2009, 23:54   #15
Thanked: 661 Times
Does not laptop comes with a charger/battery for powering purpose.
How can you make out that its related to PS. that too on lappy mobo.
Car Battery to 220V AC convertor / inverter for charging laptop etc sreeku In-Car Entertainment 169 19th January 2018 15:42
Laptop Problem...Urgent help required cooljay Gadgets, Computers & Software 23 17th November 2013 20:59
acer ' ferrari edition ' laptop normally_crazy Gadgets, Computers & Software 5 13th November 2007 15:46
question for laptop owners manaa45 Gadgets, Computers & Software 15 19th August 2005 23:52
