Old 8th April 2009, 21:21   #1
Thanked: 660 Times
Default Help with Resizing, Rotating and Cropping images - The easiest way
Tbhp is full of rarerest and rare of images all contributed by our esteem members.
But the many images uploaded are not of the right size or either they are not rotated. These happens mostly with the case of Newest members (newbies).
So this thread is to help such members. This is the easiest way of resizing images, i can not think of anything easier than this.
Tools Needed.
1. Microsoft Image resizer.
This is a nifty tools that was part of Powertoys for WinXP. but can also be downloaded seperately as a standalone. This is the best tools that Microsoft made unlike most of their other Hogs and buggy software.
Link:
http://download.microsoft.com/downlo...ertoySetup.exe
Size:
Half a Mb.
Download time.
5 seconds on 256kbps dedicated line.
How to install
After downloading just double click the .exe file and it will be installed in seconds.
Now the most Important
How to use it.
You will not notice any shortcut or links on Desktop or Start menu after the install.
1. Open Windows explorer (Winkey+E)
2. Select which .jpg you want to resize. You can select multiple file and resize.
3. Right Click images. Now there is a new option on the context menu. Resize Pictures
Help with Resizing, Rotating and Cropping images - The easiest way-image-rezise-help.jpg
4. Left click that option. You will see a pop-up window. Select the sizes you want. and click OK.
Name:  image rezise help1.jpg
5. Walla! image resized.
Help with Resizing, Rotating and Cropping images - The easiest way-image-rezise-help2.jpg
PS: Mod please merge if already exixting.
Old 8th April 2009, 21:33   #2
bblost's Avatar
Thanked: 6,978 Times
Described in the Announcements section
http://www.team-bhp.com/forum/announ...tml#post976066 (Uploading photographs directly to Team-BHP)
Old 8th April 2009, 21:46   #3
Sha
Sha's Avatar
Any good softwares for Vista and there links.
Sha is offline   Reply With Quote
Old 8th April 2009, 23:06   #4
Thanked: 660 Times
Microsoft Image Resizer PowerToy for Vista? -- Joey’s Blog
Old 9th April 2009, 09:59   #5
Thanked: 46 Times
Thanks so much. I was using Irfanview till now, but this seems to be much more convenient.
anuragn is offline   Reply With Quote
Old 9th April 2009, 23:18   #6
Thanked: 660 Times
Irfanview is also a very usefull tool. Its free and if you download the plugins pack, it can open each and every format you can ever imagine.
Another one is Xnview.
Old 13th April 2009, 17:02   #7
Thanked: 103,515 Times
Thank you, Sir Alec! A link to your thread has been added to the announcement thread. I'm certain your tutorial will help many a newbie.
Old 7th December 2009, 17:39   #8
Thanked: 660 Times
Default Image Rotation
Rotating Image the easiest way
Open your image in Windows Picture and Fax Viewer (the default image viewer of Windows)
1. Right click on your image ( i am mentioning this way because many people may have installed picasa or any other image editing soft. So .jpg etc may have been associated with it)
2. Left click Open With and from the menu select Windows Picture and Fax Viewer.
3. Now click the rotate button from the toolbar below. You may get a pop-up that warns " the resolution may decrease etc etc". Just click yes.
4. Walla! You're done.
There are many ways to rotate image but the simplest way is mentioned above.
Please do use it before posting images here in tbhp. Its very impractical to rotate Lappy or tft screen isn't it??
Image Courtesy:
Propeller, a fellow bhpian
Old 7th December 2009, 17:42   #9
.anshuman's Avatar
Thanked: 9,159 Times
I have this image resizer installed on my computer, its very easy to use.
Old 10th December 2009, 20:49   #10
Pri2's Avatar
Thanked: 88 Times
You can use the same re size feature without the application.
Right click on an image file > send to Mail Recipient > Select "Make my pictures smaller"> click on "Show more options" and select the desired size.
After the new email window opens with the attachments, copy the attachment and save it.
Pri2 is offline   Reply With Quote
Old 10th December 2009, 21:36   #11
Thanked: 660 Times
Well thats an option but you will not have the desired size. and copying it is an extra process.
Old 10th December 2009, 21:52   #12
Pri2's Avatar
Thanked: 88 Times
I agree that copying pictures will be an extra process and you won't get the desired size but you can still select the options below:
Old 11th December 2009, 00:19   #13
Thanked: 660 Times
That option will not be visible in all version of windows or if you have not installed a pop email client like outlook. In short its impractical.
Old 11th December 2009, 04:32   #14
Pri2's Avatar
Thanked: 88 Times
I would have to disagree with you on that, all versions of Windows come with an inbuilt email client.
Win 98 and XP came with Outlook Express
Windows Vista came with Windows Mail
And Windows 7 now apparently comes with Windows Live Mail
BTW, I have installed the app you mentioned and I found it to be really neat.
Old 11th December 2009, 13:50   #15
Thanked: 660 Times
i am glad that you found this way very neat.
IF you know what i mean i am talking about following.
Name:  no option.jpg
with all the comparo and research i found this to be the easiest way.
Best way to print RAW images from camera? androdev Gadgets, Computers & Software 14 11th December 2009 10:47
Rsizr - Seam carving & content aware image resizing - AWESOME! Rehaan Shifting gears 14 27th September 2009 09:29
How to tell whether electronic 4x4 is engaging : Easiest way tsk1979 4x4 Technical 18 2nd October 2008 17:23
