Old 17th September 2010, 12:30   #2566
ikoneer's Avatar
Thanked: 9 Times
@ghpk:
Well, i meant the external DVD drives and not external Hard Disk Drives.
I have this cervical disc prolpase and carrying the regular laptop everyday is quite a pain and hence i am looking for a light weight less than 1.5 kgs.
Are there any good models and this is going to be official laptop and hence needs to be purely functional and can do away with bling bling.
ikoneer is offline   Reply With Quote
Old 17th September 2010, 15:18   #2567
Thanked: 1,066 Times
Originally Posted by ikoneer View Post
@ghpk:
What you need is an "Ultra Light" laptop. All of them come without an internal CD/DVD drive.
Most of the major brands have the ultra light in their range. I have using the IBM/Lenovo X series for the last six years (X40 followed by X61s). If you can manage with a smaller screen (<12") Sony has some really light laptops in the 1kg range. Be aware these laptops are not cheap and normally hover around a lac for a decent configuration. One advantage of these laptops is the battery life. 6 hours is the minimum and goes upto 10 hours with some models.
Links to some models
Lenovo - Laptop computers - ThinkPad X Series - X201
http://www.sonystyle.com/webapp/wcs/stores/servlet/CategoryDisplay?catalogId=10551&storeId=10151&lang Id=-1&categoryId=16154&N=4294966502&Name=VAIO+Laptop s#/overviewTab
Business Laptops and Laptop Computers | Dell
Old 18th September 2010, 18:58   #2568
motorheadinc's Avatar
@ghpk:
Just a light laptop wont be sufficient. You need a really good laptop bag to distribute the weight evenly on both your shoulders and back. The best ones in the popular range are the Targus backpacks. I have used one for a long time now, over 3 years. They are quite rugged and at the same time very comfortable. You also need to make sure that the straps are the right length. Too long or too short, they will badly affect you. I too have a back problem and I use a Latitude D630 which is not light but with the targus back, it doesnt hurt at all even when carrying over a long duration.
motorheadinc is offline   Reply With Quote
Old 19th September 2010, 19:58   #2569
ikoneer's Avatar
Thanked: 9 Times
Smaller Screens should be ok, at office i will might as well connect to a monitor
I checked the Sony models and the procurement team at office has recommended the following model:
Sony Vaio X117g model - Atom processor Z550 2GHZ processor, 2GB RAM, 128 GB Flash memory etc. Is this a good performance model? BTW, what does the Flash memory mean, is it a replacement to Hard Disk and are these reliable?
Nice Tip. will look into that as well. Any idea on the cost?
Old 19th September 2010, 22:24   #2570
McLaren Rulez's Avatar
Thanked: 580 Times
Hey guys..
My laptop has been behaving strangely lately so I thought I'd ask the gurus here. Whenever I disconnect the power cord, the battery reading drops from fully charged to 70% in a few seconds. Then it proceeds to discharge as usual. Effectively, I'm only getting 70% of my battery's capacity.
Is the battery starting to die out? Or is there a quick fix to this issue? Its only one year old and rather annoyingly, the battery warranty expired a month before this problem started.
McLaren Rulez is offline   Reply With Quote
Old 20th September 2010, 09:22   #2571
Originally Posted by McLaren Rulez View Post
Hey guys..
Ha-ha-ha. This happens. My Thinkpad battery died (I mean died, no capacity at all!) in its 13th month. The new one is going strong for last two years.
Some batteries require periodic full discharge to determine their capacity. This happens when you use your laptop mostly with power adapter. In your case the battery capacity as determined by the controller in the battery might be acting up. Try this
- If you have battery reconditioning utility, run it. Thinkpad has it.
- Otherwise discharge you battery fully, recharge it fully. Then check
If the above works well and good, else your battery is on its way out.
Old 20th September 2010, 09:55   #2572
Atom processor is "light weight" processor good for browser based applications. Check this out Intel Pentium 4 Vs. Atom: A Battle Of The Generations : Can Atom Beat A Pentium 4?
Check if all your applications as well as games run in the Atom processor. Netbooks have this processors. Some games especially older ones are both processor and OS dependent and may crash.
Old 20th September 2010, 13:30   #2573
chevelle's Avatar
Thanked: 526 Times
Hey guys..
This is a common problem i have observed on all HP laptops. I am not generalizing, but under my observation i have 7 HP laptops on which i have to keep a tab on for any hardware/software failure. All these laptops sooner or later had the problem of battery discharging/dying after 1 and half years.
My vostro 1500 after 3 yrs, 5 months is facing the same problem. Still it last for 25 mins before dying. So its not as bad as your case.
I am told by HP customer care representative to replace it with new battery.
I guess you can try some other battery and see if its happening with a new battery too, in that case the charging points in laptop are a goner.
Just my 2 cents.
chevelle is offline   Reply With Quote
Old 20th September 2010, 20:59   #2574
Thanked: 580 Times
Thanks guys. I tried the full discharge method. It went from up to 75%. Almost like an attention seeking child! Anyway, I'll see how far it goes before my battery time becomes too less to live with.
Old 23rd September 2010, 17:13   #2575
sammyboy's Avatar
Thanked: 345 Times
Got another laptop after the Dell 15 R, this time a Sony Vaio E Series.
15.5 inch screen, i5 520 m 2.4 GHz with Turbo boost upto 2.93 GHz, WIn 7 Professional, 4GB RAM, 320 GB HD and a free licensed CD for Win XP professional that can be used with the laptop, if required.
Cost INR 44,400
sammyboy is offline   Reply With Quote
Old 23rd September 2010, 18:24   #2576
manim's Avatar
Thanked: 393 Times
Cost INR 44,400
The exact model number please?
I am also looking at buying Vaio.
manim is online now   Reply With Quote
Old 23rd September 2010, 19:01   #2577
mail4ajo's Avatar
Thanked: 260 Times
Can someone suggest a 11" or 12" screen slim laptop, Maximum budget 30K?
mail4ajo is offline   Reply With Quote
Old 24th September 2010, 12:50   #2578
sammyboy's Avatar
Thanked: 345 Times
VPCEB1AGG is the name of the model. Comes with 1 year international warranty as well.
The MRP is 52,490 but the dealer mentioned that they are Sony is upgrading this model so have discounts going on.
This was the last piece that he had and I couldnt resist the specs for the price (negotiated for the extra 1K though )
Old 30th September 2010, 18:33   #2579
mail4ajo's Avatar
Thanked: 260 Times
Anyone using the MSI Wind U200 new version? Seems to be nice value for money. 12" , 2GB RAM, 320GB HDD, 6cell battery and Windows 7 Basic and 2 year warranty for 25K.
How the MSI service and spares backup generally in India?
Old 30th September 2010, 19:29   #2580
HSV
HSV's Avatar
Default Laptop buying advice needed
Ok, firstly a little background. I am an IBM Thinkpad user and currently am using a R51 (upgraded the RAM last year). The system is very rugged indeed, and after over 6 years of its ownership I feel the time to change is near. Although the machine is running quite well, I feel if I dont change now I'd be left far behind (considering I havent already been so...) .
Although my use is more on the desk during the day, however I would like now to buy a LIGHT and POWERFUL machine. As per documented specs, I'd love to own the Vaio Z however spending over 1 lac on a laptop is too daunting a thought. Hec I could buy a car in that price!!!
I'd love to have a sub 1.5KG machine, with built-in optical drive, good screen real estate (1600x900 should be ideal), a powerful processor, good graphic card (for the occassional gaming or the occasional graphics animation designer tuggings at my heart), and good disk space.
I know, i know... i am hinting at the Z. I also know that there isnt anything in comparison/equation to it. So does anyone know how the Z fares? Is it dependable? After being a happy Thinkpad user, owning the same Thinkpad machine for over 6 years without any glitch - can i safely pile up the same expectations from the Vaio Z136? Will it be as durable and everlasting? Also any advice on a dependable dealer to buy it from.
Although I'd love to have the Geforce 330m GT, is it better to compromise a little on power, weight and screen and take the Vaio S137 which has the Geforce 310m and save me self 45K? Damn...!
HSV is offline   Reply With Quote
The "NEW" Car Price Check Thread - Track Price Changes, Discounts, Offers & Deals black12rr The Indian Car Scene 6709 19th June 2018 16:00
The Camcorder thread : Tech, deals and specs adityapd Gadgets, Computers & Software 121 25th April 2014 17:03
New Civic 1.8V AT. Questions questions... ImmortalZ Sedans 6 12th June 2008 09:49
Help in configs - Gift Laptop Jr Godzilla Gadgets, Computers & Software 3 13th January 2008 11:20
