Old 18th January 2010, 03:33   #1
vivekiny2k's Avatar
Thanked: 172 Times
Default HP TX2000Z - won't boot
I guess it had to happen one day
here is rhe sequence of events.
1. I created a new power profile. turned the screen down, it went in hibernate. I never ever use hibernate. forgot to disable this time.
2.computer went blank, with all relevant LEDs still lit.
3. tried a hard reset, it again booted up in same mode.
4. external onitor didn't show anything either.
5. hoping to boot from DVD, I removed hard disk.
since then, whatever i do, it just lights up for half a second and dies. i even removed and put back the CMOS battery. Didn't work.
what are my options at this time? what may be wrong?
vivekiny2k is offline   Reply With Quote
Old 18th January 2010, 07:56   #2
flipsyde's Avatar
Thanked: 62 Times
Hate to be the bearer of bad news but, you need a motherboard replacement. The entire TX range suffers from over-heating. I have a TX1000 its been about 2.5 years since I've got it and it has already got 2 new motherboards. I think I am due for the 3rd replacement very soon.
Good luck with finding a new board.
flipsyde is offline   Reply With Quote
Old 18th January 2010, 19:29   #3
aaggoswami's Avatar
Thanked: 1,436 Times
1) Try the normal drain thing by removing the CMOS battery, disconnecting mains and press power button.
2) If no.1 fails, try cleaning or blowing air.
If both 1 and 2 fail, you have some hardware problem. Mostly its mobo.
aaggoswami is online now   Reply With Quote
Old 18th January 2010, 20:50   #4
vivekiny2k's Avatar
Thanked: 172 Times
this will probably go down as the worst purchase of lifetime. I have had enough, will try to fix it but am looking at better lappies anyway. (while I try to get used to my old laptop and work on it the whole day)
anybody knows if it's possible to replace bios chip on this one?
Mounting speakers on Boot tray.. good or bad for tray?? varunghatge Modifications & Accessories 11 5th December 2008 20:07
Boot light wiring clarification. supremeBaleno Technical Stuff 48 24th July 2008 12:07
swift audio setup without affecting boot space ronk In-Car Entertainment 22 15th October 2007 10:47
Custom boot setup for Swift carlover84 In-Car Entertainment 63 14th August 2007 21:39
What direction should the sub face/fire (in the boot)? Bass&Trouble In-Car Entertainment 32 29th August 2006 16:46
