Old 12th January 2010, 02:13   #16
Thanked: 658 Times
Default UPdate! Cropping Images.
Up late we are seeing images which are scanned, uploaded and looks like following. (No offense to fellow bhpian Wasif)
Help with Resizing, Rotating and Cropping images - The easiest way-wasif-crop.jpg
Those unwanted white spaces looks ugly. What we need is to crop the images for the area what we need and then upload it. That way the thread looks much cleaner and aesthetically appealing.
Tools we will use.
I will post how to crop using two of the most common tools everybody knows about.
1. Picasa, one of many odd google products.
2. Irfanview, A brilliant image viewer create by a Bosnian bloke named Irfan Skiljan.
First we will be using Picasa.
1. Open the File in Picasa.
Name:  1 opena.jpg
2. Right Click on the image and click "Edit in Picasa"
Name:  1 openb.jpg
3. On the Basic Fixes Tab, Click Crop, Select the area you want and click Apply.
Help with Resizing, Rotating and Cropping images - The easiest way-2-crop.jpg
Help with Resizing, Rotating and Cropping images - The easiest way-2crop-.jpg
4. From the "File Menu" > Click "Save As.." and save it with a new name. (This is important in Picasa)
Help with Resizing, Rotating and Cropping images - The easiest way-3-cropped.jpg
Now same process using IrfanView.
1. Open IrfanView
2. From File Menu open the file that you wish to Crop
3. Select the Area with the mouse.
Help with Resizing, Rotating and Cropping images - The easiest way-irfan-view-crop1.jpg
4. From the Edit MenuClick Crop Selection or Press Ctrl + Y
Help with Resizing, Rotating and Cropping images - The easiest way-irfan-view-crop2.jpg
5. Save the File.
Walla!!
Application Links:
1. Irfanview
Download IrfanView
2. Picasa
Picasa 3: Free download from Google
3. Xnview, one more great application that is free and similar to Irfanview.
XnView Software - Free graphic and photo viewer, converter, organizer
Image Courtesy:
Wasif, a fellow Bhpian
Old 12th January 2010, 02:36   #17
foby.sebastian's Avatar
Thanked: 1,103 Times
I can say a quicker way to decreace the size of the image , No need of tools.
Just upload the picture to orkut , then open the picture copy it , the copied picture from the orkut will be very less in size.
If you do not want the photo in orkut we can delete it easily , or you can turn off the updates.
how does that work , have any one tried this way ?
foby.sebastian is offline   Reply With Quote
Old 12th January 2010, 03:05   #18
robimahanta's Avatar
Thanked: 1,591 Times
why waste bandwith and time by uploading pics twice..once in orkut and then again in say, tbhp. i would rather recommend using Irfan view's batch conversion tool. Its fast and versatile.
robimahanta is offline   Reply With Quote
Old 14th January 2010, 10:11   #19
Thanked: 245 Times
To add to it Xnview gives lossless image conversion which many windows tool dont provide for. I had been using Irfanview for over a decade now and moved over to Xnview few years back as Irfanview was not lossless complaint then.
Old 14th January 2010, 19:57   #20
Thanked: 57 Times
Guys, Picasa is the best of the lot. works well when u have to resize many pics in one shot. Check out the way its done.
Lemme know if any training required
livyodream is offline   Reply With Quote
Old 26th July 2010, 10:21   #21
Thanks a lot Sir.
It has solved my problem of re-sizing the pictures and helped me a lot in posting my travelogues.
greencity is offline   Reply With Quote
Old 22nd December 2015, 13:20   #22
Thanked: 945 Times
Default Re: Help with Resizing, Rotating and Cropping images - The easiest way
Rotating Image the easiest way
Open your image in Windows Picture and Fax Viewer (the default image viewer of Windows)
Thank you, Sir Alec! A link to your thread has been added to the announcement thread. I'm certain your tutorial will help many a newbie.
This is very useful - many thanks. I have come across some instances where the image is correctly aligned when I see it on my computer but shows up mis-aligned when I upload to a t-bhp post. I recently faced this on an assembly line thread that I'm working on.
Any tips on how to get around this issue? Is there also a way that you can edit / rotate a pic within a draft post on T-BHP?
Axe77 is offline   Reply With Quote
Best way to print RAW images from camera? androdev Gadgets, Computers & Software 14 11th December 2009 10:47
Rsizr - Seam carving & content aware image resizing - AWESOME! Rehaan Shifting gears 14 27th September 2009 09:29
How to tell whether electronic 4x4 is engaging : Easiest way tsk1979 4x4 Technical 18 2nd October 2008 17:23
