Old 28th October 2009, 09:37   #316
JVH
JVH's Avatar
Thanked: 148 Times
Some questions -
  1. How can we procure MMI maps? Do they have an outlet in Bangalore?
  2. Is replacement of MMI SD card is all that is required in the device for it to read? Am I missing something on the unlocking part?
Thanks!
JVH is offline   Reply With Quote
Old 28th October 2009, 09:59   #317
NetfreakBombay's Avatar
Thanked: 352 Times
Device need not be unlocked to add new maps. Adding the new SD Card will add new maps.
Old 28th October 2009, 11:26   #318
JVH
JVH's Avatar
Thanked: 148 Times
Thanks!
If I'm not wrong, this SD costs 7K right?
Old 28th October 2009, 11:39   #319
wildon's Avatar
Thanked: 1,057 Times
Originally Posted by ms001 View Post
is it possible for you to upload screen shots and video?
the MMI 2009 is has to be purchased or can be?
Will take a Picture and video next time if some one travels with me. I used the MMI 2009 which is unlocked.
One things i tell you MMI is clueless when it comes to Flyovers at least in Banaswadi /ORR Ramamurthy nagar etc which i have traveled. rest is good with lots of POI. Have to explore it more and will update you the same.
wildon is offline   Reply With Quote
Old 28th October 2009, 15:31   #320
ampere's Avatar
Thanked: 8,760 Times
Originally Posted by JVH View Post
Thanks!
The 7K amount is for the maps that you buy from MMI. They should be sending you an SD card, with the key. You insert it into the slot and it should work.
Old 28th October 2009, 15:32   #321
ampere's Avatar
How is the Satguide experience in Bangalore?
Old 28th October 2009, 15:39   #322
wildon's Avatar
Destinator 8 installed and have to install the map for the same from Satguide. Only after that i can comment on that.
Old 28th October 2009, 15:49   #323
JVH
JVH's Avatar
Thanked: 148 Times
Thanks.
Planning to buy the same. Is 7k worth it?
Old 28th October 2009, 16:28   #324
ampere's Avatar
Thanks.
That is precise question that I am trying to get an answer! No luck yet.
Satguide is 2K and potentially I have not heard anything against it. Also the numbers of cities they cover is same as MMI.
@Wildon,
I have doubt then. Why you need all these installations (destinator). I checked with Satguide folks. They mentioned, if you have a Garmin device, all one needs is to add an SD card which they provide and it will work out of the box. Where then the destinator part comes in? Is it that one needs to upgrade the Garmin firmware?
Old 28th October 2009, 16:39   #325
vishaltanksale's Avatar
Thanked: 17 Times
Destinator is Satguide GPS application and you can run satguide maps on it. Satguide also provide their maps on Garmis GPS application as well as Windows based GPS application.
From whaterver I have heard, Destinator is not very user friendly when compared to Garmin (it is supposed to be very good). I use Garmin apps and Garmin map on Nokia 5800 and its pretty good, but have nver really tried any other application, so cant compare.
vishaltanksale is offline   Reply With Quote
Old 28th October 2009, 18:17   #326
wildon's Avatar
@Wildon,
I have a DX unit which came with igo8, now the unit is unlocked, so i can put any software/map which support windows CE system. Presently i have loaded MMI navigator and its MMI map, just wanted to try Destinator/Satguide map to know which is better on the same routes where i m travelling.
Old 28th October 2009, 19:09   #327
Thanked: 352 Times
In my opinion, its is not worth 7k.
SatGuide sells maps for 2k. MMI does not have anything that warrants more then 3 times premium.
Old 29th October 2009, 11:15   #328
wildon's Avatar
Originally Posted by Tushargohil View Post
Guys,
So far below tool tested and working fine..
M a p m y I n d i a Navigator 2009 M i r e o B l a c k Edition and G a r m i n City Navigator India 2009 NT Q4 2009 Q4 loaded...
Thanks,
Tushar
MMI NAVIGATOR and DESTINATOR 8 works fine now but Garmin XT having problem while doing the port settings.
Do you have the solution for this
Old 29th October 2009, 13:49   #329
akshay_b's Avatar
Got my GPS today here are the pics.
Could someone help me install maps for india?
akshay_b is offline   Reply With Quote
Old 29th October 2009, 14:40   #330
sgiitk's Avatar
Thanked: 3,794 Times
Infractions: 0/1 (5)
I feel one aspect is being totally neglected. In a GPS (like computers, if you work legit) the cost of the software (maps here) far exceeds that of hardware. So this is the area we should consider. The hardware is almost an appendage to the software.
Tata comments on British Work Ethics ! But what of Work-Life balance ? mooza The International Automotive Scene 69 27th March 2013 00:47
VOXTEL launches PND dilipkumar7278 Gadgets, Computers & Software 3 11th January 2008 21:29
Will GPS work in India ? falcon Modifications & Accessories 13 27th September 2006 00:02
