Old 12th April 2009, 23:08   #1
Thanked: 147 Times
Default Unable to Install JAWA!! Help!!
Guys, Had anyone tried recently downloading the Latest JAWA from the SUN microsystems website?? It downloads, it starts to install and then it comes as UNPACKING ERROR!!
Is there a way to Install JAWA apart from the SUN MicroSys website??
I did a search for JAwa but found no results.
Cyrus43 is offline   Reply With Quote
Old 12th April 2009, 23:17   #2
jithudigitised's Avatar
Thanked: 81 Times
May be you meant JAVA not JAWA.
May be the downloaded file is corrupt.BTW which java did u try java 7 ?
jithudigitised is offline   Reply With Quote
Old 12th April 2009, 23:31   #3
JayD's Avatar
Thanked: 1,999 Times
Try yezdi, i heard it has less problems than the Jawa.
On a serious note, you got no help from google because you were searching for the bike. Try java instead!
Unpacking error indicates either a broken download or a corrupt file. try some other source.
Old 12th April 2009, 23:37   #4
Thanked: 16 Times
Yes, another source or even another saving location.
Bawa is always in love with Jawa!
Hit a vawa, get a wawa!
That's more interesting.
Old 12th April 2009, 23:41   #5
karankapoor's Avatar
i think the latest is version 6, are you trying to download this or ...
karankapoor is offline   Reply With Quote
Old 13th April 2009, 00:12   #6
Thanked: 147 Times
Opps!! Spelling mistake indeed!! And Zako, as usual, u dont make any sense!!
Old 13th April 2009, 02:30   #7
pranavt's Avatar
Thanked: 273 Times
Download the offline version, which includes everything and won't connect to the net to download the rest of the installation files:
http://javadl.sun.com/webapps/downlo...BundleId=29219
Old 13th April 2009, 11:10   #8
sk456's Avatar
Thanked: 7 Times
trouble installing Java ??? ... now if it was Microsoft Dot Net i would have had some sympathies. But Java ..has to be a corrupt file. Try downloading again.. Should not have any problems.
Did you download it from here??
Java SE Downloads - Sun Developer Network (SDN)
sk456 is offline   Reply With Quote
Old 13th April 2009, 11:12   #9
Thanked: 147 Times
I have tried downloading it around 8-10 times!! Still the same issue!! I cant run Limewire now as I dont have Java
Old 13th April 2009, 11:15   #10
sk456's Avatar
Thanked: 7 Times
I hope you have a good anti virus before you use LimeWire or any other p2P application as they are famous for Spyware/trojans etc...be very careful.At least avoid doing any financial transactions from the computer/network where you have any P2P installed.
Old 13th April 2009, 11:17   #11
Thanked: 147 Times
I do have a good antivirus. Actually an excelent Antivir. I have been using Limewire since the last 4 years and have never faced a single problem.
BTW, here is the screenshot of what it says when you try and install it.
Old 13th April 2009, 11:39   #12
ph03n!x's Avatar
Thanked: 118 Times
Tell us how you are installing - there are two methods, one being the online installation (http://javadl.sun.com/webapps/downlo...BundleId=29225), which is a 221 KB file that will connect to the website to download the required components. The other being the offline install (http://javadl.sun.com/webapps/downlo...BundleId=29219), about 15.5 MB in size and will not connect to the web for installing.
If you have tried one of the methods, try the other one. Sites like filehippo also have Java's latest and the older versions (Download Java Runtime Environment 1.6.0.13 - FileHippo.com), give them a shot.
ph03n!x is offline   Reply With Quote
Old 13th April 2009, 11:41   #13
Bass&Trouble's Avatar
Thanked: 71 Times
You really are a class act.
Old 13th April 2009, 12:01   #14
nirmalts's Avatar
Hi Cyrus
Could be the stray files left over by a previous installation attempt thats causing the problem.
Did you try some steps mentioned in this forum?
java.net Forums : Error 25099: Unzipping core files ...
Nirmal
nirmalts is offline   Reply With Quote
Old 13th April 2009, 16:16   #15
Thanked: 147 Times
THANKS. LEts se how it goes.
I know.. Now You go back to snuggling Guzzlu in that Scary Wagon!!
HELP...unable to unclock my nokia fone ns_jughead Gadgets, Computers & Software 3 16th October 2006 12:53
Unable to lock the steering wheel...Help! DRC Technical Stuff 7 6th September 2006 19:05
