View Poll Results: What Kind Of Backup Medium You Suggest
Hard Disk Drive 28 96.55%
Verbatim DVD 1 3.45%
Voters: 29. You may not vote on this poll
Old 7th June 2010, 17:33   #1
NOTORIOUS's Avatar
Thanked: 87 Times
Default Heavy Data Back Up DVD or HDD
Hello Friends
From The last one week i am not able to decide to how to backup my 600 GB of data. i already have a 2 x 640 GB WD mirrored hard disks from past 1.5 years , but now one of the drive which i use regularly has developed bad blocks and other one is good as i power it on only once a month for backup of data.
Now i want to keep a copy of all my data away from my home , what do you suggest , should i buy another Hdd or Burn my Data on slow speed on Verbatim DVD's which i already ordered ????
The data is mainly my old pics and videos which i dont want to lose at any cost .
Waiting for your advise....
NOTORIOUS is offline   Reply With Quote
Old 7th June 2010, 19:04   #2
Thanked: 17 Times
HDD anyday. For the amount of data you have, it will be a nightmare to maintain the DVDs. Why don't you consider some home Network Storage?
gopalnayak is online now   Reply With Quote
Old 7th June 2010, 19:09   #3
typeOnegative's Avatar
Thanked: 20 Times
Did not see the option, but in my opinion it is 'both'. Segregate into - non-changing and changing data. The one that does not change can go into a DVD set. The one that keeps changing (files and folders) can be on the HDD. Do remember that an HDD can get stolen and that DVD's can get broken.
typeOnegative is offline   Reply With Quote
Old 7th June 2010, 19:53   #4
NOTORIOUS's Avatar
Thanked: 87 Times
90% of data is not update-able like my pics and movies of my childhood.
I can take care of that , Thank you
Old 8th June 2010, 00:50   #5
blackasta's Avatar
Thanked: 988 Times
With internal HDDs becoming super cheap - go for 4 1TB HDDs, and make mirrored sets in a striped set (RAID 1+0), and backup data.
Remember - RAID when used as primary disk does not categorize as a data backup - go for RAID only as your dedicated data backup server.
blackasta is offline   Reply With Quote
Old 8th June 2010, 02:11   #6
Thad E Ginathom's Avatar
Thanked: 7,452 Times
Has to be both.
You should never rely on an electrical/mechanical device as your ultimate backup. never, never, never, never. All kinds of stuff can fail with a hard disk, and even that which is fixable is a hassle, and probably expensive, to get fixed.
Which reminds me to stop doing that very thing myself! If it was office stuff, I wouldn't countenance it for a moment, and RAID wouldn't change my mind either. Of course, at work, not only is the data of commercial value, but there may be legal responsibility to make sure it doesn't go missing, and somebody else was paying for expensive tape drives.
The HDD is so quick and easy to write to or copy from, and two copies is a whole heap better than just one, but it is not enough. Use the DVDs as well.
Old 8th June 2010, 10:58   #7
Thanked: 20 Times
In spite of that, like Thad, I have suggested both. Enclose each DVD in a case (not in an envelope).
Old 8th June 2010, 11:49   #8
NOTORIOUS's Avatar
Thanked: 87 Times
Should i store my DVD's in a case (100 dvd's in one case) or in a spindle ??????
now i would make two copies of my whole data on Two Seprate Hdd's And one Set of DVD's . One question which is clicking in my mind is that What is the expected shell life of a good quality DVD like verbatim ????
Old 8th June 2010, 12:02   #9
rahulsingh007's Avatar
Thanked: 43 Times
@NOTORIOUS
I've hear that shelf life of a burned DVD is about 5-6 years , while pressed DVD (commercial DVD) last about 20 years.
Storing data on a DVD+/-r for long periods of time is uselss , get yourself a good HDD that ought to solve the problem
rahulsingh007 is offline   Reply With Quote
Old 8th June 2010, 20:55   #10
You expect a HDD will outlive a DVD? It might... but I wouldn't bet on it, especially as HDDs become cheaper consumer items. Buying a few-hundred GB scsi disk for my servers in my work days (original IBM, of course) was a management budget decision: now we can all nip out any buy ourselves a terrabyte for home!
A very long-term archive/backup system would have to consider rewriting dvds. Actually, they may well last longer than the magnetic impulses on professional backup tapes.
One of the biggest hassles with writing to external backups, once it exceeds a single unit, is dividing the data up. Any suggestions for software to do this?
Old 8th June 2010, 21:55   #11
NOTORIOUS's Avatar
Thanked: 87 Times
Ok , I would do this way , Will make one copy on DVD and Other On a HDD. Even After 5-6 years , i can always move to better technology for data archiving
Old 8th June 2010, 22:07   #12
muralisk's Avatar
Thanked: 9 Times
HDD any day is safe and easy to maintain as well. They are even quite portable and gives you great flexibility to take with you. So, it is HDD.
muralisk is offline   Reply With Quote
Old 8th June 2010, 22:26   #13
Thanked: 7 Times
Why don't you look at storing the 600GB data on a portable HDD and then the most critical of these data on those cheapo 16/32 gb pen drives / sd cards which are avlbl dime-a-dozen at throwaway prices!
I have been keeping business-critical data on multiple 2.5/3.5 HDDs for close to 5 yrs now..no issue of drives failing. Care needs to be taken for storage in the dry/cool place and check the same once in a while.
DVDs/CDs are a strict no-no for me - apart from the pain in creating those, these are prone to fungus/dust. I have seen the covers peeling off even while being kept in pouches/cd covers.
Try also converting those massive videos into high-compression formats like MP4, which will take much less space and store them on iphone/ipods if you have one, thus giving you at least some respite if the originals go for a toss.
sanjayc is offline   Reply With Quote
Old 9th June 2010, 03:23   #14
anku94's Avatar
Thanked: 33 Times
Although HDDs seem to be the ideal option with optical disks being more delicate and reduced capacity, but one thing I hate about using HDDs for backup that you paid for a device that can read/write data millions of times, and you're using it to save data only once. You paid for a feature major R&D goes into and you're not using it. Being the bania I am, it hurts. :P
anku94 is offline   Reply With Quote
Old 9th June 2010, 03:32   #15
ghpk's Avatar
Thanked: 192 Times
use SSD if possible, although the price of them is currently too high, they should have the maximum shelf life.
Else make a few DVD's (8GB ones) and use an external HDD for another copy.
urgent help needed: can the deleted data be retrieved back in the PC? sidindica Gadgets, Computers & Software 9 28th March 2009 14:41
hdd / dvd burner / delhi whatcanthisbe Gadgets, Computers & Software 57 9th March 2009 16:29
Old HDD Data to new PC?! and more... Gordon Gadgets, Computers & Software 29 16th May 2008 17:45
Ipod to portable HDD Data Transfer viper Gadgets, Computers & Software 5 26th April 2008 14:39
