Old 17th February 2009, 13:07   #1
Thanked: 160 Times
Default Help on GPS in E61
Guys,
Please let me know how to set up the GPS on this Nokia E61 model and i know this requires a bluetooth GPS dongle, please suggest the same.
gowda79 is offline   Reply With Quote
Old 17th February 2009, 15:02   #2
Jaggu's Avatar
Thanked: 8,670 Times
Find a compatible GPS unit and then pair the device using bluetooth connection, the details will be mentioned in the manual of both the phone and the gps unit. Once you do this when you access a GPS application the phone should automatically detect the GPS.
Old 17th February 2009, 23:51   #3
you will need a blue tooth GPS receiver, which can be connected to your phone using Bluetooth. There are many available in market from firms like SatNav, Mapmyindia etc..Check their websites.
Then you will also need Maps with voice navigation software, which are available from these companies.
Originally Posted by gowda79 View Post
Guys,
rammishra is offline   Reply With Quote
Old 18th February 2009, 10:24   #4
Jaggu's Avatar
Also you can use google maps if you dont require guided navigation.
Old 18th February 2009, 16:18   #5
Thanked: 160 Times
Thanks for guide guys.
Will keep you posted once i am done.
Need help on Sunfilm and GPS tracker abhi_k007 In-Car Entertainment 3 9th December 2011 13:56
Things to know before getting a GPS system for your car nishantgandhi Technical Stuff 4 31st January 2008 08:47
GPS anyone? tsk1979 Technical Stuff 33 26th September 2006 22:31
