Old 27th October 2009, 11:41   #301
the_maassk's Avatar
Originally Posted by NetfreakBombay View Post
I think sunfilm on windscreen is spoiling the signals. As tsk mentioned, external antenna is most obvious option.
Given that this unit does not have a port for antenna, you can try finding some spot in car that has better signal reception.
But overall it should not be a problem. If you are out of city keep the unit outside car for 5 mins so that it gets the fix. Once it locks on satellites it should work.
Thanks guys for the inputs. I'll explore the option of an external antenna and while I do that, let me see if there is a way of 'force feeding' Ephemeris data to the device through software on the Win CE platform. I am aware that I may be beating around the bush with this - but there is no harm trying. I might just stumble onto something
the_maassk is offline   Reply With Quote
Old 27th October 2009, 13:40   #302
wildon's Avatar
Thanked: 1,062 Times
Just received my unit. here are the initial pics. As someone said earlier its opened, examined, repacked and delivered it to me.
wildon is offline   Reply With Quote
Old 27th October 2009, 19:38   #303
akshay_b's Avatar
Thanked: 11 Times
Originally Posted by the_maassk View Post
Finally received my unit yesterday evening . MMI loaded, Garmin loaded, installed Vishek's BlackRedEdition menu. Everything works - except for bluetooth audio being routed to FM. Not a biggie though!
Buying a 16GB card today evening and will then load up some test videos to figure out the best encoding parameters for this device.
Next in line is Miopocket
Originally Posted by akshay_b View Post
That's good news, Did it come to your house? Were you able to track it when it reached India?
When did you order yours? How did you find out that it reached India? Mine departed HK on 15th, any idea when i will get it?
Could you answer me )
akshay_b is offline   Reply With Quote
Old 27th October 2009, 19:53   #304
wildon's Avatar
I ordered it on 18-09-2009 . Item Shipped from DX store on 27-09-2009, Item left HK on 6-10-2009 (as per Hongkong Post tracking), after several call to FPO Bangalore finally confirmed that Item reached here in India on 23-10-2009, and due for custom clearance and checking/repacking. Today 27-10-2009 received the item to my address. I hope you got the answer.
Update:- Now my GPS unit runs on custom menu i.e GPS_Menu_Pez_ver2.0
Can any one tell me whether Destinator 8.0.20.21.1 works with MapmyIndia 200909 map , if so how and where to put the map?
Old 27th October 2009, 19:57   #305
vivekiny2k's Avatar
Thanked: 184 Times
Normally your unit sees the satellites through the windscreen, and roof is opaque to it.
So lets say you start moving, and your unit sees satellites 4,7,18,22
ITs trying to get positon fix using them.
I don't think GPS devices need direct line of sight. they work on radio frequency. My GPS works well even indoors. of course it's not as accurate because of waves bouncing from walls etc.
vivekiny2k is offline   Reply With Quote
Old 27th October 2009, 20:13   #306
akshay_b's Avatar
Thanked: 11 Times
Thanks for the info buddy, My GPS was ordered on 2nd of October and left HK on 15th of October, I'll have to wait for 9-10 more days
I guess i'll get it sooner if i collect it from the foreign post directly. I would've got it sooner if they sent it through a marathon walker
Old 27th October 2009, 20:29   #307
wildon's Avatar
in my case the FPO person said i cant collect it directly from them so i had to wait for couple more days.
Old 27th October 2009, 20:54   #308
NetfreakBombay's Avatar
Thanked: 408 Times
Destinator works with Satguide maps. MMI uses a different software (Miero viaGPS)
Old 27th October 2009, 23:17   #309
akshay_b's Avatar
Thanked: 11 Times
Is there anyway that i can track the shipment online after it reaches India?
Oh, and Tushargohil's package wasn't opened.
Old 27th October 2009, 23:22   #310
Thanked: 408 Times
Online tracking did not work for me. Had to call them to get status.
Old 27th October 2009, 23:45   #311
wildon's Avatar
hm.... tried with Miero viaGPS & MapmyIndia 200909 map combi and its working. Done a quick drive through ORR and came back home now.
Take me home feature worked great .
Can any suggest which is best combination of software & map for India?
Old 28th October 2009, 02:09   #312
Default Using my Garmin StreetPilot
Friends,
I'm not aware of the GPS scene in India. Also, I'm not too techie. So please be easy on my post.
I'm currently using a Garmin StreetPilot C330 in the US. It has a slid for sd card but since the maps are already loaded, i didn't bother much.
I'm planning to bring my unit when I come back to India.
1. I assume a Garmin StreetPilot will work in India.
2. I have the maps from MapsMyIndia.
Now, how do I install these maps in a SD cards and use the gps when I'm in Bangalore.
Is there anywere I would refer or is there someone whom I can communicate with offline on this.
Thanks.
Chandra
chandras is offline   Reply With Quote
Old 28th October 2009, 09:17   #313
the_maassk's Avatar
I was not able to track it once it left HK. The tracking number did not show up any results on the Indiapost website! I just waited and kept calling the local post office a couple of times. I was delivered to my house. It took exactly 36 days to reach after I had ordered it on the website. From the day it departed from HK, it took 25 days.
Can't really tell when should you expect it. Just wait and watch!
Old 28th October 2009, 09:20   #314
the_maassk's Avatar
Have tried quite a few mapping apps on this. The best I found is MMI maps with its application. Has plenty of good features and the turn-by-turn navigation works great too!
Old 28th October 2009, 09:33   #315
Thanked: 408 Times
How much did you pay for MapMyIndia maps?
These maps come in an SD card. So no need to install.
1. Just remove current SD card from your device
2. Put in card that MapMyIndia sent you
India maps would show up in few mins.
StreetPilot maps are on internal memory. So removing current SD card would not impact maps that are already on device.
Tata comments on British Work Ethics ! But what of Work-Life balance ? mooza The International Automotive Scene 69 27th March 2013 00:47
VOXTEL launches PND dilipkumar7278 Gadgets, Computers & Software 3 11th January 2008 21:29
Will GPS work in India ? falcon Modifications & Accessories 13 27th September 2006 00:02
