Old 10th June 2009, 20:11   #31
Technocrat's Avatar
Thanked: 2,501 Times
Oh Ok like I said I am quite a newbie here
Thanks for pointing to the place, I will check it out, is it the same one that's near Mahesh Lunch home?
Old 10th June 2009, 21:05   #32
pranava999's Avatar
Thanked: 19 Times
Originally Posted by Technocrat View Post
Hmm thanks for all the info guys & thanks pranav for starting such a nice thread (Sorry pranava99 for hijacking your thread )
If I go for proper floor speakers I will only power them with a separate amp. I just wanted to know which one would count as an upgrade from my current HIfi system & since those speakers are quite close to book shelf speakers, I am under impression that upgrading to shelf speakers wont be as good as upgrading to floor speakers.
Hey no issue at all mate. Please go ahead and make this thread your own. I get to learn stuff as well and gets me thinking of options....
pranava999 is offline   Reply With Quote
Old 11th June 2009, 12:39   #33
navin's Avatar
Thanked: 3,925 Times
Originally Posted by pranava999 View Post
Guess the Norge bookshelves are rules out. Their impedance is 4 ohms while the yam's imp is 8
which ones. the 6" way I saw were supposed to be 6 ohms.
Floor standers have more box volume. This means that they are usually more sensitive and go lower.
Old 11th June 2009, 15:07   #34
bigron's Avatar
Thanked: 249 Times
Floor speakers are actually the anchors of a 5.1 set up.A pair of good tower speakers will actually compensate to a small extend a need for a sub..
bigron is offline   Reply With Quote
Old 11th June 2009, 15:22   #35
Thanked: 388 Times
Given the requirement and budget are these iBall Tarang speakers too bad ?
Any comments on Sound Quality etc ? Or they are too low to be even discussed here
eBay India: iBall Tarang 5.1 Channel Home Theatre Speaker + REMOTE (item 250441019250 end time 16-Jun-2009 20:18:39 IST)
8 ohm impedence matches the amp Max RMS is 20W so you should not give play full volume but it is a small bedroom.
amitk26 is offline   Reply With Quote
Old 11th June 2009, 15:43   #36
pranava999's Avatar
Thanked: 19 Times
I looked up their website and both bookshelf and the towers are rated 4 ohms.
Old 11th June 2009, 22:12   #37
bigron's Avatar
Thanked: 249 Times
amit: i think you should avoid them completely if you remotely like your sounds.But if budget is a major constraint and you absolutely must have a 5.1 setup options are really limited in that case.
Kumaon: roads less traveled and forests less visited nilanjanray Route / Travel Queries 21 11th January 2013 12:25
GM India - Hope less? or Aim less? or both? rnidumolu The Indian Car Scene 16 17th September 2012 15:12
ICE Upgrades for Verna SX - Budget 15K, Amp, Speakers and Sub newcoolgadgets In-Car Entertainment 3 21st September 2009 16:04
Help with DIY 3 way speaker setups for fronts greenhorn In-Car Entertainment 17 25th March 2009 14:21
Best Sub Woofer Setup within 15K gemithomas In-Car Entertainment 9 1st March 2008 11:08
