Old 15th January 2010, 11:51   #796
panky12345's Avatar
Thanked: 145 Times
Originally Posted by BaCkSeAtDrIVeR View Post
I was looking Bose PC speakers, and they do fit my budget. Anybody has any feed back?? Do Bose PC speakers (they do have built in amplifiers like most PC speakers) serve as a good substitute for other HT speakers??
I have those..(bought in the US). Pathetic is one word for them.
panky12345 is online now   Reply With Quote
Old 16th January 2010, 01:39   #797
shuvc's Avatar
Thanked: 286 Times
Originally Posted by drbabuanand View Post
put simply-sound card with hdmi out and graphics card with hdmi out,do we need both to view and experiance hd content.
I've almost no exposure to PC based setups. But in your case it does look like you'll need a new soundcard with digital audio output. This would be either in the form of an optical digital or a coax digital.
This should give you an idea. HowStuffWorks "Why are there so many different connectors on my DVD player?"
Connect the optical audio out from the soundcard to the corresponding optical in of the receiver (both the receivers in the links I provided earlier, will have these inputs)
Connect the HDMI out from the graphics card directly to the TV. As it is now.
Old 16th January 2010, 08:26   #798
arjunrudra's Avatar
Thanked: 13 Times
For me its definitely the bose. And I bought a home theater system for my music room few months back.Did a lot of research and finally went with the onkyo with HDMI switching. Love it. The sound is so clear and When on theater dimensional mode is simply awesome and mine is a 7.1ch system.
arjunrudra is offline   Reply With Quote
Old 16th January 2010, 19:07   #799
Thanked: 148 Times
Infractions: 0/2 (9)
Default THX certified
Somebody had told me (not here) to look for the "THX certified" mark while looking for AV products. And that is when the beow links hit me on my face.
AVRant Home Theater Podcast Blog Archive AV Rant #163: Bacon Wrapped Vegan
and
Oppo on the Inside, Lexicon on the Outside — Reviews and News from Audioholics
So, next question - does THX make any difference?
Old 17th January 2010, 00:10   #800
drbabuanand's Avatar
shuvc
thanks for the quick reply
the link was informative
i have decided on a 5.1 creative sound card + onkyo ht package
any suggestions
drbabuanand is offline   Reply With Quote
Old 17th January 2010, 00:31   #801
DjNik's Avatar
drbabuanand-I would suggest you to stay away from creative sound cards and get a asus xonar card,You will never regret.These are the models you should look at-
Asus XONAR-DX-4700
Asus Xonar D2X-9500
DjNik is offline   Reply With Quote
Old 17th January 2010, 08:44   #802
arjunrudra's Avatar
Thanked: 13 Times
and
THX certified does make a diffrence but the only reason i stayed away from them was they came with recievers that did not have hdmi switching.
Old 16th February 2010, 00:13   #803
PM - B's Avatar
Thanked: 282 Times
Display is Samsung Full HD 50" Plasma.
Audio Setup is 5.1,
Stereo 2.2 Amp for the fronts,
With a 7.1 AVR for the Centre and Rear Channel
Powered Subwoofer.
For Front Two Channel Amplification.
Harman Kardon HK990 2.2 - 300 WPC RMS @ 4 Ohm, 20 - 20KHz Range, 0.3 THD, 1KW Power Consumption, 24 KG
For Center & Rear Two Channel Amplification.
Harman Kardon AVR355 7.1- ~90 WPC RMS @ 4 Ohm, 20 - 20KHz Range, 0.07 THD, 890 W Power Consumption, ~ 14 KG
Subwoofer
Infinity Model 12
300 WRMS, Downfiring 10" Metal Matrix Diaphragm, Dual 10" Passive Radiators
Main Stereo Speakers
Magnepan MG 1.6 Quasi Ribbon,
Two Way Full Range Planar Magnetic Dipole Radiator
40 Hz - 22KHz. 86Db Sensitivity
538 Sq Inches of Radiating Area
Wt 40 Kg Pair
Rear Channel Speakers
Magnepan MC1, Quasi Ribbon
Two Way Planar Magnetic Dipole Radiator
80 Hz - 24KHz. 88Db Sensitivity
Wt 14 Kg Pair
Center Channel
Magnepan CC3, Quasi Ribbon
Curver Two Way Planar Magnetic Dipole Radiator
80 Hz - 20KHz. 86Db Sensitivity
225 Sq Inches of Radiating Area
Wt 10 Kg
CD Player
Harman Kardon HD990
Single CD player, with the most basic funtions.
Relatively High End electronics internally.
Thinking of Bi Amping the Main Speakers.
Currently using 2.5 Sq mm 99.9 % pure copper wire for the cabling.
Thinking of going to 10 Sq mm for the main speakers.
Bluray on the cards when it is more affordable.
Currently use Laptop to play DVD.
Tuner is built into the AVR.
Digital Settop box is connected to AVR.
PM - B is offline   Reply With Quote
Old 18th February 2010, 14:35   #804
Latheesh's Avatar
Thanked: 3,227 Times
Had a plan to upgrade my car ICE, postponing the same and planning to get a basic home theatre system instead.
Budget is 20-25 K, and I listen to almost all kinds of music from Indian classic to hip-hop :-)). Suggestions please..
Latheesh is online now   Reply With Quote
Old 19th February 2010, 08:26   #805
Ranga's Avatar
Thanked: 43 Times
My setup
Video - Panasonic AX 100 Projector with Brawn 6 X 8 Screen - Glass beaded
Sony 32 Inch Bravia
Audio - Sony 6.1 Mutaki Series Player with 2 Sub Woofers
Player - Oppo DVD Player
AC Ryan Play on HD Media player - Plays every format available in the workd
Hard disk drive - Sea gate 1 TB HDD
Media content : All type of HD Movies , 720 & 1080P on mkvs
Ranga is offline   Reply With Quote
Old 21st February 2010, 11:22   #806
rocksterraghu's Avatar
Thanked: 87 Times
shuvc
any suggestions
I would also warn you that 5.1 rendering would be done by software, so you have a risk factor. And from my experience, the rendering is generally inaccurate and at very low output levels. I may be wrong, but I suggest you look into this before making the purchase.
Old 21st February 2010, 16:11   #807
srisha's Avatar
and
THX makes a difference only when you are playing a THX certified DVD, and you dont have many of them in the market.
THX is another certification just like Dolby or Dolby Digital
srisha is offline   Reply With Quote
Old 21st February 2010, 21:09   #808
Thanked: 148 Times
@srisha; thanks for the info.
Old 21st February 2010, 21:16   #809
Fillmore's Avatar
Thanked: 139 Times
THX is a certification given by a George Lucas company.
Dolby Digital is a compression technology developed by Dolby, its a format by itself and not a certification as stated.
Not necessary that THX makes a difference only when you are playing a THX certified DVD. A THX certification means that your media/hardware has passed a series of tests and is capable of reproducing a wide frequency of sounds with greater accuracy.
Fillmore is offline   Reply With Quote
Old 21st February 2010, 21:57   #810
jassi's Avatar
Thanked: 11 Times
^^ agree with Filmore on THX vs Dolby.
jassi is offline   Reply With Quote
Help me build a Simple Home Theater PC sandeepmdas Gadgets, Computers & Software 66 16th May 2013 23:30
USB Hard Disk to Home Theater autoenthusiast Gadgets, Computers & Software 0 20th August 2008 21:36
Home theater under $220 cooldude1988765 Gadgets, Computers & Software 4 9th November 2006 14:31
For SALE- Home Theater components nitinbhag Shifting gears 1 2nd August 2006 18:24
Home Theater - Amp/woofer for Car vivek.singh.73 In-Car Entertainment 6 25th September 2005 12:18
