Old 19th February 2011, 22:59   #2896
Pancham's Avatar
Thanked: 135 Times
Default re: THE Laptop Thread: Configs, deals and questions
If you are mostly going to use it for multimedia and all, get the core i3 + 5650 + Full HD display.
If you plan to run CPU intensive tasks along with serious multi tasking, then go for i3 and give up the i5.
Thanks tsk. I think I will go with the Full HD .
Pancham is offline   Reply With Quote
Old 20th February 2011, 12:24   #2897
Abeer's Avatar
Thanked: 12 Times
Attached is the quote of the config that I got from Dell. It has ATI Mobility Radeon™ HD 550v - 1GB and not ATI Mobility Radeon™ HD 5650 Graphics.
What do I miss out if the laptop does not have 5650 card?
Abeer is offline   Reply With Quote
Old 20th February 2011, 13:27   #2898
tsk1979's Avatar
Thanked: 16,422 Times
5650 is a mid range proper graphics card. 550v is a low end card.
Old 20th February 2011, 16:32   #2899
chevelle's Avatar
Thanked: 526 Times
any first hand opinion on Dell Inspiron Duo?
Amazon.com: Dell Inspiron Mini Duo 3487FNT Laptop (Foggy Night): Computer & Accessories
I am getting it for $410 instead of regular $550 + tax.
Please advice
chevelle is offline   Reply With Quote
Old 20th February 2011, 18:06   #2900
khoj's Avatar
Thanked: 1,258 Times
chevelle, what would be the street price for mac book pro 13" and 15" in the US. Thanks
Old 20th February 2011, 18:19   #2901
chevelle's Avatar
Thanked: 526 Times
13" macbook pro with 2.4 Ghz, 250gb and works is $1140. If you upgrade to 2.66 Ghz, 320gb it would cost you $1500.
15" with 2.4 Ghz, 320 gb hdd is $1725 and 2.53 Ghz, 500 gb hdd is $1900.
In 13" graphics card is the same - Nvidia 320m while in 15" its GT 330M.
The best deal on any apple laptop comes during black friday. its usually 10%-15% off and a gift card worth $100-$250.
Hope this helps.
Old 22nd February 2011, 09:50   #2902
prashant.dinkar's Avatar
Thanked: 52 Times
Default Suggestions Please
Hey Fellas ,
I am planning to buy a laptop fro myself and confused between -
SONY VAIO S Series -
  • Intel® Core™ i5-480M processor (2.66GHz) with Turbo Boost up to 2.93GHz
  • Genuine Windows® 7 Home Premium 64-bit
  • Black
  • 320GB Hard Disk Drive (5400rpm)
  • 4GB (2GBx2) DDR3-SDRAM-1066
  • CD/DVD Player / Burner
  • 13.3" VAIO Display (1366x768)
  • Intel® Graphics Media Accelerator HD
  • LED Backlit Keyboard
  • Standard capacity battery
This will cost $899 + Taxes
My other option is Mac Book Pro 13"
  • 2.4GHz Intel Core 2 Duo processor with 3MB on-chip shared L2 cache
  • 1066MHz frontside bus
  • 4GB (two 2GB SO-DIMMs) of 1066MHz DDR3 memory; two SO-DIMM slots support up to 8GB
This will cost $1199 + Taxes
My usage will be -
Regular set surfing , Watching movies , Music etc + MS office etc
I am really keen to connect my laptop to my HDTV wirelessly , is it possible with MAC ?
Guys please suggest my budget is $1000 and i will be picking it from US.
prashant.dinkar is offline   Reply With Quote
Old 22nd February 2011, 10:32   #2903
Thanked: 1,083 Times
Default Re: Suggestions Please
Originally Posted by prashant.dinkar View Post
Hey Fellas ,
  • Black
My usage will be -
Stick to VIO if you do not need Mac software. Get a full HD (1920 x 1080) if available within your budget. Also get 1 x 4GB if finances permit. You can get another 1 x 4GB installed here.
Here is the configuration with HD
VPCJ1190X | VPCJ1190X Configure-to-Order | Sony | Sony Style USA with 2GB it is $899 and with $8GB
1119. An i5 is just $80 more. I would strongly recommend that you get the 8GB. An extra $50 for Windows 7 professional is also worth it.
Old 22nd February 2011, 12:07   #2904
Thanked: 62 Times
You should go for the Sony VAIO with the Intel i Processor. If the 13" MAC gets an upgrade to Intel i processor series before the time you actually buy, then do consider the MAC.
When I purchased my notebook last year December I was considering to get a Sony Vaio Z series but later settled with the Lenovo T series and I'm throughly happy with it. I installed Ubuntu and a dozen of apps that I use for application development. Check if you could get a T Series within your budget. It is worth the buy.
joe1980 is offline   Reply With Quote
Old 22nd February 2011, 13:49   #2905
devarshi84's Avatar
Thanked: 119 Times
GO with the VAIO if using in India. Go with the MAC if using in N.A and you are a previous MAC user.
Also the I5 is that much better and worth the price.
devarshi84 is offline   Reply With Quote
Old 22nd February 2011, 18:47   #2906
chevelle's Avatar
Thanked: 526 Times
Hey Fellas ,
SONY VAIO S Series -[list][*]Intel® Core™ i5-480M processor (2.66GHz) with Turbo Boost up to 2.93GHz
My usage will be -
Please avoid Macbook Pro. Its getting an upgrade soon, so this one will be outdated. Secondly, VAIO is more loaded and capable than config of Mac.
Get Sony's Intel Wireless Ready laptop. Its usually available on all sony laptops. That will help you connect wirelessly to LCD/HDTV. If not you can always use the HDMI port to connect. With Mac its tough.
Old 22nd February 2011, 20:58   #2907
NetfreakBombay's Avatar
Thanked: 402 Times
Yes you can do that if TV has:
1. WiFi or LAN port (by adding a second WiFI router to connect TV to WiFi via LAN)
2. Supports DLNA
In this config you can display things on TV via WiFi.
NetfreakBombay is online now   Reply With Quote
Old 23rd February 2011, 13:53   #2908
Abeer's Avatar
Thanked: 12 Times
Thanks for the info. Apart from 5650 card, can you share few other mid and high range cards that one should look for before buying a laptop?
This would enable me to refine my search for a good laptop before I finally purchase it.
Old 23rd February 2011, 15:30   #2909
devarshi84's Avatar
Thanked: 119 Times
Instead of looking for the position of the card in the lineup, you better decide on the applications you will be running. Also FYI, some apps run better on Nvidia while others run better on ATI depending on the Gfx engine they use.
My 200M chipset based dedicated solution can still play today's games at basic settings.
Old 23rd February 2011, 16:14   #2910
Thanked: 139 Times
Refer your config in pdf. At that price, I just have 2 observations mainly on the software:
1. Microsoft has not released Windows 7 Home Basic x64 (64bit), either now or in the past. Home Basic is only on x86 (32bit) platform. Perhaps it is Home Premium. Home Premium is good enough for most uses. While on windows 7, negotiate for windows 7 with sp1. AFAIK, the sp1 was released to OEMs in early-Feb. If you get a windows 7 rtm with all updates, SP1 has been released and available. Not much of a bother, but it claims disk space for previous files backup. Even that is not much of a bother in installing sp1 with a simple command prompt taking care of the disk cleanup. Without this command, expect SP1 to take up 2-3 GB more than is required. From my experience, windows 7 dvd with sp1 takes as much space as windows 7 rtm install+updates; but without the sp1.
2. Office Starter is not worth much. Get at least a Home and Student.
3. Can you not get DOS based system, and buy a Technet Subscription from UK/US (quite possible). Over the long term, it will be much cheaper than paying for windows 7+office starter. Plus, you also do not need to pay for a lot of crapware that comes preinstalled and paid for.
vasudeva is offline   Reply With Quote
The "NEW" Car Price Check Thread - Track Price Changes, Discounts, Offers & Deals black12rr The Indian Car Scene 6716 14th July 2018 08:59
The Camcorder thread : Tech, deals and specs adityapd Gadgets, Computers & Software 121 25th April 2014 17:03
New Civic 1.8V AT. Questions questions... ImmortalZ Sedans 6 12th June 2008 09:49
Help in configs - Gift Laptop Jr Godzilla Gadgets, Computers & Software 3 13th January 2008 11:20
