Old 6th September 2010, 15:26   #61
Awaiting Email Confirmation
Get this:
eBay India: Belkin AC anywhere +USB port +200W Car Inverter Charger (item 150486952725 end time 06-Sep-2010 16:50:24 IST)
BaldOwl is offline   Reply With Quote
Old 13th September 2010, 15:17   #62
sanjeevgpc's Avatar
Thanked: 24 Times
@Aroy : I got a connector from another dead adapter and joined the wires. The only problem in such cases is the ID chip whih is used by DEll/IBM and some other brands to identify the charger. If the laptop doesn't find the ID information from the adapter it stops charging the battery. I have tried it in many HP adapters which do not have ID chip. Eacy way to see it will work is check if the adapter wire had 3 wires or 2. If it has 3 wires on the laptop connecter side, most probably it wont work. If it has 2, it shoudl work for sure.
You can change the controller from some other similar battery but many controllers are smart and if the power to controller from battery is interrrupted for few secs, they kill themself. I think thinkpads have this issue. Else it should work.
@forbhaskarm : I think you have a thinkpad, so 99% chances are that this swap will not work. Not worth the time and effort. Like somebody else had also suggested, sell this one and buy another . Or if possible for you, get the ID chip from the broken adapter and connect to the substitute charger along with the plugs of course.
Or if possible, send them to me and probably I can do it for you :-).
sanjeevgpc is offline   Reply With Quote
Old 1st October 2013, 14:44   #63
Thanked: 285 Times
Default Re: Using Thinkpad charger with Dell laptop
Reviving an old thread with a different question.
I have a a HTC Phone & a Nexus 7 tablet. Can I use the HTC Charger with the Nexus Tablet or vice versa?
carboy is online now   Reply With Quote
Old 1st October 2013, 15:26   #64
k_nitin_r's Avatar
Thanked: 74 Times
Originally Posted by sanjeevgpc View Post
The only problem in such cases is the ID chip whih is used by Dell/IBM and some other brands to identify the charger
IBM branded Thinkpad laptops don't really check for an ID chip. I have a Thinkpad T60 and previously a Thinkpad 600E that could run off a no-name generic charger while at university. You'll also find a page on Instructables on getting a Thinkpad to run on a Dell charger. Lenovo themselves sell a charger with adapter tips that you can use to charge laptops of other brands, including Dell and Sony.
If they are both charged by the microUSB port, you can swap chargers. I do that all the time - my Kindle Fire charger powers the Kindle Fire, another tablet, a Sony HX20V camera, a Sony HX200V camera, a Nokia E72, and an MP3 player. It's my Apple devices that require their own chargers - the old style charger, and a newer lightning connector.
k_nitin_r is offline   Reply With Quote
Old 1st October 2013, 17:19   #65
Thanked: 420 Times
Sure you can charge with any micro USB charger but older phones had smaller batteries chargers with lesser current rating were used so if you use them on tablets it takes ages to charge.
Example a 3100 mAH battery of Note 2 comes with 2 Amp charger and it should take 1.55 hours to charge fully. With 1 Amp charger of Note 1 it will take 3.1 hours to be fully charged and with 500 mA from a PC USB port or using 500mA charger of a normal phones the time would increase to 6.2 hours.
amitk26 is offline   Reply With Quote
Old 1st October 2013, 17:36   #66
Thanked: 285 Times
What if you do the reverse - i.e. use the Note 2 charger on your phone - would that be a problem?
i.e. If I want a single charger for both my Nexus 7 tablet & my HTC Desire X phone - can I use the tablet charger for both - without worrying about it blowing up.
Old 2nd October 2013, 09:02   #67
rohan_iitr's Avatar
Thanked: 417 Times
Use the charger with higher current rating to charge both devices. A charger with higher current rating would not damage a device which has lower current rating. The device will only draw the current it requires, a higher current rating charger will not cause excessive current to flow in the device.
Rohan
rohan_iitr is offline   Reply With Quote
Old 2nd October 2013, 10:02   #68
Thanked: 285 Times
tsk1979, in my original question about the laptop charger, you talked about voltages and how that's very relevant. The nexus 7 pamphlet says - "the charging unit's output is DC 5V, 2A". The HTC Phone charger says on the plug - 5V 1A. So I am assuming this should be OK - I don't want to blow up either of these devices.
Ok - so I connected my phone to my tablet charger now. It didn't blow up (yet).
Old 2nd October 2013, 14:09   #69
Thanked: 1,089 Times
The reason for USB chargers is that you should be able to use any charger available at hand. A lower capacity charger will just take longer to charge (which in a way is better as lower charge rate extend the battery life). A higher capacity will rarely charge faster as the charging rate is dependent on the battery AH rating.
Dell laptop Service.!! SirAlec Gadgets, Computers & Software 144 12th October 2012 15:00
Help me in pairing my Motorala S9 with Dell studio laptop Fordmanchau Gadgets, Computers & Software 12 14th August 2009 12:24
IBM Thinkpad LCD replacement KPGB Gadgets, Computers & Software 18 14th May 2009 10:51
Remote desktop of laptop from PC using Bluetooth? DCEite Gadgets, Computers & Software 2 12th September 2008 10:58
