Old 14th September 2010, 09:06   #526
anujmishra's Avatar
Thanked: 338 Times
Default Free Solution on Cheap DealExtreme PND
One news to update all of you.
Yesterday, I was searching some free solution to run on PND received from DealExtreme. I found this page Gosmore - OpenStreetMap Wiki .
I read WinCE section and downloaded all recommended components. Exe and PAK (Map file) etc and copied into device. Gosmore works on OpenStreet map and can be downloaded free from Internet. Voila, it was working. All free solution on cheap dealextreme device.
But...
1. Quality(UI) of software is not good. But that much you have to bear if you want to have Free Solution.
2. I am not sure OpenStreetMap covers all cities of India or not.
However, for me it is not permanent solution, I will go with SatNav map. I just informed here for your information.
PS: There is one more free yet comprehensive navigation software. Url is http://www.navit-project.org/ . Have anyone tried it?
anujmishra is offline   Reply With Quote
Old 14th September 2010, 09:09   #527
tsk1979's Avatar
Thanked: 15,682 Times
Try OSmtracker too. It advertised to work in windows mobiles, but it works on windows CE too!
Old 14th September 2010, 09:30   #528
anujmishra's Avatar
Thanked: 338 Times
Sure, today evening I will try and update result here.
I realized that I can keep various navigation software and maps in my device and any one can be used upon requirement.
Old 14th September 2010, 11:07   #529
tsk1979's Avatar
Yes, anuj you can do that.
Infact you in stock dealextreme setup, you just have to change navigation path.
If you copy miopocket to your SD card, and then give miopocket executable as nav path, and do settings as "start navigation automatically", you will boot in miopocket shell. Its a full fledged windows CE shell.
Old 14th September 2010, 11:43   #530
anujmishra's Avatar
Thanked: 338 Times
Thanks Tanveer, you have loads of knowledge about navigation devices. I am getting surprises that how much I can do with dealextreme PND. Thanks again.
Old 14th September 2010, 12:09   #531
tsk1979's Avatar
Anuj,
Here is a miopocket link
Download it
GpsPasSion Forums - MioPocket 4.0 (Unlock for GPS devices)
After that look at the readme. There is a section on "Dealextreme and other chinese GPS systems".
Apart from that, I have seen that windows 7 sometimes screws up the firmware. So never connect the GPS to the PC, just take out SD card and connect to the PC.
Also from dealextreme Wiki, download the firmware, and keep it somewhere safe.
If you do manage to corrupt the firmware somehow, all you need to do is run a restore from the firmware dump.
The process is simple. Copy both firmware files to your SD card root, pop in SD card, and reboot device.
Old 14th September 2010, 14:05   #532
DerAlte's Avatar
Thanked: 2,877 Times
... windows 7 sometimes screws up the firmware ...
Strange. Why would it do that? What would it do? The PND should / would appear as USB storage, which means unless specifically told / instructed to write bytes to a specific area (Explorer can't do that by itself), one should be safe due to the inherent safety of the USB interface.
Old 28th September 2010, 14:56   #533
maverick555's Avatar
Hi All
i have a Mio C310 Digiwalker unit lying unused with me.
Can i use it in india and also what is the process for updating indian maps ?
maverick555 is offline   Reply With Quote
Old 28th September 2010, 15:13   #534
tsk1979's Avatar
First you need to install miopocket on SD card.
gpspassion.com forums(go to mio section) have detailed info on howto.
This step will unlock the PND which will enable you to run any software you want.
After that all you need to do is buy commercial maps, or use openstreetmap maps for free.
Old 28th September 2010, 21:20   #535
@tsk1979
Thanks for the info.
i have installed mio pocket.
what is best option for buying india maps (price and coverage) ?
How is the rs 999/- maps option from mymap india and will i be able to use them on miopocket?
Old 28th September 2010, 23:10   #536
AnkitPrashar's Avatar
Thanked: 30 Times
hello
I too am buying a WIN CE 5.0 gps device.
What i don't understand is that after i install Mio-pocket, which software do i need to install in order to run the Maps provided by MMI or satguide.
AnkitPrashar is offline   Reply With Quote
Old 29th September 2010, 09:20   #537
NetfreakBombay's Avatar
Thanked: 352 Times
You can install Garmin Mobile XT. With this, you can use either MMI or Satguide maps.
Old 29th September 2010, 09:42   #538
If i buy maps from MMI or Satguide to use with Garmin XT ,will they send me a pre installed memory card ?
Old 29th September 2010, 09:49   #539
Thanked: 352 Times
Yes, you will get a MicroSD card with SD adapter. Maps are tied to the card.
You need to setup Garmin XT on the same card.
Or you can call them and ask for the file that will make it work on one particular device (instead of being tied to card). They will need device ID.
Old 29th September 2010, 10:48   #540
shankar.balan's Avatar
Thanked: 5,331 Times
yup netfreak is right
it is a little SD Card which is pre-loaded with India maps and so on.
All you need to do is to slot it into the slot provided on the device and then switch on and switch off.
this is what i experienced with my Nuvi 205W and MMI Maps SD Card.
Tata comments on British Work Ethics ! But what of Work-Life balance ? mooza The International Automotive Scene 69 27th March 2013 00:47
VOXTEL launches PND dilipkumar7278 Gadgets, Computers & Software 3 11th January 2008 21:29
Will GPS work in India ? falcon Modifications & Accessories 13 27th September 2006 00:02
