Old 4th June 2009, 16:37   #1
benbsb29's Avatar
Thanked: 3,515 Times
Exclamation Personal Computer goes into a coma
The PC at home was switched on, and was working without any issues. I logged in and entered my password, and let it log into the user profile selected.
It logged in fine, and i had moved away for a few minutes. When i returned, the PC had shut down on its own, and multiple attempts by me to power it failed. I even tried powering it by connecting it to the mains directly, but to no response.
What could be the possible cause? Am i looking at a busted SMPS or something worse?
Thanks in advance for the help.
benbsb29 is online now   Reply With Quote
Old 4th June 2009, 16:41   #2
sammyboy's Avatar
Thanked: 340 Times
Electric shock therapy Works in movies most of the time.
CLEAR ...pppfffftttttttt, CLEAR .....ppppfffftttttt (use another power outlet though)
lol kiddin. Did you check if the power outlet is fine by connecting some other appliance to it? Also did you try connecting it to some other outlet? Basics but I have been fooled by this once. Is the monitor also blank or is that powering on?
sammyboy is online now   Reply With Quote
Old 4th June 2009, 16:49   #3
yzfrj's Avatar
Thanked: 118 Times
Sounds like a kaput SMPS, however did you try removing/re-attaching
The power connector cable to the SMPS.
Power cable from the SMPS to the Motherboard.
All other cables HDD and other stuff.
All motherboards now a connector from the cabinet (for the power switch and led's)
Try reconnecting this too.
Also remove and re-insert RAM.
My nutty PC does the same and some/all of the steps usually resolves the problem.
yzfrj is offline   Reply With Quote
Old 4th June 2009, 16:50   #4
aaggoswami's Avatar
Thanked: 1,436 Times
If your mobo as switch for clearing CMOS, do that.
Else take out the BIOS cell from mobo, take out the power code from SMPS. Now keep the power button on the CPU case for around 30 sec. to drain the capacitors. After around 5 mins, insert in the BIOS cell and connect the power connector to SMPS.
Now try booting.
Also after the screen had gone, and when you tried bootig up, did the fan on processor come ON. Was the heat sink on northbridge getting a very hot or was not getting hot at all ? I mean was it lower or higher than what it is regularly.
Do you have on board graphics and then have you added graphic card ? If on board graphics is available and if you have graphic card, then disconnect graphic card and then try again to get display from onboard graphics.
Check all the cables like the VGA cable and monitor power cable.
aaggoswami is offline   Reply With Quote
Old 4th June 2009, 17:00   #5
Thanked: 190 Times
By the given description it looks like there is an issue with the SMPS due to power fluctuation you can try the following basic Trouble shooting steps
1) Check for the power supply mains & power cable
2) After switching On check if the SMPS fan working if no then SMPS has gone phut, try replacing …else
3) Check the power supply connections on the Motherboard
4) Check the CMOS battery, if battery is low/dead then PC might not boot.
5) Clean the RAM & reinstall
6) If it doesn’t work then you may have a possible Mother board issue
Try good luck
tj123 is offline   Reply With Quote
Old 4th June 2009, 22:07   #6
Thanked: 658 Times
Possible cause.
1. Power outlet loose
2. SMPS
3. CPU cooling fan kaput.
Old 4th June 2009, 22:12   #7
condor's Avatar
Thanked: 4,412 Times
first step :
Take it out & place it so you can see the smps fan.
switch it on.
if fan momentarily starts & then stops, then smps is mostly not the culprit.
open up, disconnect every thing else from mother-board.
switch on pc
check fan behaviour. if it runs, mother-board fine.
if it does not, take out memory - and keep just one module.
re-test as above.
now start with the other parts, harddisk first ..
Old 4th June 2009, 22:52   #8
greenhorn's Avatar
Thanked: 1,422 Times
any beeps ? any lights on the motherboard/smps fan running/any signs of activity?
else , its probably a busted SMPS.
be careful. If the SMPS was killed by a faulty mobo or other equipment, they can kill the new SMPS too.
alternately, when SMPS die, they leave a trail of destruction. Pray that nothing else (esp mobos and HDD's) are busted
greenhorn is online now   Reply With Quote
Old 5th June 2009, 10:21   #9
benbsb29's Avatar
Thumbs up Issue resolved
Thanks for all your responses, guys. They were quite helpful.
As was evident from most of the responses, as well as my hunch, the SMPS looked to be the main culprit. A friend of mine replaced the SMPS with a working one from his comp, and the issue was resolved. I would be getting him a replacement SMPS.
Thank God, it was nothing beyond this.
The PC is powered from a Microtek UPS, and has been giving 3 years of useful service. Could the SMPS failure be linked to its own natural lifespan or would i need to further protect it using some spike protectors?
Old 5th June 2009, 10:37   #10
esteem_lover's Avatar
Thanked: 447 Times
Check your Microtek UPS' voltage outputs in all its outlets.
Old 5th June 2009, 13:21   #11
rjstyles69's Avatar
Thanked: 791 Times
Benny I hope you weren't trying all this during a power cut ?
Old 5th June 2009, 14:58   #12
benbsb29's Avatar
The power spike experienced scenario cannot be replicated right? So how will this help?
Riju, if only i wasnt that smart.
Old 5th June 2009, 15:00   #13
mobike008's Avatar
Thanked: 8,035 Times
OT: I too have a weird problem with my home PC. First time i boot, I can browse any website for whatever time i wish, but the minute i use the keyboard to type my first letter, it just hangs.
I re-boot and then it works perfectly. This happens everytime I use that PC.
Is it haunted?
Old 5th June 2009, 15:16   #14
NetfreakBombay's Avatar
Thanked: 352 Times
Is this a USB keyboard ?
Old 5th June 2009, 15:17   #15
Raccoon's Avatar
Thanked: 105 Times
Beware of UPSs! My Powercom UPS smoked my SMPS and memory too. It possibly affected the life of other components too. Using such UPSs is more risky than not using one at all!
Most spike protectors are also of dubious quality. Often the cease to be useful after a strong spike.
APC UPS is the best for filtering.
Michael Schumacher in critical condition. UPDATE: Out of coma and back home! Gannu_1 Shifting gears 171 3rd January 2018 11:50
Honda FCX Clarity goes into Production aajtaksabsetej The Indian Car Scene 1 11th November 2008 15:31
Help my computer screen goes pink intermittently rahul_intlad Gadgets, Computers & Software 17 17th July 2007 14:01
Bugatti 16/4 Veyron goes into Production!! Stratos The International Automotive Scene 17 5th November 2005 17:51
Maruti goes filmi to move Swiftly into focus johnjacob The Indian Car Scene 16 2nd March 2005 11:13
