Old 18th August 2009, 13:47   #1
ramki067's Avatar
Thanked: 25 Times
Question Installing Windows XP on a 400 Mhz PC!!!
Hi guys,
I tried installing Win XP SP3 on my old 400 Mhz Celeron PC yesterday, OS installled fine but i got an error stating "CPU doesn't have minimum requirement. XAudio2 not installed". And after a i clicked on OK button it installed fine, but i couldn't here any audio after playing a song. Any suggestions on bringing up the audio?
Thanks,
Ramki.
ramki067 is offline   Reply With Quote
Old 18th August 2009, 13:53   #2
ashthedivx's Avatar
Thanked: 22 Times
Buy a new sound card and install
Old 18th August 2009, 13:53   #3
Thanked: 7 Times
Not sure if XAudio2 supports older CPUs. Please identify the audio card & install correct drivers. Atleast DirectSound should work.
diabloo is offline   Reply With Quote
Old 18th August 2009, 13:57   #4
ramki067's Avatar
Thanked: 25 Times
The sound card is built in the motherboard. How do i identify which sound card it is?
Old 18th August 2009, 14:03   #5
greenhorn's Avatar
Thanked: 1,462 Times
google for the details of the motherboard. Alternately, just post its name here, and we'll do it for you
Old 18th August 2009, 14:07   #6
Thanked: 7 Times
Try Mobo website and get latest drivers. Also, this tool might help: Unknown Device Identifier - Freeware Download
Old 18th August 2009, 14:17   #7
ramki067's Avatar
Thanked: 25 Times
Thanks will try it today evening and get back to you guys. Cheers
Meanwhile, this is the exact error i'm getting in the pop-up window:
Title: Microsoft XAudio 2
Text: CPU does not meet minimum requirement; Streaming SIMD Extensions support required.
Options: OK
RAmki.
Old 18th August 2009, 16:17   #8
devarshi84's Avatar
Thanked: 119 Times
have you thought about overclocking the cpu? It will help a lot in smoothening and quickening the daily usage.
I still have a running P2 desktop with me in good condition which is used daily.
devarshi84 is offline   Reply With Quote
Old 18th August 2009, 16:52   #9
ph03n!x's Avatar
Thanked: 119 Times
Boy! Are you torturing ya self
I have used XP right from a 450 Mhz Celeron with 128 MB of RAM- but I will only make my enemy install and use XP on the same system again
XAudio is an API (similar to OpenAL- in functionality), and is really not needed for sound to work. Make sure you do not have any ! or ? on your device manager, and you have the sound card installed.
ph03n!x is offline   Reply With Quote
Old 18th August 2009, 18:23   #10
Thanked: 658 Times
there are version of XP (stripped) floating all over the net for such slow machine. It was called Tiny XP.
Old 18th August 2009, 21:19   #11
devarshi84's Avatar
Thanked: 119 Times
not just one but many versions of XP stripped. I dont know if we should be posting such information as it supports piracy.
Old 18th August 2009, 21:31   #12
benbsb29's Avatar
Thanked: 3,532 Times
Isnt it necessary that XP SP2 should be installed for the sound to work?
Old 18th August 2009, 21:43   #13
Thanked: 658 Times
yeah if its HDA.
Old 18th August 2009, 21:54   #14
ramki067's Avatar
Thanked: 25 Times
Mine is an HDA disk!
How do i reinstall SP2 when SP3 is present, as system is hanging when tried to install SP2.
Thanks,
Ramki.
Old 18th August 2009, 23:17   #15
Thanked: 658 Times
HDA as in High Definition audio and not remotely related to HDD.
Core 2 Duo - E8400 shows 2000 MHz in CPU-Z ntomer Gadgets, Computers & Software 13 11th September 2014 16:42
Copying large number of folders from windows XP to windows 7 laptop tsk1979 Gadgets, Computers & Software 28 18th June 2010 22:47
HELP!! installing windows xp without cd-rom drive. clipto333 Gadgets, Computers & Software 19 23rd June 2007 19:41
