Old 12th July 2010, 17:45   #1
Sahil's Avatar
Thanked: 2,712 Times
Default Laptop to TV without wires !
PTV1000 - TV Adapter for Intel Wireless Display
Anyone tried this ? It's not very clear by the specs but does any intel i3 & i5 work with this device?
Old 12th July 2010, 18:20   #2
Nice concept. It seems like we need a laptop that supports wireless display!
pmbabu is offline   Reply With Quote
Old 15th July 2010, 16:13   #3
S_U_N's Avatar
Thanked: 383 Times
Requirements for Intel® Wireless Display
Compatible laptops require the following system components. Consult your PC manufacturer to determine if Intel® Wireless Display is supported.
System Component, Requirement
Processor
ONE of the following: Intel® Core™ i7-620M processor, Intel Core i5-540M processor, Intel Core i5-520M processor, Intel Core i5-430M processor, Intel® Core™ i3-350M processor, Intel Core i3-330M processor
Graphics
Intel® HD Graphics
Wireless
ONE of the following: Intel® Centrino® Advanced-N 6200, Intel® Centrino® Advanced-N + WiMAX 6250, Intel® Centrino® Ultimate-N 6300
Software
Intel® My WiFi Technology and Intel Wireless Display must be pre-installed and enabled
OS
Windows* 7 64-bit, Home Premium, Ultimate or Professional
S_U_N is offline   Reply With Quote
Old 16th July 2010, 18:15   #4
DerAlte's Avatar
Thanked: 2,879 Times
Doesn't look like it will work with just about any laptop, since it needs Intel Wireless Display component in the laptop. That is special hardware+software (not run of the mill 802.11 wi-fi) unlikely to be present in most laptops, till it catches up in the industry.
Old 17th July 2010, 01:29   #5
iTNerd's Avatar
Thanked: 505 Times
In the spec of my Sony Vaio Z (i5 540, NVidea 330M), it is advertised to be supported. But I have not tried it.
iTNerd is offline   Reply With Quote
Old 26th July 2011, 16:29   #6
Rehaan's Avatar
Thanked: 25,038 Times
Default Re: Laptop to TV without wires !
Check this out :
Samsung's Central Station - pretty cool!
cya
R
Old 26th July 2011, 17:19   #7
h@r$h@l's Avatar
Thanked: 690 Times
I got this from US a few months ago. Works Flawlessly and transmits A/V seamlessly.
Cables Unlimited Wireless USB to HDMI and VGA Adapter with Audio
Amazon.com : Cables Unlimited Wireless USB to HDMI and VGA Adapter with Audio
Amazon.com: Cables Unlimited Wireless USB to HDMI and VGA Adapter with Audio: Electronics
h@r$h@l is offline   Reply With Quote
Old 26th July 2011, 17:28   #8
laluks's Avatar
Thanked: 9,713 Times
I'll give you guys with a simple setup.
Assumption - Your TV is dlna compatible, and has a network port - need not be wireless. (Anyways most wireless TV requires their own company's wireless adapters to be plugged or mostly do not allow third party wireless adapters)
1 ) We need a network bridge. Most Wireless routers can be made to act as one.
2 ) Plug in the network cable to TV and to your bridge.
3 ) Assign IP number to TV based on your home network configuration.
4 ) Make the IP configuration of your wireless bridge so that it connects to your exisiting Wireless network.
5 ) Most of your IPTV contents will ork now from TV as supported -youtube, etc..
Windows 7 will identify your DLNA device now, you can stream to it from mediaplayer!
To stream video, music etc you need some server software at the PC side. For Sony you can use PS3MediaServer. Make sure you configure your settings files.
It works like a charm at home now. The only investment was a wireless router - the high speed one.
Full configuration on request
laluks is offline   Reply With Quote
Old 26th July 2011, 17:36   #9
anilisanil's Avatar
Thanked: 288 Times
1) It is not clear which TVs are supported (link is broken as of the time I am typing this). Because there should be some hardware which should receive the data from Laptop and display it on TV
2) As Laluks described above, with DLNA capable TV and win 7 you can seamlessly stream media from your laptop to TV. Even if you do not have win 7, most TV manufacturers have their in house software to do this.
anilisanil is offline   Reply With Quote
Old 26th July 2011, 20:32   #10
khoj's Avatar
Thanked: 1,258 Times
Hi laluks,
I am in the process of upgrading my existing tv and would love to have this thing set up. While I already have a wireless router and can buy a tv that is dlna compatible, I use a Macbookpro. Am I going to get stuck because of that or is there a way around/compatible with the Mac's OS.
Old 27th July 2011, 01:44   #11
laluks's Avatar
Originally Posted by khoj View Post
Hi laluks,
Answer in short :
@khoj - Most TVs these days come with options of streaming to it. This may be with their proprietory software either bundled or to be purchased separately. If that softwares work on MAC, then you're good to go. Else if softwares like PS3Media server - which is an opensource project for Sony Play stations - are available for the TV you shortlist for MAC then that is sufficient. Since I am still in the PC world, that part was not researched by me
But consider this too.
As far as DLNA is concerned, it is considered to be a standard with which all DLNA enabled devices can share data. But the solutions that are being flooded in the market are not very clean, and I started calling it Dirty Little Nonsense - Avoidable
But any ways since you have asked - there are two things you must check when you narrow down on a DLNA enabled TV.
1 ) The DLNA certification - you can check this at Home - DLNA
2 ) On which network the DLNA connectivity is certified. Most cases it is the wired one and not the wireless one.
Though most TVs advertise they are wireless networkable, please check the fine print. It is mostly with their proprietory wireless usb devices (around 5K) and not always compatible with any third party wireless devices - which are cheaper (say 1K). So an additional investment has to be made for such a device. If DLNA certification states that the connectivity is only on wired network - then there is no question of getting this device for streaming via DLNA, as it is not supported. But you still can use this device to connect to your Wireless router - which is a part of your existing home network to connect to internet. This will help with youtube, netflix kind of applications that is supported by your TV. But that can still be done in another way.
Considering that DLNA is only available on wired network, this means you have to connect the TV to your PC via a network cable. This renders the entire concept of DLNA devices communicating with each other a farce - since a wired setup is required to establish connection to the other device. This doesnot mean it cannot connect to internet wirelessly.
OK, but there is a work around - A network bridge. The idea is to connect the LAN cable from the TV to your wireless network bridge, and keep this bridge near the TV. Using this wireless bridge we can join our existing Wireless network at home. So basically now the TV is in the TV room, and your Wireless router is another room - say your study room. For this you will have to invest in a wireless network bridge or a wireless router - which can be configured as a bridge. Costs can vary from 2k to 10K based on the device that you chose, mainly due to the speed and band of the network that you chose.
I have a solution at home which connects my i7 lappy to my Sony TV. My lappy is on the internet on a separate band, and my wireless network bridge connects to my lappy on another band. It can go upto a 150Mbps by using the N+ standards (300Mbps advertised) - which gives you stutter free video streaming and parallel internet. Since all videos are now streamed from my lappy it avoids me in investing in a BD player, etc..etc.. since all such formats are handled by the lappy in realtime and transcoded to what the TV can play before streaming. I am not restricted by formats any more.
Old 27th July 2011, 02:05   #12
khoj's Avatar
Thanks for an extensive reply, I am sure I will live through it somehow. Infact, I have already started to comprehend the tricky bits such as the DLNA
Old 27th July 2011, 11:18   #13
anilisanil's Avatar
Thanked: 288 Times
Are you sure? AFAIK, DLNA works on wireless too.
To answer @Khoj's query, Mac has god number of media servers available for media streaming. In fact, I believe these servers are much better and user friendly with MAC OS.
Old 27th July 2011, 11:44   #14
laluks's Avatar
Please read the full post
Considering DLNA certification for the device was only on wired ...then.
If the device is certified for wireless then no issues. But most devices have it certified on the wired only.
Consider this certificate http://certification.dlna.org/certs/REG46753310.pdf for a 55inch Sony KDL-55HX800, which is a wired and wireless TV. The certificate from DLNA clearly mentions the certified network connectivity is for Wired, 100 and 10 Mbps.
If this certificate for your TV says, it is certified for wireless - then it works for you on wireless.
Old 27th July 2011, 11:49   #15
anilisanil's Avatar
Thanked: 288 Times
Oh got you. Quoted you out of context then :P.
BTW, now a days most TVs come with both wired and wireless certified, I believed. Which I guess is wrong, so thanks for the info
Registration of a new car without any broker(without paying bribe) in Noida hdi_pro Indian Car Loans & Insurance 59 17th February 2018 21:40
Honda City 1.5 Freeflow OR Filter + Plugs/Wires buzzin_hornets Modifications & Accessories 23 18th April 2006 21:04
Anybody Using aftermarket ignition coil & plug wires? finetuning Modifications & Accessories 0 27th March 2006 22:41
MSD Spark Plug Wires & Ignition coil Kaizer Sozay Modifications & Accessories 11 16th December 2005 09:12
wanted- high capacity plug wires (honda) nitroxx Shifting gears 2 20th April 2005 18:36
