Old 18th March 2009, 23:30   #1
rkbharat's Avatar
Thanked: 613 Times
Default Ipod Nano, not charging from Cigarette lighter adapter
My IPOD nano is not getting charge from cigarette lighter adapter. It used to charge fine earlier.
Earlier when I used to connect to adapter, battery converts to that charging icon, but now, back light gets on, on connection but icon remains the same, battery keeps draining out.
What could be the issue?
rkbharat is offline   Reply With Quote
Old 19th March 2009, 14:18   #2
Thanked: 43 Times
Check in another car, if it charges, the cig lighter fuse in your car may have blown. If it does not, change the charging cable, it may have broken somewhere internally.
filcord is offline   Reply With Quote
Old 19th March 2009, 18:30   #3
capri_cap
Posts: n/a
check by plugging any other device in the socket to check if the socket is functional.
Try the swapping test to know the root cause of the problem.
Old 19th March 2009, 18:54   #4
rkbharat's Avatar
Thanked: 613 Times
My pda and phone is charging fine on the same socket.
Also the cable is fine because its one end is USB, and plug can be changed for cigarette lighter socket or DC power. DC power plug with the same cable is charging it fine.
Also there is a problem in USB charging from Laptop. In my one laptop where iTunes is installed, its getting charged, but no on the other laptop, where itunes is not installed. It used to work on both
Old 19th March 2009, 19:27   #5
devenashani's Avatar
Did you update the firmware on your iPod, may be apple had discontinued the working of some third party accessories in new firmware
Post EDITED since it contained various [FONT], [COLOR] and [SIZE] tags.
Posting with such text formatting should be avoided on Team-BHP as it is inconvenient for members to read post.
Kindly go through Announcements section before proceeding.
Thanking You for your anticipated co-operation
The Team-BHP Support
devenashani is offline   Reply With Quote
Old 23rd March 2009, 15:07   #6
Thanked: 43 Times
Do you mean "AC power"? Because the car cig lighter output is DC power.
Possibly the connector going into your Ipod has gone bad?
Old 6th April 2009, 17:16   #7
rkbharat's Avatar
Thanked: 613 Times
ok, here is the update, every solution failed. And the Bangalore office gave up and agreed to replace the unit with new one.
Will have to go to service center to get the new unit
Old 8th April 2009, 15:20   #8
Thanked: 43 Times
Well that's a relief - was beginning to think there was a djinn in the machine!
Of course none of us thought the Ipod was faulty!
Replacing cigarette lighter with a charger? neutralgrey Technical Stuff 31 25th April 2012 18:38
Cigarette Lighter for my bike? aveek Motorbikes 19 24th January 2008 01:17
FS:Sony Ericsson Car Charger Cigarette Lighter Adapter CLA-60 gmano Shifting gears 3 20th September 2007 19:52
indigo cigarette lighter fuse location shldn Technical Stuff 3 11th May 2006 12:17
Impact Wrench powered via Cigarette lighter, Opinions? s0uljah Modifications & Accessories 1 14th April 2006 00:03
