Old 28th February 2010, 12:40   #1
Thanked: 36 Times
Default "Kirr-kirr" in speakers
Hi guys!
I don't know if this is where this thread goes, but anyways the mods are free to move it any where they want.
So, I own these 2.1ch Multimedia speakers but there is a problem. The right side output socket is somewhere to be blamed for a "kirr kirr" noise in the speakers. The speaker itself works fine when I connect it to the left output so it's just a problem with the connector. Moreover, sometimes there is no soud at all coming from this socket irrespective of which speaker is connected to it.
What could be wrong?
I opened up the sub where the socket is but everything inside is glued, so what do I do now?
abhipuru16 is offline   Reply With Quote
Old 28th February 2010, 13:01   #2
Ponmayilal's Avatar
I think the stereo jack that plugs into your PC is not making proper contact. It may be at the other end also where it connects to the sub-woofer. Just try to plug it in and out at both ends/rotate it slightly and check if proper contact is established.
Usually my right channel sound sometimes disappears or becomes noisy. I just rotate the jack to the PC a little and it is resolved. I do not know whether a new cable will resolve the problem once for all. You have to try.
Ponmayilal is offline   Reply With Quote
Old 28th February 2010, 15:10   #3
Thanked: 36 Times
Okay, I got you and the speakers are firing up. But, there still remains this "kirr-kirr" noise specifically in this right side speaker (which wasn't firing earlier), how do I correct it?
Old 28th February 2010, 19:03   #4
Ponmayilal's Avatar
It is now established that it is only a contact problem. Next option will be to reverse the cable (PC end to the woofer and woofer end to the PC) and try.
If the problem still persists, buy a new cable - a good quality one, preferably gold-plated - and try.
Thats all you can do all by yourself. If the problem still persists, it would mean that the springy contacts inside the socket have lost their tension and changing the socket in the motherboard or the woofer, as the case may be is the only solution and this can be done only by a professional service guy. Good luck.
Old 28th February 2010, 19:31   #5
greenhorn's Avatar
Thanked: 1,438 Times
issue with the speaker drivers?
else its a contact issue
greenhorn is online now   Reply With Quote
Old 28th February 2010, 19:37   #6
DerAlte's Avatar
Thanked: 2,877 Times
Try rotating the jack (both the PC end as well as the Creative end) - just twirl it with your fingers. At one point the kirr-kirr should go off.
Old 28th February 2010, 19:43   #7
bblost's Avatar
Thanked: 6,716 Times
I once had a small piece of metal stuck to the magnet inside the speaker that was making a kirr kirr sound.
Just check that as well if the jack thing does not solve it.
Old 28th February 2010, 19:48   #8
Ponmayilal's Avatar
It is good idea to uninstall and then reinstall the sound drivers as suggested by greenhorn. Sometimes the least expected - which we normally tend to overlook based on personal experiences and line of thoughts -, can be the cause.
Old 4th March 2010, 00:28   #9
Thanked: 36 Times
Well, I am not using the speakers with the pc but with my tv using a y splitter cable through my DTH. Now, I tried to interchange the channels but still the speaker would sound like kirr kirr when voices were played in the audio. Also, this noise in voices keeps coming and going every now and then. What to do?
Old 4th March 2010, 03:02   #10
ghpk's Avatar
Thanked: 192 Times
try using another cable which is 2 RCA to 2 RCA i think this is what you would be having for input on backside of your speaker/woofer
Else
looks like the Audio Gain from STB is too High, try lowering the volume(using dth remote) and check if its still there.
if you have any small noise filter available(only a few D.I.Y. insects can have this)
to test use the input through it.
Try changing to another power outlet of your room to power up the speakers.
Old 4th March 2010, 14:53   #11
Thanked: 36 Times
See, even after interchanging the output channel the specific speaker still has this problem.
Old 4th March 2010, 18:50   #12
DerAlte's Avatar
I presume you mean you swapped the L and R speakers, and the faulty speaker still gives distortion in the new position also. Or does it mean that the speaker that was working OK now distorts in the new position?
If it is the first, you need to open the speaker and check if the surround and spider are OK. If not, you need to do some jugaad and replace the driver.
If it is the second, either the connector in the sub box or the corresponding amp channel are faulty.
Old 4th March 2010, 19:08   #13
Thanked: 36 Times
This is exactly the case.
How do I check this?
Old 4th March 2010, 19:32   #14
DerAlte's Avatar
1. Visual inspection - is anything torn?
2. By feel and hearing: very gently press down on the cone with finger-tips (diametrically opposite so that there are no asymmetrical forces). If you feel or hear any scratching noise, the voice coil is touching the magnet
If either of the above is true, it is time to change the speaker.
Old 4th March 2010, 19:41   #15
Delta Wing's Avatar
Thanked: 112 Times
Open the front cover and see if anything touches the cone as it moves. Check with a torch if the cone has a tear in the material. How exactly does the distortion sound, is high freq 'chrrrrr-chrrrrrr' or like a mid freq flutter 'burrrrr-burrrr'? Is it continuous (cable/contact fault) or intermittent (fouling object/cone gone bad)?
Delta Wing is offline   Reply With Quote
Requesting info on Blaupunkt 6"X9" speakers. anadkarni In-Car Entertainment 39 24th May 2011 02:11
JBL T696 GTi Series 6"x9" Co-Axial speakers ddd08 In-Car Entertainment 9 9th April 2008 19:54
HU Query for JBL speakers was "Polk MOMO vs db Compos" hyper-VTEC In-Car Entertainment 43 13th December 2006 15:03
Another stupid question: Do speakers need "servicing"? Rtech In-Car Entertainment 13 25th September 2006 22:48
