Old 27th March 2009, 10:05   #1
Thanked: 3,849 Times
Default urgent help needed: can the deleted data be retrieved back in the PC?
last night by mistake I deleted a folder from the hard disk containing some important data without enabling the recycle bin. I wanted to know can that folder be recovered by any trick?
I don't have any backup.
sidindica is offline   Reply With Quote
Old 27th March 2009, 10:29   #2
Meer's Avatar
Thanked: 18 Times
use undelete.exe, it can list down files which are still stored on windows. Dont shut down your machine till then.
sorry, forgot to post the link, you can google it.
I could get 1 link but could not check as such sites are barred at office:
UNDELETE.EXE - PC Advice
Last edited by aah78 : 27th March 2009 at 22:33. Reason: Posts merged. (20 min rule).
Meer is online now   Reply With Quote
Old 27th March 2009, 10:39   #3
NOTORIOUS's Avatar
Thanked: 87 Times
Paaji , first of all do not copy or write anything on that partition. then run pc inspector file recovery on that partition and recover files on another partition or pen drive.
CONVAR & PCinspector Data Recovery Datenrettung recupero dati datarecovery récupération données
NOTORIOUS is offline   Reply With Quote
Old 27th March 2009, 17:11   #4
Bass&Trouble's Avatar
Thanked: 71 Times
Without enabling recycle bin? Do you mean you did a Shift + Delete?
Anyway, I have also used PC inspector in the past. Don't write any more data till you haven't recovered the folder. I assume that the recovery is also dependent on what percentage of your concerned hard drive is in use. i.e. if it is close to full, your chances of getting all the data are lower. I have also come across many corrupt files when recovering using PC Inspector.
Old 27th March 2009, 17:16   #5
alpha1's Avatar
Thanked: 967 Times
check this simple utility:
Restoration Freeware download and review - file undelete utility from SnapFiles
The best thing about this is that it is small, and requires no installation.
This ensures that there is no overwriting over the data sectors that hold the deleted data.
Old 27th March 2009, 17:18   #6
extreme_torque's Avatar
Thanked: 1,389 Times
Did that folder contain some other scoop pictures for us? :P :P :P
extreme_torque is offline   Reply With Quote
Old 27th March 2009, 17:23   #7
NetfreakBombay's Avatar
Thanked: 352 Times
As others mentioned, its fairly easy to retrieve that data.
Make sure:
1. You are not installing too many software packages
2. You are not copying large amount of data
Old 28th March 2009, 00:44   #8
Guite's Avatar
Thanked: 180 Times
sidindica, any luck yet? You can also try "GetDataBack for FAT/NTFS".
Guite is offline   Reply With Quote
Old 28th March 2009, 14:40   #9
data retrieved with a software called EDR (forgot the link..oops)
thanks for helping guys
cheers
siddharth
Old 28th March 2009, 14:41   #10
yes, of the sidindica's V2, coming soon.
Urgent help needed. please help-Santro Xing not starting iron.head Technical Stuff 3 12th May 2012 08:27
Reliance data card goes kaput ! Help needed emkay456 Gadgets, Computers & Software 10 6th January 2009 15:29
stolen skyline retrieved with the help of internet pawan Shifting gears 5 31st March 2008 09:12
Cleaner stole car - retrieved now! sbasak Street Experiences 13 14th December 2007 11:40
