Old 21st June 2010, 12:18   #1
viper's Avatar
Thanked: 9 Times
Default How to transfer songs from iPod -> PC
Hi Guys,
Need some help with my 80GB Ipod. How do i empty/transfer the files on the Ipod to a PC. Want to delete some play lists and files as it is currently full and i want to transfer some new music there.
If there is some software that I can download for free would appreciate some links.
Viper
viper is offline   Reply With Quote
Old 21st June 2010, 12:23   #2
Prowler's Avatar
Thanked: 305 Times
Go to apple.com/itunes/ and download the application and then install that in your PC. You can organize, add, delete any file from your Ipod through this application.
Prowler is offline   Reply With Quote
Old 21st June 2010, 12:30   #3
BikerSG's Avatar
Thanked: 12 Times
Originally Posted by viper View Post
Hi Guys,
Viper
itunes does not allow transfer of music from ipod to PC - easily.
there are loads of software that allow this. I use copytrans. pretty good software.
theres a free version too.
BikerSG is offline   Reply With Quote
Old 21st June 2010, 12:34   #4
viper's Avatar
Thanked: 9 Times
Itunes does not allow to copy from Ipod to PC. I could not find any freeware that allows you to transfer all files. Most only allow 1 file or folder for free. Can you PM or mail(jngoradia@gmail.com) me link if you do not want to post here.
Viper
Old 21st June 2010, 13:53   #5
nishantgandhi's Avatar
Thanked: 151 Times
SharePod is your best bet.
SharePod
nishantgandhi is offline   Reply With Quote
Old 21st June 2010, 14:06   #6
extreme_torque's Avatar
Thanked: 1,489 Times
Why dont you connect your iPOD as a USB device and copy the music folder?
extreme_torque is offline   Reply With Quote
Old 21st June 2010, 14:13   #7
BikerSG's Avatar
Thanked: 12 Times
Viper
hi. theres loads of freeware or trial software that allow you to transfer from ipod to pc. catch is - they only allow transfer of a handful of songs at a time.
i use copytrans - the paid version.
the only way u can use itunes to transfer from ipod to pc, is by using ur ipod as a hard disk and transferring the folder. google it.
Old 21st June 2010, 14:40   #8
Default sharepod/yamipod
SharePod
+1
I had been a regular user of sharepod for the past 3 years . The only issue i found in sharepod is each song will be placed in a separate/new folder when transferred to pc
one more software
Yet another iPod manager - Home
Seagull76 is offline   Reply With Quote
Old 21st June 2010, 15:33   #9
Default Using Itunes
One more option using ITunes
a) In Control Panel, Portable Media Devices, double-click your iPod.
b) In the Tools menu -> Options, in the View Tab, check "Show hidden files and folders."
c) Navigate to the Music folder in the IPD . Portable Media Devices\xxx'S IPOD (F\iPod_Control\Music
d) Select all the music folders, and drag and drop them into a folder on your hard drive, or directly into iTunes.
e) In ITunes, you can automatically organize your folder by artist and album. (To do this, in iTunes Edit menu, choose Preferences and in the Advanced tab, check "Keep iTunes Music Folder organized.")
Old 21st June 2010, 18:55   #10
viper's Avatar
Thanked: 9 Times
SharePod
Nishant,
Thank you very much. Problem solved.
Viper
Old 14th October 2010, 13:53   #11
t18
t18's Avatar
Thanked: 34 Times
I tried copying files from my Ipod to PC by using the Ipod as a hard disk. But the file name of the songs were converted into codes for eg:- hrdg, jqik. Now I have to play each song and then rename the file. Is there a workaround for this?
t18 is offline   Reply With Quote
Old 18th October 2010, 11:40   #12
sonirohit's Avatar
Well - I use mediamonkey to manage my music collection.
here is how you can do it - Copy the entire contents of ipod into your HDD. Use MediaMonkey to manage these - media monkey has a feature called auto filename from tags where it can reorganize your library based on the ID3 tags of your files, very helpful and you can automate the process as well.
Then use itunes to copy/sync your music with ipod.
sonirohit is offline   Reply With Quote
Old 18th October 2010, 11:55   #13
ampere's Avatar
Thanked: 9,126 Times
There is a utility called iDump, which I used. It worked.
But used it just once.
(Source is always a disk. Never ran into a situation where source is gone and all we have is the IPOD version!)
Lyrics of songs on cars Psycho Shifting gears 56 23rd June 2010 00:11
Ipod to portable HDD Data Transfer viper Gadgets, Computers & Software 5 26th April 2008 14:39
Could someone identify a few songs for me? Sheruken Shifting gears 5 28th July 2004 18:58
Phoebe's Songs! Pferdestärke Shifting gears 9 8th June 2004 21:44
top 5 driving songs souled Shifting gears 2 18th May 2004 14:10
