Old 14th January 2010, 00:53   #1
Shan2nu's Avatar
Thanked: 87 Times
Default WIFI security issue.
I've got a Airtel wifi modem which doesn't have a secured connection. Does anyone know the procedure to set a password, so that other unauthorised wifi enabled systems can't acces my network?
The things i'v done so far.
1. Logged into the 192.168.1.1 website
2. Under WAP setup - selected wireless
3. Under wireless - selected "security"
4. Under security - selected "WEP"
5. Under WEP - enabled WEP wireless security (authentication type "shared")
6. Fed in the 10 digit encryption key for the 64bit cipher
7. Clicked apply
8. Restarted the Wireless Access point
Is this enough or should i be doing something more?
I tried connecting my laptop via wireless after this, it detected the connection but said that the settings were not compatible. Then i had to goto the connection properties on the lap top, select WEP, enter the 10 digit key and only then did it accept the connection.
Is this how its supposed to be? Cos i was under the impression the password box pops up the moment a connection is detected.
Shan2nu
Old 14th January 2010, 01:00   #2
mohit's Avatar
Thanked: 122 Times
Can you look up the model number on it? That way we can probably find an online manual.
mohit is offline   Reply With Quote
Old 14th January 2010, 01:10   #3
ph03n!x's Avatar
Thanked: 118 Times
  1. Find the default gateway on your computer, and enter that IP address on the browser
  2. It should give you the airtel modem's login page, default username/ password is usually admin / password
  3. Look for wireless settings in the interface, see if there is a security option to set WPA2-PSK (AES) or WPA-PSK (TKIP)
  4. Enter a pass phrase between 8 to 63 characters (alphanumeric)
  5. Apply the changes, reboot.
  6. You will have to enter the same pass phrase on the computer to connect to the router again
These are generic steps- for specifics, need the brand and model #...
EDIT: You edited your post after I saved mine!! Choose WPA, that is more secure than WEP... As its an existing connection, a change in the router rendered the connection settings "incompatible". If you use a new computer, or deleted the connection settings n reconnected afresh, you will get the password prompt.
ph03n!x is offline   Reply With Quote
Old 14th January 2010, 01:22   #4
Shan2nu's Avatar
Thanked: 87 Times
Brand - Beetel
Model - 440TXI
Shan2nu
Old 14th January 2010, 01:28   #5
mohit's Avatar
Thanked: 122 Times
There's no popup. You specify the passkey at the connection level and from that point on, it'll auto connect. I think you are good to go here.
Old 14th January 2010, 01:29   #6
Shan2nu's Avatar
Thanked: 87 Times
Ok, i selected WPA and got this page. Now what do i enter in the boxes?
Old 14th January 2010, 01:32   #7
Shan2nu's Avatar
Thanked: 87 Times
Maybe it is working coz when i tried to connect my PS3 through wifi, i had to feed in the WEP and 10 digit key again. The PS3 was not able to auto connect to the modem (which it used to do earlier).
Shan2nu
Old 14th January 2010, 01:34   #8
Shan2nu's Avatar
Thanked: 87 Times
I'l try it again with my sister's lap top. That should clear the confusion.
Shan2nu
Old 14th January 2010, 01:42   #9
I think your configuration as it stands right now, is good to go
This should repel a majority of wifi leeches ((99% imho).
However this is not bulletproof in the sense that somebody really determined could still hack into your network. They would need specific software and some degree of technical know-how, but it is doable.
indiagenie is offline   Reply With Quote
Old 14th January 2010, 01:49   #10
mohit's Avatar
Thanked: 122 Times
The PSK key. Thats the key you would be using for all your devices. Same as WEP.
You have encryption on now as confirmed by your PS3 connection. Its just that WPA is more secure than WEP.
Old 14th January 2010, 01:59   #11
Shan2nu's Avatar
Thanked: 87 Times
Ok done.
I disabled WEP and enabled WPA PSK Key. Reconfigured the laptop settings also. It's working fine.
And yes, there is still no pasword box pop up. Need to enter the settings through connection properties.
Thanks guys.....
Shan2nu
Old 14th January 2010, 02:01   #12
Thanked: 49 Times
The other thing you can do is to enable MAC address filtering on your WiFi Router/Modem.
Once that is enabled, the router will also match your hardware's MAC address with the one in its settings - thus providing another layer of security against unauthorized access.
CrackedHead is online now   Reply With Quote
Old 14th January 2010, 02:08   #13
Shan2nu's Avatar
Thanked: 87 Times
You mean like this 12 digit number?
Windows NT
Shan2nu
Old 14th January 2010, 10:22   #14
Thanked: 245 Times
Windows NT
Shan2nu
This is the best way to prevent any intrusion, yes the ethernet adapter local area network address (MAC), you will need to add those for whoever wants to access the network through your Wifi modem.
Old 14th January 2010, 10:45   #15
Awaiting Email Confirmation
Thanked: 4,221 Times
We use MAC filter with encrypted security in our home wireless network with Nokia Siemens modem successfully.
J.Ravi is offline   Reply With Quote
Swift Vxi Nippon Security system - Issue? iamswift Technical Stuff 7 19th May 2011 08:38
How to use remote desktop through wifi router DCEite Gadgets, Computers & Software 14 7th June 2010 18:38
Engine will not start...security system issue? theexister Technical Stuff 4 18th November 2008 15:22
Internet connection sharing without WiFi access point gopz Gadgets, Computers & Software 14 5th December 2007 13:03
Wifi Dongle mail4ajo Gadgets, Computers & Software 7 14th February 2007 05:35
