Old 13th March 2009, 15:44   #1651
ariendj's Avatar
Thanked: 83 Times
is there any chance that laptops will cost cheaper post budget!!
ariendj is offline   Reply With Quote
Old 15th March 2009, 14:14   #1652
gendarmee's Avatar
Thanked: 22 Times
Facing a problem for the last 2 hours since i used a usb card for transfering data to the pic. The comp wouldn't eject the USB device so u directly unplugged it after trying to eject it 3 dozen times.
Now, if i right click a file or shortcut item the hour glass shows up and persistently stays for as long as i dont restart the computer, and whilst that shows the computer is hung, Cant click anything nor does the windows key work. However, the ctrl+alt+delete combo works and also alt-tab works.
If i right click an item in a folder i can close the unresponive folder from task manager but if its the desktop there is no means of doing that except restarting the machine.
Half of the installed programs have stopped working since, like ccleaner was installed but now the desktop shortcut shows that the link is non-existant. Also, Tune-up's manager lists most of the windows programs as unrecognised since that event.
I tried installing Cleaner again, but it wont run. Tried intalling Avast antivirus, but the machine re-starts everytime the setup is run.
Nothing was wrong until 3 hours back...Also, i was hibernating the system from the last 2 days and had uninstalled kaspersky a week ago.
Any suggestion as to how i probably could fix the machine w/o reloading the OS.
-I'd disabled restore points a month ago whilst removing Isys32.exe(cutephoto.exe) virus.
gendarmee is offline   Reply With Quote
Old 15th March 2009, 15:28   #1653
gendarmee's Avatar
Thanked: 22 Times
its some Wow virus i guess, AVG calls it a trojan. The Desktop didnt have any anti virus on to protect it when i plugged in the card.
-> is it possible to clean the trojan?
->the desk top re boots when i try to run Avast setup.
->Most system maintainence .exe files like cleaner ect are defunct now and cant run them after installation.
i'm attaching a snap shot of a search with wow.
I cant re-install windows are i have critial data on the C drive.
I'm able to use other functions on the computer though. Mozilla gtalk, yahoo ect ect work perfectly fine.
Can any
Old 15th March 2009, 15:33   #1654
gendarmee's Avatar
Thanked: 22 Times
can some one suggest how to go about deleting the virus and if the attached pic has a virus name or a regular system file.
sorry for dual posts, im not able to edit post.
Old 15th March 2009, 15:46   #1655
gendarmee's Avatar
Thanked: 22 Times
the virus is called sality and not wow.
Any suggestions as to how to remove it?
Cant run any .exe based files.
Can mod please merge my posts. im not able to edit my posts at the moment.
Old 15th March 2009, 18:28   #1656
Thanked: 253 Times
Gendarmee, I think the only option is to prepare a Mini-Personal Environment CD, like BartPE. Boot into the miniPE and manually erase some of the critical virus files.
You could plug in your HDD into another computer as a secondary drive and do the needful.
Old 15th March 2009, 18:58   #1657
gendarmee's Avatar
Thanked: 22 Times
Thank you for the reply.
I've found information about the virus files and where they probably be located on the system, but cannot locate them on the system manually. Ran a search with the file name after disabling the hidden files/system files too but it didnt help..
Old 15th March 2009, 19:33   #1658
Thanked: 253 Times
Then the best option would be to take your HDD to another computer and run a cleaning tool on drive:\(whatever your C shows up there as).
Old 15th March 2009, 19:55   #1659
gendarmee's Avatar
Thanked: 22 Times
No option but to do that, if the tool doesnt detect anything i can aleast copy the important files. worse case scenario- is the only option now.
One last question, how could i stop the other computer from spreading it? doesnt show any signs of infection but is spreading it. neither AVG or spyware doctor detect it.
there's a file, pagefile.sys, on the c drive which is about 800 mb, is it okay to delete it?
Old 15th March 2009, 20:07   #1660
Thanked: 253 Times
You can delete pagefile.sys. Windows creates it as 'additional RAM'.
You have to find the removal tool for this virus first. Install it on the other machine where you'll be plugging in your HDD.
Old 15th March 2009, 21:37   #1661
gendarmee's Avatar
Thanked: 22 Times
yes, i have found an exe file from AVG that does exactly that.
In the mean time, i found that 7-Zip file manager could move the important files from the C drive to the other drive w/o a hitch.
Do HKEY_CURRENT_USER\System\CurrentControlSet\Control \SafeBoot,
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\SafeBoot these two keys relate too booting the computer in safe mode?
Is there a manual way of adding the commands if the were deleted by the virus. I guess if i can enable the comp to boot in safe mode, i can probably run the AVG exe file on this system itself. At the moment i cannot boot the comp in safe mode and also the AVG tool gets terminated as soon as i start it.
Old 16th March 2009, 23:24   #1662
Gill's Avatar
Thanked: 12 Times
Plz suggest a good protective backpack for 15.4" laptop.Links would be appreciated.
Gill is offline   Reply With Quote
Old 17th March 2009, 00:40   #1663
gendarmee's Avatar
Thanked: 22 Times
Just finished formatting the C drive and installing windows again.
But was no good, the virus is still there.
Old 17th March 2009, 20:02   #1664
Thanked: 253 Times
Gendarmee, I hope you realize what you've said here is well nigh impossible!
Once you've formatted the drive and reinstalled Windows, it HAS to be fine, unless you are using an infected set of setup files from a read/write medium.
Please use CDs that are genuine and keep your machine disconnected from a LAN or network while doing the install.
Old 17th March 2009, 20:23   #1665
dreamdiesel's Avatar
Thanked: 55 Times
Targus makes good backpack for laptops. Pretty comfortable and sturdy. Lots of pockets for stuff.
Targus | Cases | Notebook | Backpacks
dreamdiesel is offline   Reply With Quote
The "NEW" Car Price Check Thread - Track Price Changes, Discounts, Offers & Deals black12rr The Indian Car Scene 6716 14th July 2018 08:59
The Camcorder thread : Tech, deals and specs adityapd Gadgets, Computers & Software 121 25th April 2014 17:03
New Civic 1.8V AT. Questions questions... ImmortalZ Sedans 6 12th June 2008 09:49
Help in configs - Gift Laptop Jr Godzilla Gadgets, Computers & Software 3 13th January 2008 11:20
