Old 25th February 2010, 21:50   #1
Thanked: 36 Times
Default Can I connect extra speakers to my Philips DVD player?
Hi guys!
I own a Philips DVD player. As of now the audio is connected to my Onida TV which has good sound quality. It is connected to the TV through FRONT LEFT AND FRONT RIGHT OUTPUTS.
Now, my query is that I also own Navtech 2.1 multimedia speakers. Is there a way I could connect it to my DVD player?
Even if the subwoofer can't be used, is there any way to use the two speakers to give a surround effect and extra sound output?
I hope you get me.
Thanking you in advance
Abhinav Sharma
abhipuru16 is offline   Reply With Quote
Old 25th February 2010, 21:56   #2
greenhorn's Avatar
Thanked: 1,450 Times
if these are PC speakers, all you need is an RCA to female minijack cable.
Dont bother learning the name just go to an electronic parts store , and tell them that you need a cable to connect your DVD player to PC speakers
greenhorn is online now   Reply With Quote
Old 25th February 2010, 22:15   #3
Thanked: 36 Times
Nah! I need to use extra speakers with my DVD player IN TANDEM with my TV speakers. Where and how to connect?
The 2.1 speakers have an input cable of the type- 3.5mm male to RCA male.
P.S.-
I tried connecting the RCA jacks of the wire to the DVD's rear left and rear right sockets and the other RCA end to the subwoofer (that's where all connections happen) of the 2.1 multimedia speakers' input but there was no sound from the 2.1 speakers. Only, from the TV speakers.
I am as of now using the normal MP3 discs of bollywood songs you get from street hawkers to play sound on my DVD player, do I need any special media?
Old 25th February 2010, 22:30   #4
greenhorn's Avatar
you need two splitter/Y cables
or try enabling the upmix/dolby surround/whatever upmix is available in the settings menu. ensure output is not set to 2.0/stereo
Old 25th February 2010, 23:25   #5
Thanked: 36 Times
Why do I need this Y-cable? What would it connect?
See, it's like I want TV speakers to be working as Front Left and Front right (which they are)
and my multimedia speakers as rear left and rear right (which they aren't don't know why) but there won't be sub involved. Although the sub may work if I connect the 2.1(subwoofer included) speakers to the rear left and rear out.
Old 26th February 2010, 00:11   #6
Thanked: 36 Times
This is what I intend to do-
Old 26th February 2010, 07:51   #7
greenhorn's Avatar
to get two sets of working RCA outputs which you currently dont have, since you're not getting any output from the rear channels ( probably because you dont have/have not enabled any upmix in the player)
the Sub is an integral part of the speaker, and will work. I'm not sure you are going to get actual surround output unless you play surround material. if you play mp3's , and manage to get output from the surround outputs, most internal upmixes just mirror the output. So its essentially the same as the Y cable
Old 26th February 2010, 10:41   #8
Thanked: 36 Times
Yeah! You were right! I just enabled Pro-Logic II and all speakers as well as the sub fired up! Thanks a lot greenhorn. Although, I feel I shall need the Y-cable to add extra speakers to my DTH TV too as I didnt know of such a cable before, then I shall get much more pronounced sound on TV too. Thanks a lot.
Do you know if these cables are readily available. I seriously doubt it. Anybody who can get it for me or a DIY?
Is a DIY possible for such a cable?
Old 26th February 2010, 12:20   #9
greenhorn's Avatar
Investigate the cables/adapters available in the electronics spares shops first. Dont think it will be that hard to find
DIY: Multimedia player for a car's DVD player narendra.vw In-Car Entertainment 12 6th November 2015 19:49
Is it 2 Player(MP3 Player & DVD player) Possible in my i10? camon In-Car Entertainment 4 17th October 2010 11:35
Philips PET 723 Portable DVD player smsrini In-Car Entertainment 2 22nd June 2009 16:44
Alpine CD Player or Digital Media Receiver or a Clarion 2 DIN DVD Player ? esteem_lover In-Car Entertainment 36 13th February 2009 12:05
Service centre required for LG CD-player/writer cum DVD player benbsb29 Gadgets, Computers & Software 0 18th January 2007 11:58
