Old 5th October 2009, 13:19   #181
akshay_b's Avatar
Originally Posted by sonirohit View Post
I got a 4.3" version with BT & FM X'mitter, I am yet to customize it - got all the required softwares & maps, MMI, OneIndia, & others - will keep posted how it goes.
Where did you find the softwares and MMI maps?
akshay_b is offline   Reply With Quote
Old 5th October 2009, 14:12   #182
sonirohit's Avatar
They are on this thread -
http://www.team-bhp.com/forum/gadget...ml#post1483972
sonirohit is offline   Reply With Quote
Old 5th October 2009, 22:40   #183
archat68's Avatar
Thanked: 238 Times
What about this one guys? The difference is only 0.2 inch in screen dimension but price difference is quite considerable:
DealExtreme: $84.00 4.8" LCD 372MHz CPU Windows CE .NET 5.0 Core GPS Navigator + 2GB Maps SD
archat68 is online now   Reply With Quote
Old 5th October 2009, 22:49   #184
NetfreakBombay's Avatar
Thanked: 352 Times
Don't go only by specs. Check use reviews for each unit (SKU).
Dealextreme is just a supplier and units have varying levels of hardware quality.
Old 5th October 2009, 22:50   #185
I also ordered sku.23569 since Tushar has already tried and tested this one.
I am already using garmin 255w with navteq maps so wanted a generic device to try other options..
Guys how much time does it take to acquire satellites on cold start?
kekada is offline   Reply With Quote
Old 5th October 2009, 22:58   #186
sonirohit's Avatar
Originally Posted by Tushargohil View Post
Reason :- You need YFGo2CE.bld to get Wince mode upon reboot.. now if you create *.bld file under any other memory card your device wont go in to wince mode.
Thanks,
Tushar
I formatted this mem card and created a *.bld file with 4 bytes - it booted fine with it...
Old 6th October 2009, 00:33   #187
akshay_b's Avatar
It doesn't have bluetooth and FM transmitter. Its fine if you have a tight budget.
Old 6th October 2009, 07:21   #188
Tushargohil's Avatar
Thanked: 71 Times
Default Bld
Even if you use new memory card other then factory default still you are able to boot ?
Thanks,
Tushar
Tushargohil is offline   Reply With Quote
Old 6th October 2009, 07:26   #189
Thanked: 71 Times
Default Cold Start.
It takes around 2-3 minute max upon cold start (Tested on different bud rate)... but again let me clarify here i use direct wince mode and starting apps manually as my concern was CPU/memory usage on this device.. if i load default menu it takes bit high CPU/memory usage and result when ever i use destinator8 for POI, system popup for out of system resource..
Thanks,
Tushar
Old 6th October 2009, 11:15   #190
sonirohit's Avatar
Thanks,
Tushar
I've not tried it -
I don't need to boot into win ce anymore - I've got a new skin, in which there is a program icon for WinCE...
Old 6th October 2009, 11:20   #191
sonirohit's Avatar
Anyone had success here getting garmin or satguide running on their DX PNDs?
I was able to get MapMyIndia Navigator and PolNav running - MMI is great, POLNAV has really crappy maps....
I've had no sucess getting Garmin & SatGuide stuff to work on my device :(
Old 6th October 2009, 11:31   #192
Thanked: 71 Times
Default Skin,
I've not tried it -
Yes but did you noticed that CPU/MEMORY usage is high...
I am using Garming Mobile XT 20W and Destinator 8 on DX PND.
Thanks,
Tushar
Old 6th October 2009, 12:50   #193
srishiva's Avatar
Thanked: 837 Times
For SatGuide, you may have to change the port and baud rate settings
srishiva is online now   Reply With Quote
Old 6th October 2009, 13:52   #194
sonirohit's Avatar
Finally got the SatGuide working on my PND too Issue was an incorrect destcore.dll
Only one left now is Garmin....
Old 6th October 2009, 14:18   #195
srishiva's Avatar
Thanked: 837 Times
Anyone wishing to install Miopocket for this device? I will try it during this week.
Tata comments on British Work Ethics ! But what of Work-Life balance ? mooza The International Automotive Scene 69 27th March 2013 00:47
VOXTEL launches PND dilipkumar7278 Gadgets, Computers & Software 3 11th January 2008 21:29
Will GPS work in India ? falcon Modifications & Accessories 13 27th September 2006 00:02
