Old 7th May 2009, 22:02   #1
gopinathann's Avatar
Thanked: 20 Times
Default GPS Speedometer (Analog & Digital) for WM6
I have created a GPS Speedometer for Windows mobile 6 with GPS. Let me know if it works in other GPS devices.
Screenshots:
Size:  14.7 KB Name:  Screenshot_13.jpg
Size:  14.7 KB Name:  Screenshot_30.jpg
You have to rename the .gpx to .zip
GPS Speedo.gpx
gopinathann is offline   Reply With Quote
Old 7th May 2009, 22:58   #2
bblost's Avatar
Thanked: 6,716 Times
If it works on Wm 6.1, I can try it out.
Looks good.
Old 7th May 2009, 23:47   #3
vikram_d's Avatar
Thanked: 937 Times
Does not work on HTC Touch HD running Win 6.1.
Old 8th May 2009, 09:49   #4
Thanked: 135 Times
This is where my "Thank You" post gets converted to "Why me!" post!
HappyWheels is offline   Reply With Quote
Old 8th May 2009, 10:42   #5
rkbharat's Avatar
Thanked: 613 Times
looks very good, I will try it and let you know
rkbharat is offline   Reply With Quote
Old 8th May 2009, 10:43   #6
Thanked: 20 Times
I tested in my HTC P3300 (Artemis), thought it should work in HTC devices atleast. It is working in Asus devices as well.
This has been developed with Windows Mobile SDK 6. Make sure you have installed .NET Comfact Framework.
Old 8th May 2009, 11:00   #7
ashthedivx's Avatar
Thanked: 22 Times
Will give a try..
OT: You have overloaded your P3300 with applocations, whole bar is full of applications
Old 8th May 2009, 12:20   #8
d3mon's Avatar
Thanked: 584 Times
Nice looking app there. Very similar to the Civic's speedo.
Will try it out and update here.
d3mon is offline   Reply With Quote
Old 8th May 2009, 12:36   #9
Thanked: 135 Times
Nope! Does not work on the HD! :(
The setting program is throwing a 'NullReferenceException' and the main program's layout is all messed up!
Regardless, a very good effort!
Old 8th May 2009, 13:05   #10
d3mon's Avatar
Thanked: 584 Times
Is your app resolution independent gopinathann ?
I guess that may be causing trouble if it's not. Your 3300 is 320x240 while the HD is 800x480.
Old 8th May 2009, 14:44   #11
Thanked: 20 Times
Inspired by the Civic dash, I took the Civic dash image and converted like this.
Since this is my first step to develop Windows mobile application, I have targeted for QVGA device (320x240). I will try if I can do for Touch HD.
Old 8th May 2009, 15:08   #12
vikram_d's Avatar
Thanked: 937 Times
Would be great if you could get it to work on the HD.
Old 8th May 2009, 18:35   #13
d3mon's Avatar
Thanked: 584 Times
@vikram_d if you really want a speedo on your mobile, there are a lot of freewares available for it.
Google is your friend.
Old 8th May 2009, 18:42   #14
vikram_d's Avatar
Thanked: 937 Times
Oh I already have plenty of them. I just wanted to check this out for its accuracy and to encourage a fellow BHP-ian.
Old 8th May 2009, 19:09   #15
Thanked: 20 Times
Before developing this I also have googled and used many, but that does have incorrect values 4-5 km less compared to the speeometer. For this app I have converted the Knots to Km and added 4km to correct it so that it matches 99% to the speedometer at any time.
Speedometer Needle: Shaking & vibrating Styler Technical Stuff 12 21st February 2016 16:05
Universities in the US for Masters in Analog Electronics greenhorn Shifting gears 8 1st October 2008 12:37
Demand for Analog IC engineers in India? Centro-P Shifting gears 8 11th June 2008 16:58
lancer power steering & speedometer problem trashishh Technical Stuff 3 13th May 2008 19:19
