Old 23rd June 2010, 22:22   #61
laluks's Avatar
Thanked: 9,713 Times
hi tsk,
do you know any methods in which you can record your track with time distance log? lets say you travel between point A to point D traversing point B and C. At the end of your trip, from the the track log I need to know when I was at point B, the distance between A and B, and also similarly for C and D.
What software, what format is this done. NoniGPs gives a track log, converted to Kml shows only the track, but no distance time data.
Any ideas...
laluks is offline   Reply With Quote
Old 24th June 2010, 10:47   #62
tsk1979's Avatar
Thanked: 16,420 Times
Can you convert the nonigps log to gpx and post a small snippet here. I am sure it does track logging with time stamps and altitude information.
Old 24th June 2010, 15:04   #63
laluks's Avatar
will do that by night once I get home.
Since i travel around, mostly the logging is done by hand for the points and time and distance from the odo. Just wanted to go for easy solutions. I am lazy
Old 25th June 2010, 08:20   #64
laluks's Avatar
Please find the test GPX file for your use.
Test.gpx
Old 25th June 2010, 10:47   #65
tsk1979's Avatar
I looked at the track points
They have
1. Lat Lon
2. Speed
3. Elevation
4. Timestamp
All that you need. Infact you can go to gpsvisualizer and create a "profile" w.rt speed, altitude etc.,
Old 25th June 2010, 13:31   #66
laluks's Avatar
They have
1. Lat Lon
2. Speed
3. Elevation
4. Timestamp
But distance between two locations how do you find?
Old 25th June 2010, 14:17   #67
tsk1979's Avatar
Distance between two locations.. I could not get your question.
You have two coordinates (lat1,lon1) and (lat2,lon2), any software including google earth allows you to draw placemarks, and then use the ruler tool to measure distance.
In nonigps view, you can set a waypoint at lat,lon, and then simply "Navigate" to the point. It will show you ETA/Distance as crow flies etc.,
Old 25th June 2010, 15:12   #68
laluks's Avatar
I wanted to avaoid the work on the PC.
Lets say Point A is x,y
Point B is x1, y1. I had travelled 5 kms to reach point B by the route I took from point A.
So basically I am looking for solution like
Point A, (x,y), Timestamp, Distance from start (0).
Point B, (x1,y1), Timestamp, Distance from start (5km).
etc.. and on.
The total distance travelled is logged by these logs, how do i get these intermediate distances?
I can find the points from the lat, lon on the maps.
Any pointers??
Old 25th June 2010, 15:18   #69
tsk1979's Avatar
Well if you have a gpx log, that will have just lat lon and timestamp. You need some kind of software to calculate the distances, like gps trackmaker etc.,
I am sure there will be some windows CE or mobile apps to do this kind of computation.
I have not really used any software for such purpose.. so no idea!
Old 25th June 2010, 17:56   #70
laluks's Avatar
Got it!
You can calculate like this the distance between two points in Lat, Lon
Point A (A,B)
Point B (C,D)
DISTANCE=3963.1*ARCOS[SIN(A)SIN(C)+COS(A)COS(C)COS(B-D)]
This gives you quite an approximation to live with.
Old 12th October 2010, 20:57   #71
AnkitPrashar's Avatar
Thanked: 30 Times
hi
i have an unlocked wince5.0 device.
Is there anyway i can run MMI maps on it?
What software would i need, can i buy it or download it?
AnkitPrashar is offline   Reply With Quote
Old 12th October 2010, 21:09   #72
sreedotk's Avatar
Thanked: 22 Times
Originally Posted by AnkitPrashar View Post
hi
I think you can. You would need Sygic as the software for the GPS and buy MMI maps for Sygic and use it on the device
sreedotk is offline   Reply With Quote
Il mio fantastico "Stallion Nero" FIAT Linea ! Fiat&Me Test-Drives & Initial Ownership Reports 34 5th February 2011 17:45
Fiat's Small Car Fiat Mio Unveiled Klub Class The International Automotive Scene 4 4th December 2010 09:11
SatGuide with Mio C230 Device. Intial Review. MrinalSinha Gadgets, Computers & Software 6 12th June 2009 17:15
